I want one.
I like the potential, AA’s Eneloops for me. I also like that they kept the head smaller at 60mm’s. At 10 ounces it does look like very little heat sinking though.
I like it; looks neat.
I like this, but just bought a Sunwayman D80a, admittedly for a bargain price. 8 AA cells is not an issue, it takes seconds to remove them, and stick ’em on chargers, and then refill the light afterwards. The absence of a battery holder is good. I guess this will be ~£120 in Blighty.
Hmmm I like that!
I have been an 8xAA user for some time too, then went to prefer 4xAA lights for the ease of charging in one round, but I have an idea: without resorting to an 8 cell charger (expensive and bulky) would it be possibile to make 2xAA in-parallel adapters to stuff 2 cella in each channel of a smart charger such as an i4 or similar?
I suspect that is how some chargers work, when they charge batteries in pairs. The disadvantage is that the charging is not optimal for each cell, especially if they are at very different charge levels when inserted. You can buy a decent 4 cell independent charger quite cheaply, in the UK 7DayShop do them.
In all seriousness, wouldn't it just be simpler and cheaper to buy another 8-pack of eneloops? Then you don't need to be in a hurry to charge them all at once.
You can never have too many eneloops!
marketing is a beach …
nitecore promotes a quad die
and banggood writes 4 emitters
(tough it is not totally wrong…)
for that money you might as well buy 4 A6 and strap them together
i am sure that we don’t have to pay the MAP
8xAAs is just too much to handle. I will never recommend my clients to get one.
why not? It’s throwy, long runtimes, big enough to use as a club and has a new emitter. It’s because of the 8 batts? Just get one of those nitecorn 8 bay chargers and your’re set.
I understand flashlight with Ni-MH is great combination, especially for long period in-vehicle storage due to its low self-discharge property. For emergency or general vehicle light, I would prefer something more floody than thrower. I have enough chargers for at least twenty 18650, but that does not mean that I will enjoy the charging process, carrying boxes of batteries and constantly figuring out which batteries are fully charge later. Moreover, quality Eneloop batteries are as expensive as 18650 in my country.
Sadly, this reminds me that I will need to buy Ni-MH to replace my aging Eneloop for my 4x camera speedites by the end of the year.
They say you should never leave LiIon batteries charging unattended. Well I’m damned if I’m going to spend my life watching batteries charge. NiMH can be left alone quite safely, and I can happily keep the charger indoors, in my server cupboard without fear that my house will burn down. 8xAA is fine. The only issue is the weight, a torch + 8AA is not light, no pun intended. But it is manageable for general use.
In my car I have…
… and now side by side with its predecessor…
The D80A with the predecessor of the EA4
For charging eight Eneloops AA… No problemo for me… I have several NC-MDR02NU.
If we can get a good price… I want one.
P.D.: in my country are hard to find Eneloop…
There is always exceptions. SWM's design looks way more sexier.
In Europe you can get legitimate loops from the bay pretty cheap.
Fujitsu LSD and Duracell Duralock 2450mAh cells are the high capacity Eneloops, but be careful as some Duracells are Chinese, as are some Eneloops!
Antiparanoico: since you too own a D80a, what is the low brightness level on yours like? Do you reckon it is about 30 lumens as claimed or more?
Looks impressive, however, not sure that I would need one because I already own EA8, which I rarely use simply because I rarely need flashlights :D!
