Leave the light on in whatever mode you want to ' memorize ' for at least 5 seconds .
Turn the light off .
When you turn the light back on , it will be right where you want it .
Edit : If you wish to save it in low mode , you will have to wait several seconds after the blink before you turn off the light or it will revert back to the opposite mode group .
I think the S2+ uses a fairly standard type of driver with next mode memory. Basically, the light will advance to the next mode unless you leave it on at least 2 seconds. If left on that long, then it will memorize that mode and stay in it next time you turn it on.
Your best bet would be to upgrade the driver with a “off-time memory” driver from Mountain Electronics. Instead of measuring the time the light is left on, an off-time memory driver uses a capacitor to measure the time the light has been left off. If you leave the light off for something like 1 second it will come back in the same mode it was last on. With this time of driver, you can flash the light on for a half second and still get the same mode next time you turn it on. It’s far more intuitive. You’ll need a soldering iron and basic soldering skills to install the driver.
Some lights have shortcuts that allow instant access to low or high from off. For example, you can turn on a Zebralight to moonlight just by holding the button down over half a second. Or you can get to max power by clicking and releasing quickly. Unfortunately, this type of driver requires an electronic switch and is not compatible with the S2+ without major structural modification to the light.
