Did you measure usable diameter or total diameter with the lens out of the light? If it has a 2mm rim and you measured the usable diameter then everything is correct, if not, well then they messed up the spec.
The original post says 50mm. I’m not sure why I thought 54.
Yes, it’s comparable to the 1503 which hasn’t yet hit gearbest to my knowledge. I like the looks of this one better though, if build quality is good it’d be a good alternative for people who favor slide zoom over twist style.
Edit for clarification: yes the 1405 throws further, no they’re not really comparable, the 1503 is comparable to it.
Too bad it is 1 x 26650 / 3 x AAA, not / 4 x AAA or / 3 x AA. Those would be much better for gifts.
It is 3 x AA, as someone said above, so it is very good for those who don’t want to use lithium ion batteries.
Recently I tried to find cheap 3xAA light (as you said, they are good for gifting to people when you don’t want to explain everything about li-ion cells and spend more on charger and battery), won’t believe how hard it is…
