Henry has mentioned about a new lubricant in one of his previous posts in the gb thread but I can’t find it now. He has been aware of the fan noise complaints.
Think going to order this with batteries. What’s the difference between the blue and red 26650 6000mah tangsfire batteries?
Not only the charger, the power plug does also show a CE logo.
If you are to source your 26650 cells from Gearbest, better take the Soshine brand of 26650 batteries. Tangsfire brand are relatively of unknown quality.
When is Gearbest going to get proper batteries?
The internal switch has 3 selections: 3.7V, 4.2V and 4.35V, and all bays will be affected according to the chosen terminal voltage selection in charge mode. Its default is 4.2V
Hi BLF folks,
Here is some good news for all Opus charger fans
First, the breaking news is the new 2.1 version Opus BT-C3100 is available now :
Opus has granted Gearbest the exclusive rights to be the first website offering the latest BT-C3100, the 2.1 version. Opus supports us to run this campaign at $45 for the first publish, only 70pcs for EU and 30pcs for US, It can be available for ordering right now, the coupon code is: BTC3100. Barring any unforeseen circumstances, the 2.1 version will be shipped starting Aug. 27. Any more buyers(from the 101th) will bring the price down to $43, and the first 100 buyers will be given a $2 coupon back. You know this rule from our previous game, right? :party:
Just so we’re clear, this means that the promotion is not just for the first 100 pieces but for the first shipment of version 2.1?
doppel: tatasal: ChibiM:is there an (auto) 4.35V switch? or do you still have to open the case
The case still has to be opened, but very easily by taking off the 4 screws, then the whole bottom is exposed, including the selector. Just a two-minute job.
Actually I have brought this issue with Henry Xu, the designer, citing the VP2 design as an example. His logic in putting the selector inside is that with the selector outside, there is a very high chance of it being inadvertently or accidentally switched to another selection and can be dangerous to a new user. (of which I personally agree) Imagine accidentally switching to the 4.35V selection for a 3.7 LifePo cell to be charged. It happened to me one time when I was using my VP2.
Does this do LiFEPO4 charging also? Their description says “3.7 Li-FeO4”.
Also, if yes, does that have to be selected with the same internal switch you mentioned, and then do all 4 bays only do LiFEPO4?
Thanks to you and all the others who brought this to this point. I’ve been lurking for awhile and definitely on the fence with the earlier versions, but this one sounds like it might a winner. I still want to wait for HKJ’s review though…
Thanks again!
oh… Bad design then… !
They should have improved this issue!
Took the bait!
The case still has to be opened, but very easily by taking off the 4 screws, then the whole bottom is exposed, including the selector. Just a two-minute job. Actually I have brought this issue with Henry Xu, the designer, citing the VP2 design as an example. His logic in putting the selector inside is that with the selector outside, there is a very high chance of it being inadvertently or accidentally switched to another selection and can be dangerous to a new user. (of which I personally agree) Imagine accidentally switching to the 4.35V selection for a 3.7 LifePo cell to be charged. It happened to me one time when I was using my VP2.
Could they use a key lock switch? That would be much more convenient than disassembling the charger each time and prevent accidents as well as an internal switch. I have no idea if it would be economically feasible but I'd be much more likely to buy a charger I didn't have to disassemble every time I wanted to charge a different type cell.
Could they use a key lock switch? That would be much more convenient than disassembling the charger each time and prevent accidents as well as an internal switch. I have no idea if it would be economically feasible but I’d be much more likely to buy a charger I didn’t have to disassemble every time I wanted to charge a different type cell.
I’m sure the switch has 4 legs to it, a common power and three grounds for each position. O’Reilly’s [or any good hardware store] should have at least one multi-position rotary switch. Finding space for it might be interesting, it would require some fine soldering, but it could be made to work.
Looks like the price on the C3100 v2.0 went up to 39.00. Can anyone else confirm?
Hello NobleX13,
Thanks fro your notice, the 2.0 coupon has been fixed, the right one is: GB3100, at $36
gearbest:Hi BLF folks,
Opus has granted Gearbest the exclusive rights to be the first website offering the latest BT-C3100, the 2.1 version. Opus supports us to run this campaign at $45 for the first publish, only 70pcs for EU and 30pcs for US, It can be available for ordering right now, the coupon code is: BTC3100. Barring any unforeseen circumstances, the 2.1 version will be shipped starting Aug. 27. Any more buyers(from the 101th) will bring the price down to $43, and the first 100 buyers will be given a $2 coupon back. You know this rule from our previous game, right? :party:Just so we’re clear, this means that the promotion is not just for the first 100 pieces but for the first shipment of version 2.1?
Hi sganimefan,
Yes, you got it! the Opus offer us the first stock, we are the first website to provide the 2.1 version
subscribe for update
sganimefan: gearbest:Hi BLF folks,
Hi sganimefan,
That’s great to know. Would you be able to share how many have been sold already? And how many pieces are actually allocated to the first shipment? Thanks.
Subscribed. Want to see HKJ review on it!
NobleX13:Looks like the price on the C3100 v2.0 went up to 39.00. Can anyone else confirm?
Hello NobleX13, Thanks fro your notice, the 2.0 coupon has been fixed, the right one is: GB3100, at $36
Coupon code is not working for me.
Nice, waiting for HKJ's review before I decide
+1
