If I put a clock on my light builds and/or charged by the hour, well, it wouldnāt be pretty.
I will post the file work, by the end of Monday, because the light will be done, to the point of awaiting a driver by that time.
These are all TIR optics, so the beams will be smooth across and floody. Just an even lighting. It won't throw, but it should light up a good wide area in front.
Why is the cover plate looking immaculate? It should be full of crease marks and an odd looking shape. Are you sure you dont have a laser cutter out back hiding with your elves? So the light is going to have fibre optic feelers. Neat.
Out of curiosity, what happens if the user plugs in the module to the USB and turns the light on? Will that be ok for the charge board? Will it be the 1 amp from the charger plus whatever the battery gives to power a given mode? And if less than 1 amp then the battery will still charge? If so, this will take the title of coolest USB-powerable light ever. Slap that onto a car charger and you can throw a disco party everywhere you go.
Also, do some nichias have that little square on the base board because 1 of the LEDs looks like it has it while the other 2 donāt in the LEDs shot.
I do not know for sure. I would think that the driver would pull from both sources, but it would not pull any more than it normally would. The driver is asking for xxx amps and whatever the power source, it would only take what it wants, but as to problems with both sources on at the same time, I just do not know. Never thought of it really.
All the Nichias are the same. Just the angle of the photo that hides the black spot.
The optics for the Nichias are from CNQG. They are 15 degree, 20mm around and designed for XM-L, but the beam with Nichia looks fine. I tested them out before hand.
Rotary tool, Dremel #115 bit and plenty of patience, opening the holes up and then fine tuning them several times. They are not perfectly round, as I did them by eye and checking by holding the plate over the lens, but they came out fairly close. Not perfect for sure and not as accurate as a machine would make. None of this is that accurate. Iām a perfectionist, thatās why I am never satisfied with any of the builds I do, or anything at all, for that matter. I see they work, but I see all the faults. I think thatās why I try so hard, to try to bet that one perfect light. Of course that never happens, but itās my challenge to myself.
