Here’s my 80 year old. It’s an early zoomie; well sort of; the screw in back adjusts the focus more than switching from flood to zoom. The bulb on top is solid glass- yes I said solid. I included a pic with it burning but since it’s made of unobtanium I never turn it on and then with only weak batteries. 2D cells power it. The switch on back goes L-R solid, off, front. No hint of who made it to be found. I’ve seen similar shaped lights but none exactly match the shape and details. Printed on back is “Krause Corner Drug Store” in Carlisle Ohio. If anyone is near there maybe you can see if any old folks remember the place.
I was just asking one of our well renowned flashlight fixer upers earlier, if he could maybe fix my grandpas old light as it quit working about 12 years ago. I think it may be in the switch or the weird looking filament/bulb in it where the problem lies, but I don’t know. The light is at least 60 years old as I am 52 and my dad said he used it long before I came along. It is a “Big Beam” brand and was made in Chicago Illinois. I do know it had a great beam and a lot of brightness to it for an old flashlight though, like the Q-beam of the day back then. The head even swivels so you can sit the light down and point it from straight up to about 25 degrees down past level. This is exactly like mine but not the actual light.
I can’t see the switch in your pic, but most of these had simple “slide” switches which are still made in numerous sizes, so you could find a replacement. Matching the original rivets would be the tough part. You could probably disassemble both switches (new and old) and replace the internal parts as needed. Slide switches usually fail from the sliding “U” losing it’s springiness or from the tuny spring above it failing. For a display model simply squeezing that “U” tighter and stretching the spring (if so equipped) will restore operation. You may be able to access that without removal of the whole switch from the bottom, thus saving the original rivets.
The bulb is probably a “Sealed Beam” and those can still be had as well. This type of flashlight was the “Sky Ray King” of it’s day and other than the cost of batteries and it’s incan technology they can still acquit themselves well.
yes it is sealed beam…it has a clicky type switch (Push button) on the opposite side from pic, but also a number of wires here there and all from one component to the other.
Clicky-switches can still be had too. If you can get a few pics of that switch we might find one. There were not a lot of different clicky-switches made back then, and I’ve fixed a few old lights in my youth with ones scrounged from vacuum cleaners and desk lamps which were identical or close enough to fit. These don’t repair well (if at all) so a replacement would be needed to make it work.
It’s still a piece of history anyway, working or not. Whoever designed it put thought into it’s aesthetics knowing the dies for the stampings would be a significant investment and useless for anything else. Today’s plastic and CNC work pales in comparison; it’s cheap and easy now unlike in the past. 3D printing moreso.
To my eyes this is as much industrial artwork as it is a flashlight, and that is a large part of why I love old flashlights so much :bigsmile:
We watched some of the Thin Man movies over the weekend and was wondering what kind of flashlights he was using. It was hard to tell, but these look pretty close if they weren’t the same.
http://imgur.com/xIADNIa
I have this lamp with an aspheric lens that my father bought some years ago. He didn’t use it much and it rotted across from leaking batteries. the lens is chipped at the edge and scratched but I was wondering should I try to build a lamp with it. The lamp was a cheap one back then so I dont want to restore it, it’s too far gone in any event.
Based on the online flashlight museum site, I think it is a
“baby Comet” with a Walleye lens. It takes two ‘C’ cells.
Paid $40. They are circa ~1913-1914
Picked it up today at an antique show. Almost in pristine condition.
I hope I’m in as good shape when I’m 103-104 years old.
Nice! that’s a beauty I have quite a few more vintage flashlights added in my collection, i just have not had time yet to do photos of them all to add here. (hopefully soon.
As I know you , you will never destroy a part of the flash lights history !!!..An easy cleaning , just to get rid of some rust and not let it spread .., and these two BEAUTIES will be the queens of your collection , no doubt..!
Modify them is like you've found an wild rose wood armoire , from 19-th century and you want to paint it with chark paint , to make it look old !!!!
