Yes, and by default you can toggle mode memory by entering config mode then turning it off between the second two blinks. Here’s a visual summary of the default interface:
STAR dual-switch is probably the best starting point. I haven’t attempted to make a dual-switch firmware, and I’m not aware of many which already exist. However, you’ll probably need to change a fair amount of the code to get the features you described.
If you don’t mind it resetting to the first mode each time, any e-switch firmware can be used on a dual-switch light. However, I doubt that’s desirable for what you described.
At first, I thought LEO meant “low earth orbit”.
It shouldn’t be too difficult to add “memory” to an e-switch firmware, should it?
I think the memory parts should be relatively easy; mostly just copy and paste some code from other projects. It’s the UI changes which pose more of a challenge. E-switches need considerably more UI code than clicky switches.
If I skip the Beacon part it should be easy. Just start with STAR Momentary, add the memory bit, and change long press to mean strobe instead of reverse mode
ToyKeeper wrote:
ImA4Wheelr wrote:Thank you ToyKeeper for hosting these shared FW’s.
I haven’t been keeping up with this area. Is there a place that has the UI’s and operating perimeters of the various FW’s and variations?
The closest thing is the repository index file, which is mostly intended for searching, not so much for reading. Beyond that, once you’ve found something compatible with your switch type and driver type, it’s mostly a matter of reading the text files included with the matching projects to figure out which ones sound best.
Thank you for that info. :)
Hey all,
Is there any way to program the generic micros that look the same as the Atiny13A? I have seen these on some drivers before, but not ever tried to program one.
A generic SOIC8 chip could be anything. Attiny13 is only one of many chips which look like that, and each one works differently. The details probably vary for each type of chip.
I’ve updated my firmware and selected;
Which should give me mode memory? Correct? But I still don’t seem to have it. I’m using a zener modded board could this be affecting it?
Also when I start again it gives me my lowest mode. Even in the second group it gives me my lowest of the first. It starts with the lowest of second group then after a second goes to lowest of first group then I can cycle through the modes on the second group like normal.
No, that only controls how that option gets configured. With CONFIG_STARS defined, you can enable mode memory by grounding pin 3. With it not defined, you can enable mode memory by pressing the switch a bunch of times and then turning it off between the second set of two blinks. Neither method turns it on by default.
If you want mode memory hardcoded as on, you’ll need to change some other part of the sources, or use tk-otc.c (which drops the config mode entirely in favor of hard-coding options, but provides more space to add features).
Yesterday I flashed my first driver (stacked 105C, 12x7135) with the S7 firmware, worked fine, very nice firmware. I used the ready to use .hex-file.
Today I wanted to try star_noinit. Therefore I had to create a hex file. I have to say I’m a total newbie to all of this flashing/coding stuff.
I have Atmel Studio 6.2 installed. Finally I’ve been able to get a hex file, but it’s 2685 bytes.
The way I did it was: file~~new>project-> GCC C ExecutableATtiny13A, then deleted that automatically created stuff, copied and pasted in the code,>projectproperties>toolchainOptimization(under AVR/GNU C Compiler)~~>optimize for size (Os), then build>build solution
I just installed AS6.2 without making any changes to whatever settings.
Help would be appreciated. Thanks.
The hex file size isn’t so important; it’s the size of what the hex file represents.
I have .hex files at 2893 bytes which still fit. When I run avr-size on it, it tells me how big the file actually is, and that limit can go up to 1024 bytes. I’m not sure where to get the avr-size data in Atmel Studio though.
Thank you very much, Toykeeper.
The version of Atmel AVR Studio 5 that works is 'as5installer-stable-5.1.208-full.exe' - the version you'll find if you get it through Atmel's site IS BROKEN AND WILL NOT INSTALL! Search for the exact filename above to get the one that works. This applies to firmwares where the authors have released the source code - so for instance, minimo (momentary switches), minidrv (clicky switches), and the older version of luxdrv. NLITE is supplied only as a pre-built ready to use hex file so the steps s…
The pictures are broken but I think you get the idea. Way back when I started programming these 13a's these instructions worked for me on 6.x.
Hey TK (or anyone else)
In blf-a6, how do I get the tactical strobe into the main loop? I see it is given 253 as a convenience code, but I can’t see anywhere that it’s actually used?
Can I just transplant the code I’ve used in STAR_OT?
//mode_idx254 is the Strobe Mode
if (modes[mode_idx]254) {
while (1) {
PWM_LVL = 255;
_delay_ms(50);
PWM_LVL=0;
_delay_ms(175);
Edit: Just gave it a try, all it takes is to put the convenience code into the normal mode order. easy as pie. Now i feel silly for flapping my lips before switching on my iron. :zipper_mouth_face:
Hi TK,
I decided to take your advice about using the FET + 7135 driver to get the super low mode I want with an XHP setup ( parts are on the way)
What I am wandering now is will I be able to tweak the Star_off_time code to get what I want out of that?
I see that there is a line of code there to enable a second PWM ( line 86)
//#define DUAL_PWM_START 8 // Above what output level should we switch from the alternate PWM output to both PWM outputs?
What else would I need to do to get this rolling with the dual?
Not sure what you and TK talked about, but that’s all that’s needed.
As it sits, and modes under pwm level 8 will use the 7135 channel only, and anything above 8 will use both the 7135 and the FET. (you’ll need to un-comment it [remove the // ])
Is that what you were asking?
^ I think 255 is FET only too with the "stock" code.
EDIT: Sorry, my above response is incorrect. I was thinking about Phase vs Fast. Phase being used for the first and highest modes.
To get it into the main loop, add “STROBE” or 253 to the main channel in one of the two mode groups, and make the other entries longer too. For example, adding it to the end of the second mode group:
#define NUM_MODES2 5
#define MODESNx2 0,0,79,255,STROBE
#define MODES1x2 20,200,255,0,0
#define MODES_PWM2 FAST,FAST,FAST,PHASE,PHASE
while (1) {
PWM_LVL = 255;
_delay_ms(50);
PWM_LVL=0;
_delay_ms(175);
I think that looks about right, but I haven’t tried it.
Hi TK,
I see that there is a line of code there to enable a second PWM ( line 86)<span class="pyg-c1">//#define DUAL_PWM_START 8 // Above what output level should we switch from the alternate PWM output to both PWM outputs?<br><br><br><span style="font-size: medium;">What else would I need to do to get this rolling with the dual?</span><br></span>
FWIW, I haven’t tried a single 7135 chip on a XHP or MT-G2 or other higher-voltage higher-output emitter. I’m not sure what to expect from it.
As for tweaking Star_off_time, any code can be modified to do pretty much anything. It depends on how much you’re willing to modify it.
By default, Star_off_time uses the same PWM level for both the FET and the 7135 simultaneously, unless the level is below the threshold you quoted above. In that case, it’ll use only the 7135 by itself. Tying the two together makes it simple, but it also means you have less control over each channel individually — it won’t let you ramp up the 7135 alone then turn on the FET only when needed; instead the 7135 and FET will both be active and have a fixed ratio of how much power each one contributes to the whole.
However, if you were going to have a lot of mode groups, the joint-PWM approach only needs to store one number instead of two, so it cuts the storage needs in half.
