Sounds good. Alexvh’s method should adapt fine to the “normal” style of offtime memory rather than “offtime no memory”. Both the cap and this new method could be considered flags: the same method of keeping track of modes used by STAR_off_time is fine.
Oops, I posted before seeing your reply. So yes, it seems they are being compiled differently. We should try to figure out what’s different so that people compiling with AVR studio have the right options set.
The flashlight terms can be a little confusing, but I think I know what you are asking. Yes mode memory can be added to this using the eeprom just like in the other drivers. I’ll upload a version with that soon. So that the light turns on in the mode it was previously left on in (unless it is a short press, in which case it comes on in the next mode). This was mostly meant to show how it works and what can be done using this method. I wanted to show that you don’t have to use the eeprom at all unless you want mode memory.
I’m certainly no expert with AVR Studio, but I can try suggestions for different settings to compile & test. I know there has been a few minor differences in versions of AVR Studio that have caused hick-ups in the past.
I figured that should be the case. This is a real nice chunk of meat for the programmers here
Good stuff! Maybe this method can’t replace the short, medium and long press with the off time cap but it will surely make the stock driver much better. Thanks for sharing.
I can confirm that this method works well, it’s what I use on all power cycle lights, and implemented on a PIC in my code example here: tterev3's PIC quickstart guide
I found off-time memory via RAM retention some months ago, too. It's a known behavour with PICs, and I've seen tterev3 use it, but less known for AVR since it requires disabling the initialization the compiler does by default.
It worked, and I was quite excited at first, planned to make an off-time version for lucidrv with it, but found that the time was a bit too short on my test NANJGs to be comfortable; it required a decisively short tap and would often not recognize a 'normal' tap. So I didn't pursue that further and instead made a version for an off-time cap.
BTW, it's the voltage divider that pulls voltage below RAM retention level so fast. One could use double values for both resistors to make it more comfortable, but then again, adding a cap is easier than that. Without the divider, the driver held the 'cookie' (the value I used for RAM retention checking) for 10 minutes.
Also, if you want memory, you still need to store the mode in EEPROM.
Edit: I didn't use brown-out detection.
Thanks for the additional info DrJones. This sounds like it may be an effective dodge for the Tiny10’s lack of EEPROM (offtime / no memory with high-value voltage divider resistors).
That said, who wants to fool with the Tiny10? :~
I think it is also not possible to tune offtime periods in firmware with this method. With the OTC method those who do flashing can easily tune the values if desired.
Here's my code with memory, based on MiniDrv:
#define F_CPU 4800000 //use fuses low:0x75 high:0xff #include <avr/io.h> #include <util/delay.h>
//change modes here; just change/add/delete values
uint8_t modes={8,90,255}; //PWM values, 5…255#define NOINIT attribute ((section (".noinit")))
volatile NOINIT uint16_t cookie;
int main() {
DDRB=2; //define PB1 as output
EEARL=4;EECR=1; uint8_t mode=EEDR; //read from EEPROM
if (cookie==1338) {
mode++;
//else mode=0; //NOMEM
cookie=1338;if(mode>=sizeof(modes)) mode=0; //wraparound, also check if invalid
EEDR=mode; EECR=4;EECR=4+2; while(EECR&2); //write mode to EEPROMuint8_t lvl=modes[mode];
TCCR0A=0b00100001; TCCR0B=0b00000001; //PWM setup, 9kHz
OCR0B=lvl; //set PWM level
while(1) {} //endless loop
Do you have a way of measuring how much off time you can have before the cookie expires? I’ve found I can get about 500ms of off time before the memory decays with the capacitor on the 101 driver (I measured it to be about 10uF). If I swap it with one from a 105C driver (about 5uF) I find I can still get about 400ms. When I’m using my flashlight normally, I find I press the switch for 200-300ms. I find that this method works fine for me. I’ve been using it in my flashlight for a little while now and I’m happy with it.
I’m curious if you found it was too small based on personal preference, or if the max off time was just shorter in your experiments.
On my drivers with pics I’ve seen greater than 10 seconds. This is without a voltage divider, so there’s no significant drain on the capacitor. Usually I tune the time to be where I want by adding a resistor in parallel with the cap. My normal combination is 2.2uF and 150k for about a half second timeout, which is my personal preference for this type of UI
Warning very basic question (I’m not really using Atmel studio at all anymore)… Where do you find / add the include files? Or does 6.2 do that all on its own at compile time?
That’s the purpose of the includes. They are brought in at compile time by the compiler. This is a pretty universal thing, not limited to Atmel studio or even to the C programming language family. Include directive - Wikipedia
Yea I get what they are, PIC used them in EVERYTHING (MPLAB 8.x) but you have to manually add them to the project tree. So in AS6.2 you don’t have to do anything at all but name them and the compiler handles looking them up?
Sure. I’ve never had to do anything manual to get includes working… in Atmel Studio, in other IDE’s, on the CLI, etc… it’s strange to me that MPLAB requires you to do something special to get includes to work… but sure enough, Google shows exactly the kind of thing you are talking about… Set The Include Directory Path - Developer Help
Just bumping the thread so people can see my update at the top. Ramping and optional mode memory added to firmware.
Thanks, I’ll take a closer look very soon!
Thanks. I’ll give this a run through AVR Studio to see if I have the same problem as before.
I’m hoping that problem was fixed by making the variables that are held after a power off volatile. It should prevent the compiler from doing optimizations that stop the trick from working.
I tried this on a different driver, a FET-based one designed by BLF members. It works! The lows aren’t low enough on a FET, and the ramp shape is a little weird, but the off-time memory seems to work as intended.
I will probably try using this technique on some of my non-OTC lights, since it seems like a solid improvement over “short-cycle” on-time memory.
Also, I added this code into my repository, linked in my sig below. Thanks for making it GPL!
FWIW, I adapted this technique into my brass-edc.c firmware just now, and it seems to work well.
Additionally, it reduced the size of the ROM by 262 bytes! Now I have more than a quarter of the ROM to play with if I want (it went from 1018 bytes down to 756). This method allowed me to remove everything related to the WDT, eeprom, wear levelling, and the “short cycle” memory bit.
It’d be better if it could detect short/med/long presses instead of just short/long, but it’s still a big improvement over on-time memory.
(I’m particularly happy about this, because I wanted off-time mem on this light but it doesn’t have enough room to add a capacitor and still be able to reflash it or fit a battery)
