Fenix TK61 teardown and mod thread
186 posts / 0 new
DB Custom
DB Custom's picture
Last seen: 5 hours 52 min ago
I got 2 of these drivers. I’ve built 4 different control boards, was having all kinds of issues. Primarily at first it simply wouldn’t work at all. Then I discovered that the wires from the 2 e-switches break the standards. One switch has 2 red wires, the other has 2 black wires. I had it wired wrong. Then I started blowing emitters. Tried changing current and all that but of course I bought it BECAUSE it could run higher currents.
This isn’t the first time I’ve had something working and went for that little bit more… should have left it alone while in the 500’s in Kcd.
The problem lies in the top end output, as the other modes work fine and there’s simply not an issue until Turbo is clicked. Then it’s either making way too much power or it’s spiking and popping the emitter instantly. I don’t see fried bond wires like a massive overload, so it’s got to be a spike or surge. (Doesn’t have to be of course but that’s the way it seems)
DB Custom
DB Custom's picture
I got some new sense resistors in the mail today so I redid the TK61 yet again. I cut a 40mm disc .9mm thick to go under a 20mm Noctigon with a de-domed XM-L2 U2 1D. Removing the stack of resistors I had on the driver, I put 2 of the new R070 that are even larger than the ones originally on the board (it came with 2 R068)
After firing up in Turbo at 6.98, it climbed to 7.13 and seemed to stabilize. I backed it down then came back at it and it hit 7.2A. With the light assembled, this makes 565Kcd and 1611 lumens at start with the light hot. Having the base of the reflector cut out to be able to fit over the 20mm Noctigon is nice, I simply dial the head up or down to find focus. Works really well! Smile
And here’s the inevitable “but”…I see a tiny black spot on the phosphor, so it’s gonna die. Sad
DB Custom
DB Custom's picture
Here's a mouseover of the TK61 with XP-G2 de-domed at 5.5A (557Kcd) vs. XM-L2 de-domed at 7.2A (565Kcd).
Same camera setting, same spot...97 yds to red oil drum. Canon G1X at 28mm, ISO 1600 f/5.6 at 1/2 sec exposure.
(Edited XP-G2 numbers, I had 525 down when it made 557)
RaceR86
RaceR86's picture
Last seen: 3 years 7 months ago
That is a great comparison Dale! Thanks for sharing..
BLF LED database – collaboration spreadsheet and latest news about where to buy LEDs
http://budgetlightforum.com/node/19342
AlexGT
AlexGT's picture
Last seen: 22 min 50 sec ago
Nice mouse over, what were the original tints you were using? Did you use the gasoline method for the dedome? Love how the tints came out in the pic.
Edit, I see you used 1D tint
dazed1
dazed1's picture
Last seen: 1 year 1 month ago
7.2A and only 565KCD?
My TK 61 with only dedome is doing ~ 300kcd – 3A. Should i get to at least 500kcd – 5.7/5.8A?
Fenix TK61 MOD> resistor, transistors, copper heatsink, Artic Cooling MX4, dedome, 3A > 5.7A ~ 1700 lumens > (600.000cd)
DB Custom
DB Custom's picture
The XP-G2 is an S2 2B, gas de-domed. The XM-L2 is a U2 1D heat de-domed. In each case the tint stayed quite nice.
dazed1, I'm a bit perplexed as well. I'm using the HX1175b1 driver to get that 7.2A (well, both numbers but with different resistors) I have a 40mm disc of copper .9mm thick under the 20mm Noctigon. Heat dispersal is near immediate into the head, you feel it and know it's working properly.
I do believe my reflector is off somehow. It seemed warped or something and would not center which is what led me to cut the entire bottom out of it to fit over a 20mm Noctigon. Check out this pic, the base of the reflector is clear...not touching anything at all. The reflector is held into the head by the lens and bezel and is snug. So why the obvious distortion to the left?
gaston01
gaston01's picture
dazed1, I’m a bit perplexed as well. I’m using the HX1175b1 driver to get that 7.2A (well, both numbers but with different resistors) I have a 40mm disc of copper .9mm thick under the 20mm Noctigon. Heat dispersal is near immediate into the head, you feel it and know it’s working properly.
I do believe my reflector is off somehow. It seemed warped or something and would not center which is what led me to cut the entire bottom out of it to fit over a 20mm Noctigon. Check out this pic, the base of the reflector is clear…not touching anything at all. The reflector is held into the head by the lens and bezel and is snug. So why the obvious distortion to the left?
Hi
Its reflector seems out of focus in height…
Sorry for my bad English…
DB Custom
DB Custom's picture
How can you possibly tell the height positioning looking at a picture taken straight down on the emitter?
The focus is perfect at that height. 557.5Kcd with this XP-G2 you see.
It was adjusted actively, tuning in each direction past this point then back to what works best for this light. Meaning, while it was on, shining at a target 35 yards away, the height was adjusted to optimize the hot spot. And right where you see it is what works best. The chrome looking surface of the flat at the bottom of the reflector is approx 1mm above the star. The donut hole in the beam merges at about 1M when shining it at a wall.
AlexGT
AlexGT's picture
I think, because he cannot see the yellow phosphor in the reflected image… bit it is just a guess on what he is looking at.
gaston01
gaston01's picture
So I said “seems” Wink If you corrected the focus is ok…just wanted to collaborate.
I thought it should look like that :
DB Custom
DB Custom's picture
If I’d pulled the camera back to about 3’, or the focus point, it would look similar to that.
That picture was taken to show the reflector cut out to accept the 20mm star. And of course, is actually the Fenix TK61 that this thread is about. Wink
DB Custom
DB Custom's picture
Taken from almost 7’ above the light…
gaston01
gaston01's picture
Take a picture at that distance, and it looks very similar to your photo sorry! Sad
Of course, is thread of Fenix TK61 :~
DB Custom
DB Custom's picture
See how that warp in the outer edge of the lens remains consistent? I believe this is what is keeping this light from being far up into the 600Kcd territory.
Also notice how the reflector has an appearance like it’s Orange Peel? This is a smooth reflector. These are reasons why I dislike plastic reflectors.
gaston01
gaston01's picture
I also think that it should be within that territory…. I think the poor finish of this reflector is the cause, you did something? try to clean it? does not look like std TK61 reflectors
DB Custom
DB Custom's picture
No, I didn’t do anything to it, other than cut the bottom out.
Ordinarily if an aluminum reflector has ripples or lines in it I’ll hand polish it out. I’ve had great success with this. Again though, can’t do that with a plastic reflector. Beats me. I’m planning to search for a good reflector that will fit in here and see if I can get a better result.
Anybody know where a TK61 reflector can be found? Or one from another light that will fit this one?
dazed1
dazed1's picture
Hi guys, did anyone measure,
Stock TK61, dedome only, current bump + dedome, how much cd does it increase with current, is it linear or at least close to it? based on this, it should be 1700 lumens or lets say 1650, does this means around 60% throw increase? thanks.
zeremefico
zeremefico's picture
Last seen: 6 hours 49 min ago
Vihn has some serious update with v2.0
I would like to see the driver he used. http://www.candlepowerforums.com/vb/showthread.php?387187-TK61vn-V2-Thro...)
₪₪₪₪ ΟΥΔΕΝ ΚΡΥΠΤΟΝ ΥΠΟ ΤΟΝ ΗΛΙΟ ₪₪₪₪
My YouTube channel
Flashlights & edc gear
K40M F16
RaceR86
RaceR86's picture
Ill put my money on the HX-1175B from RMM (Not official yet).
It that is the case, its the driver I mentioned early in this thread a few months ago. Wink
(but with some tweaks that have cost RMM a ton of emitters to figure out)
zeremefico
Shut up and take my money.
My YouTube channel
K40M F16
phil76
Last seen: 5 years 5 days ago
a question:
why do you try to replace a p-channel transistor c01c by an n-channel transistor (70N02) ?
i mean it can not function as.
WarHawk-AVG
WarHawk-AVG's picture
Last seen: 3 weeks 5 days ago
phil76 wrote:
a question:
Different polarities, one triggers with pulling the gate (or base) to ground, the other applying a voltage
http://www.allaboutcircuits.com/vol_3/chpt_4/1.html
Quote:
The functional difference between a PNP transistor and an NPN transistor is the proper biasing (polarity) of the junctions when operating. For any given state of operation, the current directions and voltage polarities for each kind of transistor are exactly opposite each other.
http://reibot.org/2011/09/06/a-beginners-guide-to-the-mosfet/
alot of reading…but hope that helps
RaceR86
RaceR86's picture
phil76 wrote:
a question: why do you try to replace a p-channel transistor c01c by an n-channel transistor (70N02) ?
Welcome to the forum phil76.
It was just a quick test I did for RMM.
Latest and greatest driver "mod" for the TK61 might end up being this.
Cereal_killer
Cereal_killer's picture
Last seen: 8 hours 21 min ago
Latest and greatest driver “mod” for the TK61 might end up being this.
Just an FYI- I’ve already corrected the issue tterev3 pointed out in the .sch, just need to fix the board (I added a gate resistor, series / limit resistor (or whatever the name for that would be) and BJT to facilitate the P-FET shutting down all the way.
This is high on my priority list but not at the top and I till I can secure a TK61 for testing I seem to be lacking motivation with all the other crap I have to do (hey I just posted the project 3 days ago, cut me some slack lol).
dsiddens
dsiddens's picture
Last seen: 5 days 6 hours ago
My TK61 arrived today. Batteries took a couple of hours to come up to 4.2.
For my short available range it lights up well. This weekend I’ll give it some distance over water.
zeremefico
Voltage regulator fried, I think it is that same type like the regulator near, type “C01C”. Can anyone help checking his tk61’s driver?
Before I removed it only lowest mode was working, after removing flashlight is dead (pretty normal?).
I found some components in aliexpress and I plan to buy some. If I bridge the spot over there, what will be the results? Do you have any idea if I can find one of these regulators in other drivers?
My YouTube channel
K40M F16
ImA4Wheelr
Last seen: 11 hours 19 min ago
Does this RaceR86 pic answer your question?  Appears to be some type of FET you are pointing at.
zeremefico
Yes and thank you.
I destroyed Q4.
My YouTube channel
K40M F16
gaston01
gaston01's picture
I’m sorry for what happened, I see also the encapsulated coil it’s broken :~
