With the current emitters, there is little difference in multiple lights when calculating total output based on wattage. Since you are pulling nearly 12 watts, that is a significant lumen generating energy draw. Add that to some very focused TIR lenses, you get some pretty good LUX numbers to boot. Yes, there is driver efficiency and the 15% upgrades in the newer Cree offerings, but it is still nearly 10 watts worth of light.
So is my rough calculation of 750mA on each XP-G correct?
-Garry
I’d say so. As long as you trust your readings.
This is going to be a cool thread.
Not sure how long this "deal" will last, but I just picked up a very cheap MS 808E clone, head only, for $8.50 ($7.23 + $1.27 ePacket trackable shipping) on Ebay. The seller shipped it out immediately and I received it in 12 days (though perhaps the moon & stars just happened to align perfectly to allow this to happen). I received the light on Monday and can indeed confirm it has the 4 mode driver (H-M-L->off, with press-n-hold for hidden strobe). I think bike lights with this "4 mode driver" are much nicer than the 3 mode High-Low-Strobe. Note that this is the first head only light that I didn't receive mounting bands with. It is in fact an XM-L as shown/advertised, but I expected to swap out the LED for a nicer tint anyway. I will say that after a quick play with the light I do see that the tint is a very nice "pure white" without hint of blue, purple or green.
Link:Red CREE XM L T6 LED 1200 Lumens 4 Modes Bicycle Bike Light Headlight Headlamp | eBay
I'm not saying this is a fantastic light, but it's cheap enough to grab it to try one out (esp. with Action LED's wide angle lens and a Pannova battery case) or just to have an extra light.
Current pulled from the battery pack (@ 7.98v):
Off: 0.015A (A little high compared to my other lights)
Hi: 0.833A (100%)
Med: 0.263A (32%)
Low: 0.099A (12%)
Not driven very hard, though that provides great runtimes. I'm sure it could be resistor modded.
No other details or photos at this time, but it's a typical MS 808E clone light with a fairly tight hotspot and wide dim spill.
-Garry
I have a pair of these lights. The whole kit is out for under $20 delivered in several places. I think the metal is optimized for the larger SSC-P7 emitter since the XM-L fits a little loose. Overall, for the money it is a great light. Excellent runtime even with the cheap supplied cells. And yes, the standby current is not welcome. Also not completely waterproof but good enough for a downpour. It has a “weep hole” where the cable comes out so driven water can enter, but in general use, not enough to do damage. I’ve run one for over two years and it is hard mounted to the frame of the bike. No issues.
Readers may find my new "Diffusion Techniques Testing" thread useful in application to their bike lights.
-Garry
What about the cooling in those cheap lights?
Is the LED good thermally integrated?
Generally these lights have decent pills (for their current level) but the pills simply lay in the head (hardly worth calling press-fit, but maybe some are better than others). During the recent testing with my 3mode one the body was getting quite warm indicating decent thermal transfer which impressed me.
-Garry
UPDATE: New Flickr Photo Gallery Link: https://www.flickr.com/photos/garrybunk/albums/72157692347399235
As posted in ledoman's review thread, I bought a SecurtyIng HD-016 version of the UniqueFire HD-016 "dual beam" light from Amazon.
I haven't torn it apart yet, but I've taken current readings and got some beamshots.
Current pulled from 2-cell battery pack at 8.24v:
Off: 0.020A
Flood: 0.663A
Throw: 0.665A
Flood & Throw: 1.410A (Steady, not dropping)
(BTW - I am confident current readings I make are accurate.)
Flood is VERY wide! However the "flood" mode doesn't throw out far at all. I can't imagine "flood" alone being enough to ride with (except commuting where it is used more for "be seen" use. I think I would prefer the reflector be just a tad deeper in order to get a little more throw out of it.
Here are some beamshots. Pics taken with my same manual camera settings at roughly the same location so that my beamshots can be compared one to another. In the first set of pics, the distance to the trees I aimed between is approx. 185 feet (garage is beyond the trees at an undetermined distance - I really need to determine that). Approx. 275 feet to the house off to the left of the trees. (Note: you can barely see the trees or garage in the "throw" pic.)
Flood:
Throw:
Flood & Throw:
Now to my wooded trail spot:
Flood:
Throw:
Flood & Throw:
That wooded shot above really sells this light!
Next is a full teardown and mod to XM-L2 T5 5B1's and a resistor modded SSX2 driver to run Flood & Throw LEDs at all times in a High-Med-Low (or Low-Med-High) arrangement.
-Garry
UPDATE: New Flickr Album Link: https://www.flickr.com/photos/garrybunk/albums/72157664781725888
I took a chance on Kaidomain's Gemini Duo/YingDing clone. My driver runs on 4.2v input (as stated in KD specs). I tried 8.4v input and the battery level indicator just flashes red-green-red-green, etc. . . . light won't turn on or do anything else at all. Current draw on 4.2v battery (with thick leads, which made a big difference in output) was:
Off: 0.013A
Low: 0.51A - 28%
Med: 1.23A - 68%
High: 1.795A - 100% (so about 0.9A +/- per LED)
Someone posted this mode change behaviour previously on MTBR, but I can't remember where and which light. When you change modes the light actually dims very slightly and then "ramps" up in brightness quickly until the next mode level is reached. Off happens instant though. Modes are: Off-Low-Med-High-Off. Press-n-hold for strobe. My driver is NOT the "10 step programmable" one which has appeared in some of these.
TIR lenses from LED-DNA are interchangeable once removed from their white holder
Pics:
Beamshots:
Low:
Medium:
High:
So even though I felt it was under-driven, the beam on high doesn't look so bad. I think I will still resistor mod it for a little more output and address the lack of heatsinking. I'm intending this light to be a helmet light, so I'm keeping it more of a thrower with a floody light on the bars.
Mouseover with my standard 808E clone:
Mouse Out = KD light, Mouse Over = 808E Clone:
Mouseover with my stock HD-016:
Mouse Out = KD light, Mouse Over = HD-016 (flood & throw both on):
Some comparison photos with the HD-016:
This light is TINY!
Discussion on resistor modding this driver posted in this thread.
-Garry
Thanks Garry, it does look tiny compared to the HD. Not trying to create more work for you
but if you have wider optics for the KD, it’d be interesting how it compares w/ the HD.
I do have these Carclo 20mm wide angle lenses now I could try. I also have these 20mm "pinstripe" lenses from KD. Then I have the various 10°, 25°, 45°, and 60° lenses from LEDDNA which I tested previously individually (see my signature). One thing I meant to do and forgot was to take a beamshot while covering up one of this lights optics so I could compare it to my LEDDNA optic beamshots and try to determine which angle lens it is stock. I'm guessing it's a 10° lens?
I'll see if I can get the time to try it out. It's getting cold around here now and it's even starting to snow as I type.
-Garry
You’re setting yourself up for more grunt work :-).
Interested to hear your thoughts on the 3x XML2 light
Which one? You mean these? (Though they're usually XM-L.) Or do you mean the top secret one I have coming for review? (Shhh . . . don't tell anyone :) ).
-Garry
The one I posted about on MTBR with the purple trim ring. High>Low>Strobe, mine says 2400lm, yours is listed at 3600lm. We both know they will be about 1000lm tops.
You said you bought yours from Gearbest, I’d get mine from Amazon.
Ah, yes that one. It's on the slow boat right now (tracking isn't showing anything). I'm kicking myself now that I didn't ask to review the one Cat recommended trying in that thread. Actually, that light might not have been on Gearbest's site when I chose a light to review.
-Garry
UPDATE: New Flickr Album Link: https://www.flickr.com/photos/garrybunk/albums/72157662737583937
Just received my GearBest 3x XM-L2 bike light for review light yesterday. I hurried up and grabbed some beamshots last night while the weather is still decent and there's no snow on the ground. This thing is a seriously bright flooder! Check these out:
What really impresses me is that this light only pulls 0.92A from an 8.26v battery pack on high. It also runs on a 4.2v pack (same two cells in my 2P1S battery carrier) and pulls 2.02A from that. So that's roughly 0.67A per LED. That calculates out to roughly 5.5+ hours of runtime on high on an 8.4v 5,200mAh 2S2P pack (your average 2600mAh cells)! After reviewing in stock form I'd like to see if I can mod the driver for higher output. I haven't torn it apart to look at heatsinking or the driver yet. Stay tuned for a full review.
-Garry
