Do you get mode issues with nimh batteries? Are the modes 2.5-35-180 lumen on both battery types? Any mode memory?
No spring right? Looks like it could use foam in the head to help action.
Thanks sofar for the review! Do you have a picture of the driver, and how the led is mounted? Is there a removable pill? (I ask for obvious reasons ).
Strange, I cannot duplicate the problem, every battery works fine now. Probably the battery's button got caught with the foam just now. No memory, starts from Low.
I tried to peal off the foam with my tweezers, but I end up tearing a piece out from it . Foam is weak and double side tape/ glue is strong. It did expose some components underneath the foam. I have no choice but to seal it back, cannot afford to damage it before I finish up the review.
[quote=djozz]
[/quote]
I know from disassembling a DQG AAA light that it is easy to damage the stuff inside. I just hope that this light is a bit easier to open up and swap the emitter. No hurry for this, and I would not want you to destroy a nice light :-)
Are the modes 2.5-35-180 lumen on both battery types? Is it brighter on 14500 or the same? How do you like it overall?
Thanks for the review!
14500 does produce slightly higher output than NiMH, based on my initial measurements. XP-G R5 was 725mA on high which is more than 250lm. Yes, I like it a lot and I have been playing with it for the past 2 days. I do own a couple of ultra-compact class flashlights, but none of them is able to hold up to my expectations until now. It is definitely my first choice for EDC light right now. But please do not take my words for it, as choosing flashlight can be a personal thing.
Those are LED lumens. OTF (Out the front is likely 165-175 lumens assuming 65-70% efficiency).
Also, tailcap measurements do not account for driver inefficiencies so you are not getting that at the LED.
It still seems pretty good though. I may order one because I’m a sucker for little AA lights.
Yup, OTF value be ~15% lesser. 65% efficiency will be really bad...
You got me! I ordered one. Thanks for the review!
You are welcome.
+1. Remember to apply the coupon.
You might want to updated your findings if you no longer have mode change issues…
Just ordered a NW sample. Thanks for the excellent review, your picture of the light next to the 18650 is great for scale.
I love mine (incredibly compact). Obviously, I will only use with NiMH (Nitecore NL147 and Olight 14500, not fits ok) :
Trevi_lux, very nice collection! I plan to run only Imedion AA and maybe a L91 at times. Judging from your collection, the fact that you like it is high praise indeed . I really like SS lights. Looking forward to this lights arrival.
Body of DQG same width than EagTac d25a Ti (2013). Head is 1mm fatter.
Did you notice PWM? Thanks
No noticeable PWM in all three modes.
CW is 1A and NW is 4A tint bin. For some odd reason BG has listed those as current.
Conclusion
Coming Soon
