Frankly i donāt care. With that said, gaaah, I hate it when youāre right. But I guess thatās why youāre the sheriff in town. 8) Yes it seems to be a race. I only tested before with 10% and then it shut off a few times. But if you test 50% sometimes it shuts off and sometimes it goes to full output. It doesnāt matter though as you just set all pins to input and be done with it.
Iām pretty happy with my first driver so I wrote another one. Iām a c noob so I basically just make things up along the way. And I managed to get just about everything to work except one thing, I couldnāt for my life get the right mode count of an array I pass as a parameter to a function. In the end I found out that itās not possible and you have to pass the size as its own parameter. grrr. Anyway, it got run time group settings so itās pretty cool. A seasoned c coder probably can save a few bytes here and there and squeeze a bit more modes into it so happy hacking.
Thank you so much for this!!
I appreciate all your time and effort in enhancing our community as you have.
Toy Keeper, Iāve got your cypreus2 in my EagleEye XA-6 triple build, so far Iām liking it, the blinky modes are fun in the rain. Is there an easy way to make the first hidden mode High instead of Max Turbo? Hitting max turbo on this light is painful in daylight.
Joat, to change the hidden modes, just change the definition of HIDDENMODES so it says ā100ā or so instead of āTURBOā. You might also want to change the last āPHASEā to āFASTā on the next line. And if you want a short tap to go to max turbo instead of moon (off to moon, med top to high, short tap to either moon or max turbo), you should also change the ā0ā on the HIDDENMODES_ALT line to the number of the mode you want next (probably SOLID_MODES-1).
So, itās a little weirdā¦ but thatās because I wasnāt planning on putting any regular operation modes in the hidden loop.
Also, one reason max turbo is so easy to get to from off is because it serves as āimpress modeā, for when muggles ask about a light. They donāt usually care that it has a nice moon mode, but theyāre sure impressed by max turbo.
And thank you back. I found this site when I was looking for pwm-less drivers to get away from the buzzing. I had zero knowledge about that you could write your own firmware with fast-pwm before. Iāve been seriously impressed with fast-pwm so far. All I can say to all of you is that if you donāt want to flash your driver yourself you should buy one from mtn that already got fast-pwm. I thought ToyKeeper was just talking bull when she said that fast-pwm is almost as good as no pwm but not even the SLOW shower trick seems to work with fast-pwm so Iām happy.
Speaking of shower tricks, a 24 Hz strobe with 0.3ms duty cycle is lots of fun with running water.
(also, showers are terrible at showing PWM unless itās really slowā¦ water droplets change shape as they fall so they generate their own light pulses even on constant-output lightsā¦ try waving a note card quickly through the beam instead)
Yes the shower must be slow, edited post above. Will test the card trick later but must first go out with the dog in the night and test a few new firmware features i just added. Multi group firmwares are pretty useful after all I must say. Itās amazing how much you can squeeze into 1024 bytes.
Yes, in C arrays are passed as a pointer to the beginning of the array. If you want to know how big that chunk of memory is, you need to pass the size too.
Also, this means that the symbols for arrays and pointers can be used pretty much interchangeably. The syntax of āarray[3]ā is basically identical to ā*(array + 3)ā. Take the pointer, add three of whatever its size unit is, then get whatever is at that location in memory.
Lets just say that I found that out the hard way. Usually I just go by the āif it works donāt try to fix itā philosophy but when you only got 1024 bytes you must code as efficient as possible too.
It works but Iām not really sure I got it completely right though. The rest of the multi group code I got to work directly (didnāt think that would happen). Not sure itās the most efficient way though but so far so good. Also, I canāt really see the point with battery monitoring (if you run out of juice just pop in another one :laughing:. I only kept the power down stuff and got rid of the low mode. Turbo timer I can see that it can be useful with high power DD drivers though so I also added that.
One effective way to deal with array issues in C is to use the Pascal approachā¦ make it one word bigger than necessary, and use the first item in the array to store its length. Another way is to make it one word longer and put a null at the end, but that means you canāt store any other nulls in it.
Or if itās hardcoded at compile time, use āsizeof(myarray)ā to get its length. But that only works for hardcoded arrays and only when the original symbol is referenced.
Yeah I managed to fix the problem with sizeof as my arrays are hardcoded compile time. But I did read up on the things you talk about too. Stackoverflow has tons of answers on just about any possible coding problem. But now I ran into another problem, _delay_ms() only takes compile time constants as value! What da heck is up with that? I was thinking about making it possible to set strobe frequency at run time but now I donāt know if that is even possible to do with just a few bytes.
That's the nature of standard _delay_ms(). I replaced it with my own approximate delay function, which fixes that problem and also saves a couple of bytes. See TheStar.c in the repo.
Thanks man! Saved 4 bytes too.
Edit: Your function seems a bit unstable, it doesnāt work properly.
Edit2: Could it be that it must have 16 bit integers as value because those seem to work properly? 8 bit doesnāt work?
Edit3: Forget what I wrote above, found a simple bug, will report back soon.
Iām using nearly the same function in pretty much all my firmwares, so Iād like to hear more about this bug.
Yes there seems to be a bug whan passing a uint8_t from eeprom as parameter. My strobe frequency is not stable to say the least. Any fix much welcome.
Edit: Itās this line: strobe_delay = eeprom_read_byte((const uint8_t *)(uint16_t)2);
Edit2: My strobe is on friggin shuffle mode!!!
Edit3: My 15hz strobe works ok for a few seconds and after that it freaks out. Slower faster and whatnot.
Edit4: Just a guess, when WDT kicks in after one second it mess things up for short delays.
Ok, itās not exactly a bug but hereās what I found. The _delay_loop function runs in software and doesnāt work reliably if you use a wdt. But I found out that _delay_ms runs on a hardware clock so I switched to that but it didnāt work anyway. So I was just about to throw in the towel when I realised that I donāt really need 1ms resolution so I tried with 5ms instead. And bloody he it worked. So now I can set the strobe frequency in run time. I also saved a few bytes in the process as I could get rid of the uint16_t too.
Strobe seems super stable running with the delay_5ms function.
Added ramping too and still got a few bytes left to play with so if you got any ideas. But in another thread there is a guy that wants to set his own modes and this got me thinking if anyone has written a firmware that is completely empty and you have to program the modes yourself? That would be a bit cool actually. If you want ie 65, 32, 100, 42 you can have it that way.
Was going out with the dog in the night and wanted something to play with so I made an almost empty firmware, only took a few minutes. Only got one mode full blast by default and then you would have to program all other modes by yourself. I tested it right now in the night and itās a bit tedious but you can have your own exact group as you wish. I set a limit on max six modes but can be increased easily if wanted.
This is very cool can you program the turbo step down on the fly like dr jones guppydrv also?
How do you program it when its in the light? would it work with a twisty? or is it very many very quick clicks that would make it hard to do in a twisty?
And can you reset the modes whenever you want later?
