LEDs came in today. Photo in the OP. Hopefully I will have some testing done this week-end.
Justin, I didn’t know until I was looking at it on the PCT the other day: this CXA3590 takes over 42V to reach its highest rated current draw! But, it starts at ~35V on the bottom end. That is a HUGE jump! If a person wanted to, they could use 10X 18650 or 26650 cells with a DD/FET driver (assuming the driver can handle up to ~42V input/output) to power one of these. I know that’s not what you’re doing with this light, but maybe the other CXA3590 could be powered this way?
I think this will be a monster flood light at 10k lumens.
Will you include a (hidden) self-destruct feature that makes the light short the battery pack and explode? Like a last ditch grenade.
idk about you with that panasonic but if I were you I would go with RC lipo packs for helicopter
Looking forward to your results
I just watched your second video…freakin’ awesome. I bet it was hot, you’ve got excellent build skills.
I just added that video to the OP. Testing is done guys.
45 volts @4.25 amps. Everything works!
Still a long ways to go before beam shots.
Epic.
We have lift of.
You definitely need to add a fan… my salad bowl light from your earlier build contest has similar drive levels (and a much bigger heatsink area). Without the fan, it will melt into a slag heap in short order. The speed of the fan on mine is temperature controlled via a temp sensor epoxied to the corner of the Bridgelux “chip”.
I have played with adding a remote drive level pot to those DC-DC converters. It does not work very well. At certain settings the output goes unstable.
Holy cow, how did I not see this for a week.
Drinking will do that to you.
Wow, just wow! Speechless I am.
Nice!!watching this with interest!
(+1 for a fan btw)
This will be sweet. Not just the aluminum construction but have never seen one of those emitters in action.
Your converter looked oddly familiar... and it's the exact same kind that I've been abusing in a flooder project. Just IMO it felt easier to adjust using only the current limit pot by having the open circuit voltage set a few volts higher than necessary, and never touching the voltage trim again. This would of course be risky if you were to use an outside knob to later adjust the current during operation. In theory the voltage adjustment trim(that would not need access from the outside) is perfect to set the upper limit after the maximum usable current has been determined... but I don't know how reliable that is during power up if the current happens to be set too high(afraid of momentary overload and catastrophic failure).
Keeping the input voltage close to the output must be good for efficiency, but might limit your EDC's moonlight mode possibilities. Won't the emitter dimly light up in direct drive with that pack, so shouldn't the boost converter just "fall out of regulation" at some point making a lower limit? Haven't really tried that either(I'm working with lower input voltage). Looking at your video it seems you might have found out, but I failed to notice in case it was there.
Pure awesome. Looking forward to the end result.
The voltage will be adjusted and set. There will only be access to trim the amperage. There will be no moonlight mode. Bright as hell and then a little less bright, but still bright as hell. Moonlight is for wusses who only have 5000 lumen or less lights.
Just playin. I don't really intend on modes at all, just a way to back off of full amperage. The on/off switch in line with the battery pack output, will completely shut off the light.
I am taking that advice. A fan is on the way and I will put it in. I don't think it will do a lot, since I really can't cut fins in the bottom of the heat sink, but it will be there 92mmx92mmx38mm deep and 48v.
Do you mean replacing or moving the pot with some wires? Would it have to do with the wire length, or was it the remote pot itself? I was assuming a mechanical connection to the original part.
Or do you mean instability in general when trying to adjust during operation? I had a similar problem in my COB floodlight(still not quite finished but prototype stage published) build occurring even at about 50-70 watts, but then again I was running at more than 100% voltage boost and the converter was a smaller underpowered one. It's probably not bad at all(the version that has two trim pots, most have only one), but it's just too small. The one I have now(identical to what OL is using) seems stable at least up to 100 watts even when stepping up from 12 volts.
Is there any way to add a block with some fins? On my build, even a small fan makes a huge difference. I'm cheating by using a CPU heatpipe tower cooler, but I think any finned solid heatsink part would help quite a bit. Of course your build has a huge heat capacity, so thermal-wise it will tolerate short runtimes at almost any output. Given the huge amount of metal everywhere, fins might also help even if not directly mounted on the... ... pill.
That's what I was assuming. Probably I'm just being paranoid. That professional grade array should be strong enough to take a lot of any possible momentary overload during power up.
Hey! I'm sure the generic "100 watt" China COB with 11k chinalumens will reach at least 5001 lumens when slightly overdriven!
I replaced the original (current) trim pot with an external one connected with some small shielded coaxial cable. When turing the pot there we places where the output went unstable and the LED started flickering and the inductors started squeeling. I think the circuit may not like being adjusted “on the fly”.
OL: I'm sorry if we're adding semi-OT to a project thread but this seems relevant. The external pot thing is something I would at least consider in a build like this and I'm assuming you might. Unless you're set on mechanically extending the original current pot.
My converter was happy being adjusted on the fly, powered up. To me, that sounds like a faulty trim pot. Like when an audio amplifier makes static when you're adjusting volume or gain, and most often it's at the same spot(s) every time. In other words, the pot resistance itself is non-linear at that point because the resistive material is worn out or the contact is bad to begin with. Inductor squealing was noticable when the little DX converter went unstable, but has not occurred with the "600 watt" unit.
