Here is the original ‘work in progress’ OP. At the time the thread was titled:
“[WIP] 17mm 8x7135 with Zener & dual-PWM + stubborn”.
v008
I was concerned about the 3 vias located under the tab on the top 7135 which sits next to the Zener diode. I suspect that during reflow those vias could cause the 7135 to shift inwards and possibly bridge the Vdd/PWM pin onto the Zener’s pad. To combat this problem I distributed vias around the GND ring.
A178PZL?
= “puzzle” ? In order to taunt people when they realize that they should have soldered the MCU in place after the 0805 components?
pizzle? (wikipedia is your friend)
Yeah, puzzle. As in what order do I do this?
+1 for puzzle!
I’m for puzzle too.
Hah, I’m game. Puzzle sounds like a clear winner right now.
I updated the resist on the bottom to make reflow easier. There are now well-defined dams of resist between every 7135 tab and the exposed ring. The actual exposed ring is now very very thin, but the copper layer hasn’t changed (it’s 1mm) and I’ve added exposed scallops to make up for it.
Of course the silk is updated to reflect the name
It’s getting better all the tiiime. The scallops for the expander boards? It looks like there are some acute angles on the 7135 traces. What are the two lines across the L+ pad? They look like breaks in the copper leaving only two narrow paths for current.
EDIT: Thanks!
- The scallops on the bottom are there to increase the solderable area which is available on the ring without scraping. Just something to make it easier to solder the driver into a pill in other words.
- The only acute angles I see are where PWM traces “Y” together on the bottom. Is that what you are referring to? I did those on purpose because I like the way it looks. I do not expect it to affect operation or fab-ability. Are you looking there or somewhere else?
- The lines across L+ are just an artifact of the OSH Park rendering technique and Eagle’s Polygon output. Polygons in Eagle are turned into a series of overlapping lines. This is normal and only affects the previews.
Aha! Yes the traces from the pwm pads to the ring and also led- to it’s ring but you know what you want. I’ve tried to minimize these by making the connector traces radial to the rings and connect to a pad corner but if it works wgaf?
Right. I think it’s about 6 of one and half a dozen of the other. Eagle doesn’t have dedicated tools for either task as far as I know. Neither way looks entirely natural. Aesthetics probably would have settled the question - if one looked better I’d have gone with that. Instead I settled on the one that was significantly easier for me to eyeball.
In a circuit like this, at these frequencies, as far as I know the only potential problem would be with a super, super bad fab not being able to produce something. Eg an “acid trap” problem, although I don’t have enough experience to know if that’s a real thing or just something people on the internet chat/whine about. I don’t think we’re going to run into any of that.
Looking good!
Looking good!
Thanks RMM!
It’s really a pity that Eagle does not have more features related to aesthetics, snapping, geometric layout, etc. CorelDraw would make short work of those revisions and make the result look better. Fortunately the final product is a tiny PCB, so my minor misalignments shouldn’t be super obvious.
In Post 10, the last pic you show, you left out the little circle that identifies pin one on the MCU.
I don’t like it.
I LOVE IT!
I don’t like it.
I LOVE IT!
Hahaha, and of course the text is rotated 180 degrees from the direction the MCU should face. Wow. (that was unintentional)
Updated to v012 -
- Added a covered 1mm via for SW+ hookup from rear. Either pass your <1mm wire through and just solder onto OTC pad if you want or scrape before assembly and solder directly into the via.
- Improved LED- trace on bottom in order to facilitate the chunk eaten up by the 1mm via that was added.
- Increased LED+ and LED- vias to 1.3mm for cleaner and easier 20AWG/18AWG installation. Not really very important here, but I figured I’d do it for consistency. Maybe you’ve got a long run to the LED and want to use big hookup wires.
- Updated silk slightly. Added orientation mark for MCU.
- Updated GND pours for cleaner and more accurate look on renders.
I think it’s ready for a release. I haven’t built one yet. I never ordered any because I wasn’t happy with the driver yet in earlier versions.
Updated to v013 -
- Swapped PWM outputs (Pin 5 & Pin 6)
I realized today that I had the PWM outputs connected in reverse as compared to RMM’s Moonlight Special. Of course that will work, but it was not a drop in replacement when done that way. IIRC the way it’s currently implemented in STAR requires code changes, not just define changes, so that’s a pain. I think I might have originally done it as a matter of convenience, or maybe it was just a side effect of this layout being derived from this one. Either way having the pins connected in the same fashion as the Moonlight Special is better for everyone in this case. I’ve updated the driver to be that way. As a result, the section under the MCU is a little bit less clean looking… but who’s counting?
