[retired] [WIP] 20mm single sided & 17mm double-sided ?-amp linear driver - surprisingly good!
Reserved.
I am going to sound unedumicated here, but whats the point of this driver? is it like a 7135 driver, but just with a different method / components? Or is just simply higher amperage? like a fet/7135 crossover?
It started out as a 17mm driver, but would not fit. :frowning:
It should be able to supply pretty high current. It doesn’t require a pile of 7135’s. It all fits on one side. A normal single-sided 7135 based driver of this size might fit 5 or 6x7135, so maybe ~2.3A max.
Hmm, that reminds of of a feature I forgot to implement… I was thinking that it would be nice to implement a bypass where the ATtiny could pull the Gate pin on the FET high for “turbo” type stuff. There isn’t space in the current layout, but an air-wire could easily do it. EDIT: yes there is… clearly Pin5 and the trace it needs to connect to are right next to each other. Oops. :wink:
When I get more motivated I’ll take another stab at cramming this into 17mm. While the LD-1 is clearly a superior driver for single cell applications and hotrod SRK’s… this driver can run an MT-G2.
Would it also work in a 3s-3up light? And what sort of programming would the MCU need?
I forgot: the other point of this driver is that I got confused and bought some QX7136’s thinking that I could do something with them I could not. :slight_smile: :~ So I needed to make something to use those up.
It should work fine in that application. The MCU would run the same code as normal, STAR & etc. Pinout is the standard pinout used by most ATtiny13A based drivers here on BLF. A DrJones MCU would be fine as well.
OK, so this is more like what’s required to fit it in 17mm:
https://oshpark.com/shared_projects/P6EcXEmU
  • Again, somewhat sloppy.
  • There should be appropriate clearances around the MCU for a Pomona SOIC clip. (As usual. Measured as a 6.4mm x 8mm tall rectangle around the MCU.)
  • 9mm spring pad.
  • “turbo” bypass implemented in this version on Pin5. The ATtiny can bypass the QX7136 for a turbo limited only by the sense resistors and FET.
  • Normal PWM output remains on Pin6 (eg the standard pinout).
So I guess the idea for this 17mm one is a “big power” MT-G2 driver in 17mm… and also to use up those pesky QX7136’s of course! :wink:
What’s the calculation for the power rating required for the sense resistor’s?
The issue I ran into trying to use 1206’s in extremely low value’s for sense resistor’s in some of my drivers was that there just isnt high power rated 1206’s out (very very few 1W and a few more 3/4w) and there’s only one brand of those (vishay dale) and they’re VERY expensive and there isnt a large selection of them available in small quantities.
You simply calculate the power dissipated. Current multiplied by voltage drop. In this case the voltage drop is extremely low, so Power is as well. At 10A drive current you’re looking at 0.5W total (0.25W per resistor). At 20A you’re looking at 1.0W total, 0.5W per resistor. That should be easy to purchase at a fair price. ($0.40 to $1.00 each in QTY=1)
I think you may have been using a relatively high sense voltage?
I must say all designs on the forums just blow away Chinese designs in simplicity and features, even using their own stuff like QX7135 or QX7136.
Thanks Hikelite.
I should point out that anyone who plans to run 5/10/20A? through one of these should plan on heatsinking the FET properly. Potting it in epoxy is probably a good option. This driver is also compatible with the ‘remote’ boards led4power posted on OSH Park. The same wiring and cautions apply.
Also, if you setup your driver for 5A and then use the turbo bypass business to achieve 15A you will take the sense resistors beyond their ratings. I wouldn’t worry too much about it as long as you pot them. Or just don’t use the turbo bypass stuff, it’s not necessary.
If you start with the knowledge that your setup will do X-watts in DD and work backwards you can establish a safe regulated current so as not to take the sense resistors beyond spec. For example, say you know that your light will do 20A in DD. We’ll be splitting 20A between two resistors, so 10A per resistor. If we can afford a pair of 1W resistors for this project, we can use an Ohms Law calculator with that and the 10A figure and establish a resistance of 0.01 ohms. So with two in parallel we’d have 0.005 ohms, which works out to 10A regulated. Therefore for a light which does ~20A DD (turbo bypass) we’ll need to regulate at 10A for regular modes in order to keep the sense resistors in spec. As I said, I expect that we can exceed spec with potting.
I’m interested in this driver, I have lots of 7136’s (and everything else too). Would you be willing to send me your files, or at minimum your .sch and I’ll make my own board?
Here is the Eagle LBR and the datasheet link, post #39.
Err, also note that the 17mm v003 board is missing GND vias. I will be posting an updated version.
Well, I’ve just done my first test of the QX7136. It seems to operate as expected, no surprises. I used a small bank of FastTech R100 1206 sense resistors - I started with 3x and then moved to 5x.
Based on the results I got, I think these FT components are around 0.105 to 0.110 ohms. 5x of them gave 2.29A, close to the expected value of 2.5A but no cigar. About right for R105-R110 though. I measured the voltage across the bank while in operation and got 0.049v - I have little doubt that my meter is off by 0.001v and the little IC is right on point. :slight_smile:
:expressionless: = my level of comprehension
:bigsmile: = my level of glee
:beer: = my BAL
looking forward to seeing how this gets used.
I did some cleanup to the 17mm version this evening. No major changes.
  • Added GND ring vias.
  • Made LED+ and LED- vias directly perpendicular to each other and evenly spaced from the edge of the PCB.
  • Added a covered pad for LED+.
  • Straightened up the bottom a small amount.
https://oshpark.com/shared_projects/flBsJz93
OK, I did some testing.
We’ll need an FET better suited to this purpose than NXP PSMN3R0-30YLD or Vishay 70N02. Supfire’s M6 driver uses Din-Tek 30N02 (DTU30N02). Unfortunately DTU30N02 is a DPAK part, making it rather large (phsyically) for this application. I don’t fully understand what makes this part a better fit than the other FETs, but I’m working on it. One clear difference is the Threshold Voltage.
Maybe Vishay’s SiR800DP is a good option, datasheet link. Gate charge is higher than DTU30N02, but still in the range of what I think is reasonable (someone correct me!). Drain and dissipation are higher as well, not that they matter at this level (both are very high/good). Also, “Applications” listed in the datasheet are similar. :wink:
I flashed STAR momentary v1.0 on an ATtiny13A with these modifications:
  • disabled turbo
  • disabled LVP
  • switched to Phase Correct PWM (maintained standard fuses)
  • #define MODES 0,5,10,15,20,25,30,35,40,45,50,55,60,70,80,90,100,125,220,230,240,250,255
Here is my stripboard setup with a DTU30N02 and 4v input. As before I’m setup with 5x cheap R100 which achieves a regulated 2.29A
At the lowest output levels the scope’s interference is too much for the QX7136 to cope with, so output flickers and the waveform shown is inaccurate. Here is a “big picture” shot of the waveform generated at a “low” level.
As you can see, there is a lot of noise on that. Zooming in, we see the nature of the noise.
I think that the output waveform looks very agreeable. Note that the pictures show an output of maybe 2.4v! While this may not be the smoothest output ever, it’s free of the normal “off” pulses we see from a 7135 driver. I think that this driver will be much more efficient than I realized at low levels. Note that in the most zoomed in image, voltage never drops below 1.7v and does not exceed 3v.
There are a lot of modes, so I do not absolutely guarantee that these are 100% lined up, but they should be quite close. These are shots of what the controller was doing with the DRV output to the gate. Note that there is only so much juice available on DRV and the scope may have disrupted behavior some at lower drive levels.
PWM Level: 0/255
PWM Level: 5/255
PWM Level: 10/255
PWM Level: 15/255
PWM Level: 20/255
PWM Level: 25/255
PWM Level: 30/255
PWM Level: 35/255
PWM Level: 40/255
PWM Level: 45/255
PWM Level: 50/255
PWM Level: 55/255
PWM Level: 60/255
PWM Level: 70/255
PWM Level: 80/255
PWM Level: 90/255
PWM Level: 100/255
PWM Level: 125/255
PWM Level: 220/255
PWM Level: 230/255
PWM Level: 240/255
PWM Level: 250/255
PWM Level: 255/255
Nice work Wight, are you aiming to be the most prolific driver creator on BLF? :slight_smile:
Is the 7136 similar to the 7135, just without the internal mosfet? If so, can you spare one of these devices? The only suppliers I can find of 7136 are on Aliexpress, never used them dont seem to like PPal….:frowning:
Heh. :wink:
I’m not really sure how they compare from a technical perspective. Based on the output waveform in post #18 it seems that when implemented with the external FET, the QX7136 behaves pretty differently from the xxx7135. If I recall correctly a 7135 will turn fully on and off during PWM.
When used by itself the QX7136 can be set to between 10mA and 400mA using an external resistor. I have not tried using them that way, this is my first implementation with the QX7136. I don’t see much point in using them that way anyway.
I can probably help you out if you need it. That said, this eBay seller shipped promptly and packaged well, I was happy with the purchase: http://www.ebay.com/itm/370787091970 The listing says that they ship worldwide.
There are other products which are also called 7136, be sure not to become confused when shopping. The HT7136 is definitely NOT the same thing, if a person was in a hurry they could accidentally purchase the wrong thing.
