Banggood's Daily Deals -3.20th Updated, Astrolux® EA09 69.99$+Astrolux® BL04 29.99$+Astrolux® EP05 21.99$+Astrolux® EC07G 66.78$
Would it be possible to have a deal on Jetbeam BA20? Those are simple no-nonsense 2xAA flashlights everyone should have for outdoor use and loaning to non-flashaholics
A lot of suggestions coming up and I think BG should take the most popular option. As much as I’d like my suggestion discounted, it’s all about the greater good!
I’m interested in either panasonic 18650 PF 2900mah and 18650-25R, offer in either will be nice :bigsmile:
can you give us the world?
I can't, but I can give u a flashlight to light up the world.
Deal 16/08
EVVA 26650 4500mAh 3.7v Protected Rechargeable Lithium-ion Battery
Code:EVVA26 Price:$10.99 Original price:$12.99
  1. Use quality King Kong lithium ion cell, highest capacity cells, high performance
  2. With Protection circuit Board: SEIKO IC, three Mosfets which can stand higer current
  3. Small internal resistance
  4. High energy density, low self-discharge
  5. Pollution free, long cycle life
  6. No memory effect
Ordered 4, thanks!
Deal 18/08
SolarStorm SC01 XM-L2 T6-3C/U2-1A 190LM LED Flashlight
Code:SC01 Price:$12.99
Deal 19/08
Olight SR51 Intimidator CREE XM-L2 1080lm LED Flashlight
code:SR51 Price:$49 original price:$64.99
if u like the standard one with aluminum box, pls PM me
Your link directs to an ebay auction.
Also, bg’s has 3400 mah batteries & xml2 too.
BG doesn’t include batteries but it is international. The ebay link is $40 postage to Aus :frowning:
Not showing in any of the links BG posted.
Hi neil
Olight SR51
i like the standard one with aluminum box is it same price $49?
Deal 20/08
1*30 Reflex Laser Sight Rifle Scope With Red+Green Laser Configurable
CODE:LSRS Price:$20.99 Original price:$23.69
Maybe someone need this one for hunting.
Specification:
Product name:1*30 Reflex Laser Sight Rifle Scope
Material:aluminum alloy
Waterproof:Yes
Light color:Red and Green
Power supply:CR2032 cell batteries (included)
Size:14.2cm x 5.5cm x 5cm
Weight:about 276g
Deal 21/08
2PCS INR18650-25R 2500mAh 3.6v 20A Rechargeable Li-ion Battery
CODE:IN25R Price:$11.25 Original Price:$13.69
Specification:
Product name: INR18650-25R 2500mAh Rechargeable Lithium-ion Battery
Brand: Samsung
Nominal Voltage: 3.6V
Discharge cut-off voltage: 2.5V
Nominal Capacity: 2500mAh
Standard Charge: 1.25A, 4.20V,CCCV 100mA cut-of
Discharge: 0.2C, 2.5V discharge cut-off
Max. continuous discharge: 20A(at 25°C), 60% at 250 cycle
Weight: 45g
Size: 18mm x 46mm (body diameter x length)
Quantity:2pcs
sumsung 25R deal today!
Deal 22/08
Dipper D19 Cree XM-L2 U2-1A 5-Mode 1000 Lumens 26650 LED Flashlight
Code:DD19 Price:$36.99 Original Price:$45.09
Emitter: Cree XM-L2 U2-1A
Mode:1.5%Low-40%Middle-100%High
2.5%Low-40%Mid-100%High-100%Strobe-100%SOS
Protection: reverse polarity protection, low voltage protection
With stainless steel attack head and memory mode
Deal 25/08
Smiling Shark 3W SS-5049 Mini LED Bright Hand Torch Flashlight
code:DBLF04 Price:$1.9 Original price:$2.99
Features:
The product is a mini LED flashlight
It with 1 bright LED and comes with a clip, which can easy to carry.
Clipe design, easy to carry and use
LED light will practically not burn out
Fits Comfortably in Hand
Pls tell me the next deal.
