Hi Tom E. Sorry for confuse you that my modified codes are for an external LM45 sensor connecting to PB3. I thought that the thermal couple between the LED and the sensor is very critical in actual application. General speaking, the MCU is remote from the LED so I prefer to employ an external sensor.
Hi ImA4Wheelr. Thanks for your advice. The high fuse should be 0xDF (SPI enabled). My modified codes have not been tested with a driver yet.
Ahh, ok. I'm thinking you'd get more reliable results with an external sensor, so all's good.
T_K - please think out loud . Interesting - didn't know the Meteor was using the 85 and it's internal temp sensor. I didn't get one, and hadn't been keeping up on the threads. It sounds like if it's set up properly, it can be practical. To me, the Meteor is nothing that unusual, except for it's small size. What Richard is doin with a M6 is more interesting to me. Haven't seen/heard much in details, accept it has 4 FET's - wondering if he is stacking them/running in parallel. I didn't realize parallel FET's would be necessary because the better FET's are rated to 50-100 amps.
Great conversation going on in here tonight. TK and Tom E, one seriously talented duo.
Tom E wrote:
. . . I know real estate on the 15 and 17 mm FET+1 drivers is really tight now, so an expanded footprint for a 45 or 85 might be impossible, but for the 25, it's a true drop-in replacement for the S8S1 package, and looks like you can find the 25's at a reasonable price. . . .
Another option is to just bend the legs in on a 8S2 (SU) chip. I find the best approach is to lightly push the legs on the inward arch (towards bottom of each leg) until the leg just touches the silicon chip. Is springs back just a hair and fits the SSU footprint nicely. It's easy and only takes a couple seconds to do. I imagine we will occasionally get a broken leg, but I haven't yet so far. The picture below is a bad angle. I'll try to get a better angle next time.
Here are some better angles. First pic is comparison to an Attiny13a SSU for scale. Attiny45 SU on top. Second is a profile view. The progamming clip fits and holds much better after the pins are bent.
Used your FW for a bit tonight Tom E. Only got to use it while it was connected to the PS because I had some kind of short when I assembled the light. The little I did use it, it was very sweet. The momentary switch was flawless. That strobe is wicked by the way. I couldn't really simulate a clickie switch with my set up, but the little I did, it worked fine. I like the way you have it set up with memory on the clickie switch and all.
I didn't test turbo time out. LVP seemed to be working fine, but I just did a quick check using the PS.
Can't wait to get the short fixed so I can put it through more paces and take the light into the wild.
EDIT: Driver was a HX-1175b1 modded for 9 amps out to an MT-G2 using 4S cells. Alt PWM output was disabled and 2 Modes were added for a total of 7 modes.
It's hard to find - I haven't seen one, else I would have ordered it. Might be available in a better quality, higher price light, dunno. This is the best deal around for the X6R at $22.80: aliexpress.com Eagle-Eye-X6R, little higher at $24 from BG with the discount code: bbbc2c. I think you, or anyone, will love this light modded. It's a real nice quality host - think it was first going for close to $40, but definitely worth $30 easy.
I got several lights with both switch's, but the smallest is the X6R. The UranusFire C810 is actually real nice (but big), the SingFire 327 is also nice (big), then there's the Warsun X60 (and rebrands) and the Y3 of course.
Your other choice would be an e-switch with a real nice tail lockout - they are excellent for the twisty method. I really like the Roche AS31 - little smaller than a L4 but still bezel is C8 size, but smallest C8 size reflector light around, and no tail switch but nice twisty lockout. I've had good luck with many ZY-T11 clones, ~$10, but the tail thread anodizing is not quality, so you don't get a clean, solid OFF on twisting, and I think with use, it will get worse and worse. There's also the lottery effect - some are better than others, even in the same order of qty 2-3.
Small dual-switch? Ultrafire C20 aka Crelant 7G3CS. There is a very positive and helpful review on BLF. I’ve been wanting one for months and I just Tuesday ordered one on AliExpress for $20 flat.
Thanks! Both the EE X6R and UF-C20 look like good hosts for this. The X6R has a bonus of built-in indicator lights (though I don’t think there will be any spare pins to drive them), while the C20 is smaller and uses e-switch wires, and specs of its innards are published in JackCY’s review.
Edit: I can’t tell what size the EE X6R driver is; looks like 20mm. I think it might have the switch onboard though, with a custom-fit driver, so it might need a smaller driver piggybacked onto it like how this Convoy L4 mod did it.
If I understand correctly, I think the pins will be…
reset
1
8
VCC
OTC
2
7
Voltage ADC
e-switch
3
6
PWM 1 (FET)
GND
4
5
PWM 2 (7135)
(I think pins 2 and 3 can be swapped, but both will be needed)
So, no room for indicator lights. But plenty of code space for extra modes and options.
^ If you're talking about Tom E's latest, Pin 2 is momentary switch and Pin 3 is unused. At least that is what I assumed and did. Didn't look at the code. Now I need to check. Checked.
The C20 is a bit of an odd setup with that driver spring design/setup, and the driver is 19 mm in diameter according to Jack's specs. Check out that review carefully. Of course that was all pre-OSHPark drivers . It is nice to have both switch's though in a 18650 tube EDC and with a separate switch mount, not driver mounted. But it's length of 135 mm is a bit big. If a conventional driver mounted spring can be used, and you can get a good ground connection for the driver, it would be nice. For $20 it's a good deal.
But to use this host for testing, it's not ideal - I'd much rather have a retaining ring on the driver and enough space to fit long wires, so I can easily re-flash the driver without soldering. A bigger host would be better I'd think.
Where'd you find this for $20 on AliExpress? Cheapest I found is the Crelant one for $24.
Check out my X6R mod details in post #78 here: https://budgetlightforum.com/t/-/33113. It's a fwd clicky tail switch and is now running my e-switch/NOINIT combo on a 25.
Hmm… The C20 has a weird nylon retainer / spring setup, while both the X6R and L4 look like they’ll need the driver piggybacked. None seem ideal. But all I really need for development is a simple tube light head and some extruded parts set up for easy access. The host is more for testing real-world use later in the process.
What would be really cool is a Roche F6 with a switch in the tail instead of a glass breaker. Of course, that also would require a special driver due to the way the switch is handled… like, a derivative of Helios’ driver.
pilotdog68, I think the attiny13a might be able to handle a dual-PWM ramping firmware with the ability to use a tail switch for momentary tactical purposes. No mode groups, but you’d have quick access to virtually every possible level. Would this work? (I’ve been meaning to make one of those, but don’t yet have a FET+1 with an e-switch)
Ahh, missed that... Could be the Crelant 2015 version has some internal design changes, maybe. Jack's review was back in 2013. I'm thinking though they only changed the LED to XM-L2.
Ramping isn’t my thing personally, but I’ll be very interested in whatever you come up with. The more options we have for dual-switch lights the better.
I’m just worried all the cool kids are going to move on to the big mcu’s and I’ll be sitting here in the dirt with my 13’s :bigsmile:
I ordered the one that said 2015 version because it looked like the side button didn’t stick out an obnoxious amount (like some others did).
Even from Store.Crelant.com the price is only ~$25, so I’m not sure if they’re “fake” crelants or not. I’m just hoping the quality is as good as Jack’s sample was. They shipped e-packet, so hopefully it will come quickly. If been saving my Nichia 219c for it.
Oh, I totally missed that. It looks like all the hard parts (figuring out what to do) are done! I should probably go for the X6R as a host instead.
The X6R definitely looks like a nicer host overall… and having the switch built in to the piggyback setup would make testing easier. Plus having the charge circuit and indicator LEDs continue working after the mod is an unexpected bonus.
I feel like a fish, flip-flopping around so much today.
