switchtesting , (june13th2015:additional test by MRsDNF in post#44)
I stopped the 16A test after 2 hours because nothing much was happenening, I got bored, and I want to go to bed. The small Omten switch ran hot, but still works fine and so does the 6A ebay switch although the resistance seems to have gone up a little.
Here's the last voltage numbers of the two remaining switches:
Small Omten 16A begin: 73 101 125 92 95 91 145 106 93 100 mV
16A 1.5hrs: 70 113 110 80 132 81 115 77 92 104 mV
6A ebay sw. 16A begin: 26 29 37 27 29 29 33 37 31 40 mV
16A 1.5hrs: 34 51 54 47 45 37 40 42 35 38 mV
I did not expect the switches to work so well. Perhaps the Mcclicky and the Judco(Tofty) switch have a lower resistance (can someone measure that for me?, I'm curious about that), but it is not that these switches fail easily. My ideas on these switches: they eventually fail from heating up, and they get rid of the heat via the leads. If the heat can travel a short distance from the leads to a flashlight body (thick solder blobs all the way to where the leads go into the switch and the leads in direct contact with the aluminium, and such) the switch may well perform even better than in this test where the heat must directly dissipate into the air.
Hope you liked these tests, good night :-)
There is but I could not measure the resistance in the Tofty switch with any of my DMM.
A DMM, when measuring resistance, uses a small constant current and then measures the voltage (that is what I think it does). When the resistance is very low the voltage is below what the DMM can measure. The way to go with very low resistances is use a much larger current than your DMM does (like more than 1 amp, or 16 :evil: ) and then the voltage is measurable, and the resistance can be calculated.
Thanks for doing these test.
I’ve had 3 switches fail recently. One at 3.04 amps, one a 4.8 amps and one at 5.1 amps. These switches were not Omten but generic switches in different lights. They all failed by dimming to barely visable light or going completely off.
It appears that the Omten are much better switches, I have 6 Omten 250v 1.5 amps switches on the way with full confidence in their ability thanks to your test.
Thank you for soing these tests. Sure must have been boring though. So much more thank you :-)
I'd like to see tests with the same currents but pwm-ed?Because constant current does nothing to switch,except generating heat,but maybe fast pulsating (for ex. 1khz pwm) current cause some additional "electrical wear" damage?I'm just guessing.
I think the set-up would still work with this resistor load and a FET-driver, so it must be doable. Say PWM causes more wear, it also means less heat because it is used to make lower modes. What would be more damaging (rhetorical question)?
I'm not going to do any more switchtesting this month (holidays, a nice mod in the planning), so there's plenty of time to think of other switch-tests worth doing :-)
Do you think the first switch passed along its heat to the second switch which in turn acted as a heat sink for the third switch?
I had a McClicky fail in an odd way, nothing wrong with the contacts but the light wouldn’t turn OFF. The spring inside the switch collapsed from the heat at just over 10A and wouldn’t press the components to cycle through the ballpoint mechanism. Hence, the light stayed on.
I have a cheap looking switch in my Sinner Ti that is Yanguo or something like that, it’s taking 9A to an MT-G2 ok so far. I worry about it, as it would take the same or one almost exactly like it to replace as there’s little room in the tail cap.
Thanks for the extensive testing and lip sacrifice, means a lot to a great many of us. Tell you girlfriend there’s thousands depending on your results and you’re doing it for the team. :wink:
Thanks for the test, the omten switches really are good. I have the 5pack of the small switches from cnqg they are cheap, reliable and have low resistance. They are only rated for 1A but don’t have problems with 5A. I also measured the voltage over the switch but in the mV range I don’t trust the DMM to get a absolute value but I always test it at 5A and if the resistance is below 100mV I let it stock and if it’s more I put one of the cheap omten in it.
The ebay switch seems to be a lot better but on the other side 60mV more or less is not the world, some tailcaps from eswitch lights have more resistance.
Before I got the switches from cnqg I often opened the stockswitches and tinned all the metal parts that helped often but was a lot of work. The switches which have only one contact on the side and one on the back are the worst because the current paths is through the spring…
Given the resistance in the nickel plated tabs I think you may be right about the copper wires at either end providing a sink for the outer two switches. The design of the failed switch looks good with no current through the spring(usual failure point of cheap switches) so maybe another test with the failed type at one of the outer positions and one of the others in the middle. See which switch survives that handicap best.
Thanks for the tested as always djozz :slight_smile:
I have read this tread up & down several times now & i can not find any info on where we can get this “6A ebay switch” is this some well know item?
Please give me more info so can find these & stock up on the clearly superior switch :slight_smile: i have tried to find it on ebay but my searches failed.
Here’s the thread . It’s linked in the OP of this post.
First two words after the second picture in the op are a link to a thread about that switch. The eBay link is in the op of that thread.
-FMC beat me to it. :slight_smile:
Thanks guys :slight_smile: i don’t know how i could have missed it :open_mouth: i think i was so curious to find out his result of the test :slight_smile:
One of my favorite BLF days are when i learn some new way to get more performance out of my builds :slight_smile: this is one of those days :bigsmile: thanks again djozz :wink:
Any chance you could pop open the other two switches for an inside by inside comparison of the parts?
the small Omten looks very much like the large one, everything a bit smaller. And an inside view of the ebay-switch is actually in your switch-mod thread: https://budgetlightforum.com/t/-/32257 Compared to the Omten, the leads are much thicker metal, and there are raised contact thingies, all in all it is build thicker and better than the Omten. I only wished it came as a reverse clicky as well.
I think someone said here, that you can get a switch to act like a reverse clicky, by lowering the time it takes for the memory to reset it self in the on time firmwares, by lowering the value or altering the components to make the time super fast.
I think it was Tom E, wight & CK who discussed it in one of the driver or firmware threads, sounded like a possible solution.
I have been planning to play with that if i ever get to flashing my own firmwares that is :wink:
Thanks Djozz, that pic is what reminded me to ask. Knowing what’s inside is half the battle when trying to figure out which switch to get for a mod.
Lately with all the switch mods with spring bypasses, different springs, for eg the standard springs replaced with the likes of djozz springs and my need for non standard sized boards l purchased a couple of different sized switches from EDC with the idea of making my own switch assemblies. The switches being reviewed are,
http://www.edc-light.com/5-pack-eoslamp-12x8mm-switch-cnq1854_p0977.html
and
http://www.edc-light.com/5-pieces-of-10a-1318-big-current-flashlght-switch-cnq2227_p1025.html
Firstly a couple of pictures of the switches.
The smaller of the two is a reverse clicky.
The larger one took me by surprise as its a forward clicky of which I could not see advertised on the webpage and assumed it would be a reverse clicky. The solder tabs are very brittle as I broke one side of when straightening it out to solder a wire to for testing. The part you press on the switch to turn it on or off is typical of a forward clicky in that it is very tall
A comparison of the two switches size wise.
The 1318 next to the KAN 28 switch that is a very popular switch. The difference in height is evident here.
And a shot from the top.
The test set up.
Testing was carried out using an MTG-2 led over a period of 3 hours. For the majority of the time the switches were fed 10 amps at around 8 volts and occasionally switched on and off. My DMM only reads to .01 volt minimum.
The difference in voltage from one side of the larger switch to the other was .01 volt at both 5 and 10 amps.
The smaller switch had a voltage variation of between .06 and .08 volts at 10 amps and .04 volts at 5 amps.
Neither switch over heated and there was no perceptible difference in performance or operation of the switches from the start to finish of testing.
Thanks also to djozz for allowing me to post this here.
