- The Fake-Cree LED Awareness Thread - The new "low" in Budget lights.
Paste this into the Search box:
how difficult to reflow
(the search navigation changes to look like this):
http://budgetlightforum.com/search?q_as=how%20difficult%20to%20reflow
(don’t worry about the %20 — that’s just copying out of the navigation window, it’s what Search does with spaces in the plain text you paste in
That will get you answers.
Remember you can also change result view from ‘relevant’ to ‘date’ to see newest first
Hank: Thanks.
I will give up the reflow idea. Maybe just some LEDs already mounted on stars.
Aside from LED, another issue is the driver. I checked a few of my SK-68 collection. I found the current varies widely. The best one I have, an old (likely genuine) SK-68, takes about 2A current from a Enerlop AA battery. All others takes less than 1.6A. It looks like the light emitted is proportional to the current. (It is obvious I guess for the same LED.) Do you or anyone else have any suggestions for the driver circuits with good output current?
Thanks.
Some of the (fake) SK68s do not have slots to take them apart. The one you pointed out here SK68 Emitter swap BOGUS looks like it. However, I was not able to disassemble it.
Has anyone spotted any counterfeit/Latticebright XP-G emitters in the wild? I recently purchased a 5-pack of “XP-G” emitters for a remarkably low price from one of the big overseas sellers. On installing three of them in a triple host, I found that the output was very poor, and with a horrible green tint. I immediately pulled and discarded the three I had just installed, then reflowed other emitters onto the same boards.
I’ve got a couple of the nasty emitters left, but I only have a single known-genuine XP-G emitter to compare against (from an old Manafont-purchased Ultrafire single-mode P60 dropin). Superficially, they look very much the same…
I have the same exact light. I had to pry out the driver first and then push the mcpcb out from the back. I had to give it some pretty good taps around the sides with a small punch. Eventually i was able to work it out that way.
sadly that’s going to become the painful reality now even with buying bare and flowed emitters from overseas sellers, is that most of them may end up being these crap, low-output, horrible tint Latticebright style knock-off garbage leds.
Do you need to unscrew the aluminum cylinder that surrounds them first?
Also anybody know what is HT-PE marked on the LED star? (Edit: I found it from some previous post. It is a fake Cree XP-E. :frowning: )
Another fake cree XP-E
Appears to have that hole in the corner other fakes have but this one keeps the phosphor only on the die.
Why I will never buy from TMART again post# 6
Yes. Unscrew the aluminum housing from the outer aluminum case. I used my leatherman to poke into the aluminum to get it started. Note: VERY BAD IDEA!!! Snap! Goes the tip to my beloved cutting tool. :frowning:
Maybe you could use some snap ring pliers to push out in both directions to get a grip on the aluminum cylinder? Or something like that
Which leatherman?
I couldn’t find where, but I think somebody suggested to drill two holes on both side of the aluminum housing first the unscrew it using snap ring pliers or the tool for openning watch’s back plate.
The Wave
Latticebright XP-E clone:
Unfortunately, I don’t have a known-good XP-E on hand to post the comparison shots.
The leatherman was a gift and it was engraved with my name. I just heard that I still may be able to send it in for repair under a 25 year warrenty. I’ll look into it
Their warranty is suppose to be really good. :bigsmile: Though I would only expect one free shot with sometime like a broken knife point that is usually from improper use.
I ordered 20 CREE XML RGBW “Warm” White LEDS from TopLightLED.com for $5 a piece. They were titled warm but they have the same specks as the neutral white. They came from China and arrived in 4 Days!!! I hope they are real? They look legit, but if someone knows how to spot the fake, please let me know.
its difficult to say with those RGBW emitters you have there, until we can see the LB fakes up close to compare then to a genuine Cree version.
BIG MISTAKE!!!
It’s TopLEDLight.com not TopLightLED
OOps
What about these? They are off a SRK 10 emitter light.
The bubbly base as well as the circle hole rather than square hole suggest that they are genuine. Now, I don’t really know what I’m talking about. This is just repeating what I read earlier in this thread.
