beamshots "Lumapower" xm-l + 3x mc-e + 3x xr-e 44mm lens ...
and long distance beamshots
The shutter speed was 3 sec, but the iso rating only 100, overall a little bit over exposed. (full moon's light on the background)
the church is 360m away
control
lumapower xm-l
tr-1200
x2000
xm-l 4A +52mm lens
xr-e 1.5A + 44mm lens
3x xr-e 3x 44mm lens
it's a "homemade" flashlight
Well I'm impressed forget the shutter speed.
How much for one like this?
Or for this one? That's a bright thrower.
How would something like a Trustfire 3T6 compare to that?
That's a good question. I don't have one but maybe someone who does can chime in.
Trustfire t6
小さな画像をクリックすると、下に拡大表示されます。
  • TrustFire CREE T6×3 5モード 3800ルーメン 爆光ライト_画像1
  • TrustFire CREE T6×3 5モード 3800ルーメン 爆光ライト_画像2
  • 正面の壁まで約20メートル
TrustFire CREE T6×3 5モード 3800ルーメン 爆光ライト_画像1 TrustFire CREE T6×3 5モード 3800ルーメン 爆光ライト_画像2 正面の壁まで約20メートル
Thanks for the beamshots .
to the first post and pictures, camera settings was the following: 1sec shutter speed, and iso200
And I think my 3xmc-e light is almost the same as the new triple xm-l flashlights, trustfire sky-ray etc..., maybe a little brighter, becasue my light sucks over 3A from 3 pc 18650. I use relative old cells with this light (~150mOhm internal resistance), because of the direct drive. It could be to drive easily over 4A/emitter with newer cells, but I dont want to overstress them.
This google translate helps me alot, but I know it's not perfect. :)
Ok I still didn't get my questions answered. Do you sell these lights are would you build a guy one? If no, I understand. Just curious.
Nice beamshots, nice 3 x MC-E too. Quite noticeable donut though. Surprised that the 5 x Q5 did not throw as well....you got the more recent versions? (only the first batch was driven aggressively)
For those who wants to buy the 100mm diameter 3 x MC-E, can try PAlight BG-03 and XTAR D31 howitzer. Expensive though.
Sorry, but this is a hobby for me and I do not want to sell or build more.
Yeah, it would be better with xm-l -or a better reflector- but when I made this light, there was not yet only mc-e. It's a DX triple reflector SKU 11922.
My tr-1200 with 2 cells goes 2.5 ampere, it's ~ 15W or more.
Earlier I made ceiling bounce test, and tr-1200 performed "35" relative value, and the C8 clone xm-l's score was "40" at 3.5A. The throw capability is almost the same for the tr-1200 and C8 clone.
Well if you change your mind let me know. I would pay for a light like that if it is reasonable.
hi! viffer750, Could you show a picture of this flashlight? xr-e 3x 44mm lens (I'm impressed).
thanks.
+1
as you wish
and spot size and intensity
above: x2000
left to right:
C8 clone xm-l 3.5A
tr-1200 5xQ5
xm-l 4A 52mm lens
xr-e 1.5A 44mm lens
Your triple Q2 aspheric seems to be able to comfortably outgun the SR90. Do you have access to a lux meter?
Yes, I have a cheap one from ebay, lx1010bs. I don't know how accurate this. I think it measures higher value than the real (20-30%). I have only relative peak lux values from 3 meters.
x2000 Q5 1.3A ~ 2300
C8 clone xm-l 3.5A ~ 4300
TR-1200 ~ 4300
xm-l 52mm lens ~ 8000
xr-e 1.5A 44mm lens ~ 9200
3x xr-e 44mm lens ~ 24000
Any info is better than no info. BTW do you mind measuring from say at least 10m, preferably 15-20m? What i am trying to do is to let the beam focus and smooth out, when you are farther out the hotspot peak intensity will be easier to get hold of and not only stay at a small place (it smooths out so to speak). Also the meter sensor will not get overloaded, as you can see 24k is too much. Forget about the specs - most guys in the hobby know about the characteristics.
C8 XM-L @ 3.5 is pretty well known. XR-E @ 1.5A with a 44mm aspheric is also guessable. Yours is high but we still can make corrections and give educated somewhat accurate guesses and be around in ballpark.
Your XR-E @ 1.5A with 44mm is probably 55k region in true life (i am expecting decent heatsinking but not excellent, so you get around 1.1A-1.2A true relative performance unless you directly mount to pill). Triple XR-E aspheric is 2.6X, so you get 143k. Could be slightly higher than Olight SR90.
