SG3NW is awesome and perfect except some minor cosmetic “dings”, and has already eaten its o’ring, but that’s not really a problem.
SF3 NW is ok except it looks like it will be eating o’rings quickly too, but there is a small darker spot on the led, and the lowest mode is flickering
It will probably receive a new led very soon, I also got some XM-L2 T4 7A4 this morning
I think the SG3 will replace my Zebralight SC31fc for now :party:
Your SF3 has the same problem like mine did except the flickering is in medium 2 and turbo only. I think this light (SF3) is picky with cells. I just returned this light to HKE and swap with SF5. Great customer service by them! I think it will be easier to just use my eneloops. I don’t mind the lower lumens and the runtime will be longer too. Well, I did lose $6 for postage (not really expensive from my country) but overall still a great deal.
I have not received my SF3 yet. But I worry about the problems I read about the flickering in some modes. I wish to not have such problems, i would be really upset.
I also think the SF3 is just picky about cells. I actually get the flickering on turbo with my brand new AW cells. My theory is that the SF3 is pushing the battery so hard on turbo that it’s causing grief with the protection circuits. I think the flickering is the protection circuit partially tripping. For whatever reason my EagleTac cells just power off when they hit that point, where the AW cells seem to step down a little and flicker for a little while before the protection circuit trips all the way. The TF flame cells seem to go about 30 seconds before they trip the protection and just power the light off.
My SF5 doesn’t have this problem, but then again it doesn’t seem to be as bright on turbo. I think the SF3 is just pushing the batteries too hard. I was thinking of getting some AW IMR cells next to try.
I’ll try some RCR, I have AW protected and IMR, and some Nitecore/Eagletac.
For now I tried with CR123A battery, after leaving it on for a little while it seems to flicker a bit less.
My thought of the day was maybe that it’s the protection circuits causing people grief and not the batteries themselves. Either way this SF3 is a fussy beast and seems to push a 16340 about as hard as it can be pushed. I get about 1 amp even on the tail cap reading for turbo and an EagleTac 16340 hot off the charger.
All things considered the SF3 NW is already one of my favorite lights. The SF5 NW is neat too. I got mine from Wallbuys so I don’t know if it makes a difference, but the tint on my SF5 is a little warmer than my L10-219. It’s absolutely fantastic ! I wish the SF3 was this warm, but it’s still nice and neutral. Even though it’s a little quirky, it’s still so much lighter and smaller than the SF5.
One thing I noticed about the SF5 is that with a regular AA cell, turbo is the same as high. It only gets a higher high when using a 14500. I also noticed that high is about the same with an Eneloop as it is with a 14500, which is interesting. The SC52 is supposedly optimized for an AA but I don’t own one of those. And the S15 Ti is also supposed to be optimized for an AA and it has similar output as the SF5, so I wonder if the SF5 isn’t purposefully optimized for an AA as well. Either way, both of these are fantastic lights and I’m so glad I got them. I should’ve ordered the SG3 and the SG5 as well for the whole set!
I just tried some AW and Nitecore protected, and it does 9 times out of 10 trigger the protection when I tries to activate turbo from any mode except max (when in max the success rate is higher, maybe 5 out of 10).
With IMR, no problem. I noticed the double-clic has to be quite slow in order to activate the turbo mode.
Are the threads gritty on yours, or just mine? I’m starting to think I prefer my Olight S10 over the SF3 :weary:
I’m more interested in shortcuts to moonlight than to turbo…but both choices are understandable, and shortcut to turbo probably makes more sense to most people.
PS: my concern with IMR is the lack of low voltage protection with the SF3 (or am I wrong?). My Zebralight cuts around 2,7V, which is quite low for RCR and quite high for CR123A, and the Olight S10 does not cut at all.
This is the graph of SF5 taken from a review on CPF.
I’ve noticed that the turbo is only 55% of the turbo on SF3. Regulation while using Eneloop is not that bad and I’m sure it will get better with Eneloop PRO. I also ordered both unprotected Sanyo 14500 and Eneloop pro to feed the SF5. It is quite sad because I really like SF3 but IMO Spark should improve the driver in the future. My S10 L2 does not flicker even on turbo (1A tailcap reading) with the same cell but to be fair it will step down to about 60% after 4 minutes. So it is not pushing really hard like SF3.
@Lithium, you can access the moonlight /lowest mode by holding down the button from off. It will cycle back to the lowest mode.
Got my SG5NW today. Great shipping, it was in the mailbox on Friday according to tracking. That’s eight days from order to delivery. NICE!!!
As for the light, it’s mostly good.
The output is good
The tint is perfect for me, very nice
The finish is nice, not perfect but nice
The clip is OK, but backwards and not reversible. Will see if I can get used to that.
The headband fits my head but not the light. Headband must be made for the SG3 body diameter. It’s too loose. The workaround is to leave the clip on when inserting into headband loops.
The threads are well cut but sharp and a little rough sounding
aggressive knurling on tailcap and lens ring, no grip issues there
carbon fiber wrap is nice, has minor finish issues (up close, noticeable seam and imperfections at edges)
Modes are useable, would rather cycle like the Wizard (hold for the next mode, not restart at Min)
Nice UI feature: From Off, double-click to get Super. Turn off. The next start returns to saved mode (a-la Wizard Pro, I like that)
Accepts protected cells, TrustFires are working fine, not tripping protection yet.
The standard wide lens EATS a ton of lumens. I’m probably not going to use it and stick with the add-on reflector I ordered with it.
Brushed finish is inconsistent, on some parts (about half of the anodized surface) it is not noticeable at all
Tailstand is unfortunately not great, due to poor cap design. Aesthetics won out over function here. Headstand is also not good due to protruding button.
Here’s a pic with the Wizard Pro, which up to now has been my EDC. While the SG5 is a very nice light, the Wizard has nothing to worry about. I’ll use the SG5 for sure;
Some quick measurements
table(table#posts).
|Mode|Batt Current (A)|Output (Lumens)|
|Min|0.004|0.5|
|Med1|0.2|4|
|Med2|0.12|32|
|Max|03|77|
|Super|0.77|196|
The S10 looks like a good competitor to the SF3 but I am unable to find a NW version in Ti with the XM-L2 to match the S15 Ti that I have. Hkequipement has the S10 in Ti with a NW tint but it looks like an XM-L not an XM-L2.
The S15 compares favorably to the SF5 but it has a horrible clip and tends to turn on in my pocket sometimes and I have to soft-lock it out. I do like the user interface better on the S15 though. But all things considered, I think the SF5 has it beat by a small margin. My SF5 has a beautifully warm tint, carries much better in my pocket, and from what I can tell uses a 100% constant current circuit. It also doesn’t turn on in my pocket. It would be nice if it had a shortcut to moonlight like the S15 but at least it has a mode memory. Whoever designed the S10/S15 clip was on crack. My wife saw the S15 clip and said “that’s like carrying your gun in a special holster that points it at your face, nice” and she was right.
