HowTo: Modify Carclo Optics for XP-L Use
Using a $0.25 T25 Torx Bit - Vinhnguyen54's Idea
Convoy S2+ Shorty (18350) With 3x Domed XP-Ls & Modified Carclo
1. Background
As many of you know, the Carclo 3UP & 4UP optics don't fit over the XP-L die since they were designed for the Nichia/XP-G2/XP-E2 class emitters. Our solution has been to either dedome the emitters, or try clumsily to use a drill bit or a sharp knife to open them up.
Last week I was over at Vinh's house (Vinhnguyen54) and as I was walking out the door, he asked me "are you still dedoming your XP-Ls?" I answered, "yeah, I am--I've tried opening up the optics and haven't found anything that I was that happy with", "check this out!" he said. He then proceeded to show me a very simple, cheap, and repeatable way to open up the base of the optics using a filed down T25 Torx bit. This was his idea, but I'd like to share it with all of you.
It is an imperfect method--but it is cheap, easy, and gives good enough results for me to recommend using it until something better comes along.
All lit up. Not too shabby!
2. Items Necessary
Here is a list of what you'll need:
- T25 (or similar) Torx bit
- A file to taper the bit
- Slow electric screwdriver, or a manual screwdriver (fast is not good)
- Carclo Optic
- A bit of patience!
Just some rough file work will do.
Old, rough, and rusty, but it does the job!
- You want to use a slow speed when opening up the optic (I wouldn't recommend using a regular drill).
- Stop frequently to clear the debris so they don't scratch the inside of the lens.
- Stop frequently and check with an XP-L to see if you have gone deep enough.
- The less material you remove, the less the beam is affected; however, if the fit is too snug you risk dedoming/ruining an LED.
That's about as deep as you want to go!
Mountain Electronics : batteries, Noctigon, and much more! What's new?
Or would it be beneficial to get a end mill bit? Like a 6 flute end mill maybe? Then it would cut clean... might be a centering issue then I don't know.
Thanks for sharing. You'll be sure to sell a lot more optics now! :bigsmile:
I'm sure that there is a cleaner, better way to do this, but it surely won't be $0.25!
This is BLF, after all!
Thanks for sharing! Have you tried sanding and buffing the remaining burrs for a cleaner end result?
Have you compared light loss between dedomed emitters and dined emitters using this method?
Newb
I guess I am not a good member here, just ordered an 11/64" 3 flute ball nose end mill bit.
Dog ask me, cow should I know?
Edit: Ain't it purdy?
Regardless of the method, its nice that these can be opened up without changing the beam pattern. Thanks for posting.
Ban all Klarus flashlights! >>>>> https://www.reddit.com/r/flashlight/comments/a0n88o/klarus_with_a_strong...
Review: 150 Million Candlepower Military Xenon Arc Battlefield Illuminator (AN/VSS-3A)
My new collection of 50+ Chinese knives
But I'll use it for some of my other projects so it won't be for nothing either way.
Cool. Thanks for the tip.
Thanks, that’s what I’ve been looking for. Any idea if the rough finish hurts the % of light much?
There is truly no way to know without having a perfectly polished one to compare it to. I'm sure it isn't optimal, but my 18350 powered S2+ measures over 2,000 OTF, so I'm pretty happy with it!
Thanks for posting!
I’m think it should be “too little and it will be hard to center” and “too much and you will bottom out” ?
https://www.flickr.com/photos/akrylamid/sets/
cool idea!
ai laik!
already member of M4DM4X.com ?
the best deals are waiting for YOU!
BIG THANKS for helping me by using my REFLinks
before you buy elsewhere mail me: MARTIN@M4DM4X.COM - i will try to save you money!
Very cool. Nice to know it can be done without messing up the beam profile.
I’m a junky, I mod lights so I can sell lights so I can buy more light to mod so I can sell lights to buy more lights to mod.
Acrylic edges can be flame polished, I don’t know if that can be done here.
is this really an advantage over a dedomed xp-l?
Newb
Massive advantage. Cereal_killer explains it perfectly here: http://budgetlightforum.com/node/35436#comment-674837
Keeping the domes on is most beneficial in maintaining tint. De-doming costs some lumens but most importantly it degrades the tint, sometimes in a way that is too much to take...the pea green hue.
Say you absolutely LOVE the 3D tint (I absolutely LOVE the 3D tint!), you really can't de-dome an emitter and wind up with that color of light. De-dome the 3D and it changes pretty drastically to orangish warm. The warmer tint emitters aren't as prone to show the pea green color, but they do shift away from the preferred tint. It's been pretty common with the XM-L2's to de-dome 1A tint emitters to keep the color as nice as possible. But are there 1A XP-L's? 2A, 2C, 3D...I haven't seen a 1A yet. The 2A's aren't horrible when de-domed, if you don't mind a slight off yellowish-green hue. (very slight usually, but still)
Thanks Richard! Like Dale, I LOVE the 3D tint, and now I can have it in a 20mm triple! Could you show a comparison beamshot between the modded dome-on triple and a de-domed one? And do you know the approximate OTF lumen difference?
“Strive to be a warrior and a scholar. Be forged in fire and tempered by knowledge. If not, you will either lack the courage to fight for your ideals or lack ideals worth fighting for.”
Whichever way (this way or my way with a knife blade) the key factor to watch out for it to not bottom out the tool in the optic cup- if the in inverted dome get’s scratched it’ll screw up your beam badly.
My recommendation is to buy extra optic’s to practice with.
RIP SPC Joey Riley, KIA 11/24/14. Now I am become death, the destroyer of worlds.
Now you're asking a lot of me, lol. I actually have a dedomed XP-L V5 2A triple which I could use to compare in the same light. I'll try and get some beamshots/output comparisons, but it might be a while until I can do so.
The dedomed XP-L's beam is very similar to a dome-on XP-G2 beam.
The big deal here is keeping the tint, since I'm guessing that the lumens difference is under 10%. Also, not everyone is comfortable dedoming emitters. This is much easier and cheaper if something goes wrong!
Hey RMM… you should offer opening up the optics to fit domed XPL as an extra add-on service with all your Carclo triple optics
Even if the XP-L stays within 10% of it's output when de-doming, with a triple light that's a 30% loss in output! With a hot rodded triple, that can be a very significant lumens loss.
Say we're seeing 1400 lumens per emitter for 4200 OTF lumens with the domes on. Take the domes off and lose a mere 10% and we have a 520 lumen loss! Yeah, I'm all for keeping the domes where they belong, on the emitter instead of on top of my computer. (I have a little collection of hot de-domes.
Edit: Obviously, even more impact on a Quad.
Let see your collection! :bigsmile:
xkcd.com/1603 Li-ion battery safety 101.
Couldn't resist trying, so I modified a Torx bit and gave it a shot...
I used a cordless Makita hand drill with variable speed and did most of it at very low revolution. Then I set it to high speed mode and ran it fast to sort of polish the cut. Works so so. There was a bit of slag along the cut edge that I scraped off with the razor sharp tip of my Sage 2. Now I'm gonna have to build a light!
Just ordered a shorty S2, I swear those weren't on the site last order I placed just day before yesterday! Now I'll have to wait for that to come in so I can complete this quad.
They weren't! Added them last night.
Been available since yesterday for the triples and quads.
Here is one that might work…might need to remove the outer ledge in order to expose the cutting blades
http://www.harborfreight.com/reamer-deburring-tool-65338.html
Good idea. I just use an exacto knife and taper out the openings with that. Same way as I trim off the metal in the ID of a pipe after cutting it.
My PayPal address: oldlumens (insert the @ sign here) gmail.com
My YouTube Flashlight Video Channel
The BLF Modding Links Thread
The output loss is still noteworthy of course!
@RMM – thanks for posting this.
Still fine, still on a break. One day I’ll catch up with you folks! previous wight catchup
list of my drivers & variants (A17DD, FET+1 stuff, WIP stuff, etc)
