Thanks for the tips.
I will order that bike mount soon. I need it for a city bike so it looks good. Plus it is cheap which is a big plus as people in my city like to steal anything that is on your bike… even a light mount.
I’ll try to remember to post my feedback of that mount when I get it.
EDIT: Is it possible to take the firmware out of the µcontroller (read the code), then modify it and put it back in? Or is there some sort of protection that prevents you from extracting the code?
EDIT2: I now have the mount. It’s really good and feels solid. The only con is the rotating system’s notches. Each notch rotates of about 15° which is too much for me as I wanted to be able to point the light straight forward. But it’s ok.
Just flash another firmware, maybe JohnnyC’s Star, then it will do high pwm, no more buzzing. you can then also flash an off-time firmware version of that, but you have to add a capacitor for that too).
Exctracion of the current fw is not possible, thats why DrJones made Nlite.
I run the Star Fw (on time) on my S2, with 2800ma Nanjg 105c, turbo timer 90 seconds to half power due to getting it to hot to hold.
at 50% after the turbo timeout i can hold it pretty comfortable for long times(although its still warm) .
My modes are Moon, ~10% and 100% (fallback to ~50%)
Had one of these for about a year and find it very useful for walks in the dark. The only downside is the heat that results whilst on high. This renders High of limited value. I’ve been tempted to get a 2.1A Roche F12 as an alternative. A 2.1A S2 would also be a wise choice and better value.
This happens to be my very first decent flashlight. Thanks for sharing Bort :)
I wonder if there is a black model somewhere? They should have launched it in black, together with gun metal gray model just like S2+. I prefer S2 over S2+.
my s8 is ok for walks but, i wish it had a little wider flood and a little more throw, guess you cant have everything. not sure if it has the same reflector as the s2 but, the flood almost seems as bright as the spot. and the flood at 5 to 10 feet is only about 3 or 4 feet circle and it stops sharply.
i have the 2800ma version and it gets pretty warm after 90 seconds, but i think im gonna bump it up to 3600ma just for fun…. i want to change the led aluminum sink to noctigon, does anyone know if it just has thermal compound?
I did however change the firmware…I put STAR with the ability to auto throttle and after 60 seconds drop from “Turbo” to a lower mode as to not overheat, still runs at 2800mA but instead of running wide open and getting INCREDIBLY HOT it gets warm then throttles back, the light slightly dims when it drops back but no longer overheats
do you know if they will work or have the same threads?
i dont have the flashing tools yet, but i have a qlite 3.04a driver with star firmware on the way along with a noctigon sink. i dont run my s8 on high very long. its plenty bright for close up stuff on medium, but outside for longer distance, i always want just one more high mode for a few seconds. i wonder how many lumens the xm-l2 2800ma is?
i have ordered many things from bg and never had a problem with them. they have good customer service. the convoy flashlight i ordered got to me in 9 days and i live one state over from you. most things i get from bg get here in at least 14 days.
No problem, i just just put another 3 hours of use on it today, did some spray foaming of gaps in the basement and elsewhere and starting installing a new washroom subfloor
According to the Cree Product Characterization Tool an XM-L2 U2 at 2.8A (85ºC) produces 937.1 lumens, assume about 75-80% OTF and you get about 700-750 lumens
