I've read a few of the methods some people have done it, like sanding the central solder pad until the metal core is exposed and then filling the void with solder, or just straight up drilling through it.
However high and low after searching I haven't seen anyone make a video of the actual process of removing. Getting Sinkpads or Noctigon's are the definite obvious choice, but being BLF minded I wanna get the most bang for buck. :beer:
djozz made a thread comparing MCPCBs with one of the cheapy copper boards' dielectric layer stripped with some pretty good results.
Thanks for the replies. Yeap buying Maxtochs/Sinkpads/Noctigons are the obvious thing to do, but unfortunately I have quite a few of the cheapy copper boards coming in soon, so its time to whip out the xacto knife :)
The few I have done have fiberglass glued to the board, no chance to cut it out and lift it off, hard as a rock. Cut the first layer and then a screwdriver to scrape it away.
I Have a few laiyng around and don´t want to throw them away so… Next time it will be only Noctigons.
