Yup. Simon rocks! I used the “code” a little over an hour ago. I put the blue S2+ in my cart, went to checkout screen and added my note. Several minutes went by then I got an email from Aliexpress that my order price had been adjusted.
My order was:
$16.95 - Blue S2+
$0.18 - 7135*4 option
$1.40 - XML2 T6-4C option
Original Total: $18.53
Adjusted Total: $15.75 for one customized blue S2+ :bigsmile:
Aliexpress has it’s limits but Simon works around them to give us great deals.
Oh and Halo you were spot-on about the anodizing. Simon said that when they did HAIII on the blue it made the head and body different colors. Still, however he did the anodizing it’s held up perfectly on the red S2+ that my wife has and that’s been bouncing around in her purse for a few months.
I don’t know it…… A little before of this post, i buyed some convoy (blue, red, 18350, and S2)… I send a message greetings Simon, and I said that i´m a member of BLF, but i realized the payment immediately. He may have some small detail with me.
I placed my order about an hour ago too and I added a message for BLF, but my order has not been adjusted yet. I figured it was normal for him to take time to adjust it, but since you said it happened in a few minutes, it makes me wonder…
I ordered 2 days ago, but there’s still an option to cancel the order on my Ali account. I left Simon a message asking whether he can adjust or if I should cancel and reorder.
Thanks! Please let us know if it works.
I’ll still be happy even if I don’t get a discount. I’ve never been disappointed with Convoy lights. Improvable? Yes. Let down? No way!
Unfortunately the time difference is a factor here. I just happened to place my order while he was still online, probably just before he wrapped up for the night. There are sometimes delays of near a day but he always comes though. Simon has to sleep too.
Yeah sorry buddy. I didn’t even think about it when I made the OP so I had to ask him and wait for his response. You can always send him a message and ask if he can do anything.
Interesting. I didn’t realize the switch wasn’t waterproof. I took mine apart just now though, and verified that it’s not. It appears to be at least slightly water-resistant though.
And now that it’s apart, I can fix the spring that I nearly melted with too much current. Add a bypass. I really should have done this when I built the thing initially.
In any case, I’ll probably wait until RMM has the blue host in stock. I want one, but I haven’t figured out what to do with it yet. With so many lights, it’s getting really hard to find a purpose for any new ones.
It’d also be really nice to have a triple spacer sized for the S2+ instead of having to find old S2 pills to swap in. I build almost everything as a triple now, since the beam and output are so much nicer.
Correct. That’s what Simon told me. The silcone switch cover is the waterproofing for the switch. The stainless while still tight and beautiful to look at IMHO is not waterproof. Water resistant maybe but that’s where it stops. Beauty always comes at a cost…
The CNQG brass light managed to stay waterproof with a metal switch, and it’s really compact, but it used a totally different method. I’ve never seen it used elsewhere in any way which actually worked. It’s basically a metal cover for a rubber boot.
But it also has threads on the inside so water can leak through the spiral gap. The CNQG brass lights have threads on the outside, and pressure holding the boot against the inside wall, so this isn’t an issue.
The BLF Ti could probably be made waterproof by adding teflon tape inside, but this might interfere with getting power through the body.
In any case, the S2+ metal switch isn’t waterproof. But I like it enough that my red one is one of my favorite lights anyway. I don’t have the head waterproofed either; it has an optic directly pressed to the metal with no o-ring or glass. I’d add those, but the triple spacer I’m using doesn’t leave room.
