It occurred to me I have no pictures of the actual effect of de doming, so here’s one, hope it helps.
OP updated
Only package 3 left!
Special package offer #1
5x XML2 U2-1A 6500-7000K De-domed on 20mm Noctigon
Only £28.00!
Special Package offer #2
1x XML2 U2-1A 6500-7000K De-domed on Maxtoch DTP 31.5×1.6mm
1x XML2 U2-1A 6500-7000K De-domed on Maxtoch DTP 26×1.6mm
Only £18.00!
Special Package offer #3 (1 avaliable)
3x XML2 U2-1A 6500-7000K De-domed on 20mm Noctigon
Only £18.00 (plus shipping)
Ok, so I’ve been asked about de doming the MTG2 …A LOT! So I’ve finally done it! If there’s interest I will probably be able to do some, however due to the price (these things are expensive!)I can not buy a lot of these!
XML2 U3 1A have arrived, avaliable now!
De-domed XML2 U3 1A 16×1.55mm DTP Copper £9.00 now £6.00!
De-domed XML2 U3 1A 20×1.55mm DTP Copper £9.00 now £6.00!
Limited time!
MTG2’s still avaliable!
Sale
MTG2 Q0 5000K De domed 25mm DTP copper
Only £12.00
Only 4 MTG2’s avaliable
What does the MT-G2 do when de-domed? Does it change the output and/or the throw? Also, is there a visible tint shift with the MT-G2’s that you have de-domed? If so, is it similar to the picture in your OP?
It has the same effect as when you de dome and XPG XML or XPL a slight loss in lumens (not noticible) but an increase in throw, the best way to describe a de domed MTG2 would be ‘highest output led but less throw than other emitters’ - due to die size
So if you want a maximum output but throwy light then the MTG2 is the way to go.
Received today, thank you
The packaging was second to none, absolutely first class. There was no way that any ham-fisted postal worker was going to damage this shipment!
And with a free gift too! Thank you, will be buying again………
Woody
Thanks for letting me know Woody!
Better safe than sorry when it comes to packaging fragile things! I use as much as I can so theres no damages!
PRICE DROPS
Yes, Hank supplies me with the LED’s and MCPCB’s and the threads are linked to the website!
OP Updated
Arrived. All right. Thank you.
Ciao
