Is there still visible PWM with these? Thanks for the teardown.
Thank you.
Thank you very much. I have been very curious about this and that answers many of my questions.
I must say I fast forwarded a few times but I never watch video reviews because I can read a written review in about 1/10 the time and I did watch this.
Too bad about the modes though. Why would they adobt the chinese standard 3 modes? 100/50/25%
Anyway it is what it is. They likely wont change it anytime soon and I am still just happy that people who live where maglites are less dear than here can get modern tech with modes and hopefully great durability to run off alkaleaks. Wish it was me.
Why you no let kitty in video?
I can't watch video here, but the pictures show hints of quality stuff. Very exciting. Thank you O-L
thank you for the review Justin - I was wondering when you would get your hands on this new model
the pictures isn’t work for me
How long until someone figures a way to drop in a new driver and Boom! We have More Light! Much less battery life but more light.
Not supper thrilled with the spacing of the modes, and not sure how I feel about the twist spot/flood. Even back in the early 80’s when I got my first one, I thought that it is kinda a gimmick, and left it on spot most of the time…
Thanks for the tear down. I wonder if we’ll see this change on the ML units. I’d really love one of them with decent output.
I see they use my favorite Buck-Boost IC, the T.I. TPS63020. What surprises me most is the use of a four layer PCB. Seems odd for a cost conscious flashlight.
Haven't yet figured out what all the other stuff is for... this may be an interim to test the market and then shift to a custom IC approach down the road.
See Post #1 for the correction of my errors. Sorry about that.
tps63020 datasheet
I like it, looks like a nice design :*
So, I'm thinking a copper replacement for the metal pill, with a MT-G2 on it and replacing the driver in the switch. Who's going to do it first? I know someone here or on CPF, (machinist), will come up with it. Would be a great mod that could be done fairly easily, with a lathe.
If we had the light here I'd suggest it would sell for about $6000.00 + GST. Thanks for your thoughts OL. I'll watch the vid later.
Beam shots and Amp draws are in the OP.
With cells in series 1.5 amps is 1.5 amps, it's just at a higher voltage. With fresh alkalines I guess voltage under load would be, what, 1.4v per cell? 1.4 volts x number of cells x amperage = input power in watts. The 3 cell light using those numbers would be only 6.3 watts, and that's input power, so the output side will be something like 85-90% of that.With only ~6 watts input there's no way anything even close to 4.5 amps is going to get to the LED.
The 2 cell version would have to use a boost driver so the input current would be higher to make up for the lower voltage (and also boost drivers are usually less efficient). The 3 cell very well could be a buck-boost driver, since 3 nearly flat alkalines will be below the voltage needed to run the LED at ~5 watts.
Compare the tailcap current with fresh cells to the current with nearly flat cells, that will clear up a lot about what the driver is doing. If current goes up as voltage falls, it's switching over to boost mode. If current continues to fall with voltage it's buck-only.
This one stumped me for a while, until I figured out what it’s actually for. And it isn’t flood to throw. It’s a focus.
It allows you to optimise the beam for any distance. Something a fixed focus torch can’t do.
For example, some of my C8’s and my small sun, if I shine them at a wall fairly close up you get a donut hole in the beam, this is because they are more optimised to throw. But it makes them less useful on low when you want to use them close up. Most fixed focus lights compromise and don’t quite optimise focus for throw, to then avoid the donut hole.
With the Mag you can refocus it for any distance and always avoid the donut hole. The off shots from this mean you really can the best throw the led and reflector size offer. It also allows you to make it more floody, although I don’t believe that is the prime purpose.
I edited the post. I don’t understand it, but I edited it. I think I need to stop taking amp draws, since I don’t understand it. Thanks for pointing it out.
EDIT: Current does go up as voltage falls.
Cool function sets. Nice feature.
I like how the new beam pattern much more. The old pencil beam was cool for throw, but not good for general usage. Much smoother beam now too.
I think it's more to focus the light with any bulb. The old bulbs with a flange had significant variation from sample to sample. I spend many hours bending flanges on PR series bulbs with long-nosed pliers to adjust the focus for each particular light. Didn't have to do that for Mags. Didn't help with off-center filaments, though.
