I have one with a Ledil Mirella and a single XHP-70 that does some 5500 lumens. The extension tube went to a Solarforce M7, took a little modification but it all works well together.
So yeah, what I was thinking, an extension tube would allow for what, 4 18350’s? Maybe 3 18500’s? (Although I have yet to find an 18500 that will put out like the shorter 18350 Purple) Then it’s just a matter of determining the driver, right? I’ve tried 12V triple XHP-70’s on 3 18650’s and they can’t do the forward voltage. But 4 parallel XHP-35’s with 4 18350’s, run through a Zener modified FET driver, that could be interesting…. the problem as I see it is that 1A max current thing, wonder what they can REALLY take?
Would this maybe do 8000 lumens? Don’t know, but if I can remember all this I’ll probably give it a go.
Edit: Have some of the HI XHP-35 on the way, y’all don’t let me forget why I ordered these ok?
Edit II: Ok, so these fit the XP footprint which means a triple would be easy to do in the X6 with a Noctigon 32mm mcpcb. I have copper heat sinks for this, and the Ledil Cute-3 optics, so all I need is for the emitters to come in and we’ll see what these puppies can do! (backorder on the XHP35 HI til Aug 5, they’ll probably ship a day or two quicker, we’ll see.)
Edit III: Looks like, from some extrapolation of the data sheets, we should expect something in the 4400 lumen area with a Vf around 12.6. Not stupendously outstanding but not at all shabby either.
Because possibly 3500-4000 lumens with no deadly black X of death from a four die led? Possibly, no faceted or OP reflector needed? Possibly 12000 lumens out of a SRK with 3.45 sized die? Not having to mod the reflectors or centering rings? Not worth F------ with? Maybe not, but maybe it will be. Dale will let us know soon enough, LOL. I don't even bother any more till Dale is done with his thing.
After reading the specs on this chip it look doable. Do we have any electrical engineers out there that could design a 17mm board for this. A single cell XHP35 running 1800 lumens in a P60 dropin would give throw much closer to the XM-L led as apposed to the MT-G2 and still be more efficient than either. This would also be the same for any single cell light, keeping them still in the EDC realm. I mod a lot of lights but I tend to destroy many in the process. It’s too complex for my skills. Anyone want to take up the challenge as I believe this type of driver would also give practicability too 9v MT-G2’s, 12v XHP-50’s and 70’s. I believe high drain 18650’s and 26650’s could carry the loads.
As I understand it you wouldn’t even need high drain 18650s. Assuming 80% efficiency your looking at around 4-5A at the battery end.
I’m going to have a go at it. My step fathers an electronics engineer which helps a little but I’m still a little over my depth so time to learn a thing or two. I have a CNC router which I can prototype on.
I just received 4 of the XHP-35’s in my grubby little paws. They look awesome! Exactly like the XP-L HI but with a larger phosphor fooprint on the substrate. (Exactly used in loose terminology at first naked eye appearance)
I’ll get a couple of macro images and see how they look.
Boost drivers. We need boost drivers to run these from a single cell. Or even better, high-amp boost drivers to run several of these in parallel from a few cells in parallel.
Who is still active who knows how to design circuits?
I will be copying a Ti reference desgin with a couple of slight modifications. Creating a single mode driver with over 90% efficency using the chip I pointed out (in the original post Tex linked to) up to 30W boost off a single Li-ion with output up to ~13V seems very simple… I haven’t actually built anything yet (still waiting on parts) but implementing the modes and squeezing it onto a 17m board is going to be the hard bit. I’ll post up a couple of schematics for the electrical engineers out there to review before I start prototyping.
If it has a microcontroller and a PWM-capable switching chip like the usual FET or 7135, the modes and such should be easy. If it doesn’t have those though, it’ll probably end up being very limited.
Glad to see two on board now. I’m a bit old fashion, but picture a P60 dropin running 15 watts and putting out 1800 Lumen. Right now it takes that much for an XM-L2 to do 1250-1300? It’s just so much more efficient even with only 90% boost efficiency. We also have new more heat bleeding designs/host. Don’t discount the possibilities; XHP-35,50,70’s and MT-G2 in EDC size lights. Picture for example the Convoy or Shadow host. Strange thought but it’s getting to the point where we can’t hot-rod the led past specs as much cause we can’t bleed out the heat fast enough. It’s looking like we are getting to the point of small size, good run time, and a ton of light without too much compromise. I’m not an engineer but I would encourage all of you out there that are to give this boost design some of you time.
