Nichia 219C, testing a 5000K 83CRI emitter, comparing with a XP-G2 S4 2B and other leds
Yes they are
We do a lot of spectral testing here for customers, as a comparative point. When you test with and without a secondary optic you can get up to 300Kelvin shift, the logic would say a dome on a led is a primary optic so the same shifts should be expected
Djozz, they are the same dome style as a 219B, correct? Very similar? I have dedomed a few 219Bs, they can fool you. Nichia has a clear-coat layer ON the phosphor. It’s perfect after the de-dome, to explain what I mean, the die looks like one of these CREEs after a de-dome (picture below), making you believe there’s extra material stuck on because it’s glossy—I found it to be filled with phosphor. You do not want to remove the glossy layer after the dome, then.
I use a 2-step de-dome procedure now that is a chemical de-dome in about 4 hours, I did a time-lapse video showing the dome detach right around 4-5 hours if done with a fast solvent followed by a slow solvent because of varying plastic types in the dome. I first attack the base glue, then swell the dome until it pops by itself. No slitting, I do not touch the dome.
MEM, in your opinion should the CRI be unaffected by dedoming or slicing as long as we don’t remove that layer you described?
Sorry, I had completely missed where you had asked about CRI measurement before I last posted. I have a tendency to catch the start/end of threads when I’m in a hurry to read. I need BLF-subscribed posts on a 24/7 audio translated PA stream that I can listen to as they come in over horn speakers throughout my home and shop. :bigsmile:
OK, to explain this, you must first understand how difficult it can be for one to fully explain. Even the simple answer of a yes or no, it’s always dependent on a few different refractive properties, phosphor thickness, bonding, sealing layer contour, etc etc. IMO, I think a good de-dome is still going to change CCT noticeably enough. However if you read on…
We deal with two primary rating systems: CCT & CRI. We expect CCT to directly impact CRI-rating, in some reasonably predictable fashion. People go as far to assume this is an automatic change and the two are linked. We know CCT will change with a de-dome, and that means a CRI change. Well, technically that is not true. CRI is independent.
About the CRI, first of all. The latest “news flash” of high-lux LEDs that also have a “high CRI” rating is something we mostly have not been used to seeing or hearing about—especially when our focus gets affixed on CREE LEDs and their numbers. These trends tend to form opinions about CRI with some mistruths involved about de-doming. I would highly recommend that you read this webinar from OSRAM Opto, about the entire nature of CRI, and newer CRI rating types which exist (Ra, R9), that take things like color saturation into consideration, as well. This PDF will help many better understand how “CRI” is developed, what “CRI” actually is telling us, and also how effective the CRI rating system can and cannot be across the large scope of all available LED choices out there.
The PDF webinar is for download here: CRI Sources Explained
So even though intensity increases, and CCT will change, the same colors are technically still there in the LED. Those individual wavelength regions are further influenced by lens design, such as if the lens collimates all available colors at the same image projection without throwing some color away, due to aberration, for example.
I have a method I feel might possibly work. I have a 50”x50” fresnel lens in a frame, with a white wall near the back. The effect is interesting, because the fresnel seems to take on the full tint of the projection, and it is this displayed, like a TV channel. So I’ve wondered about the Adobe CIE color system combined with “RAW” photos. Let’s say I aim the camera so that the entire image is the fresnel lens lit by an LED projection, the photo should measure the tint, to some degree better than a human eye I would expect. This data can then be seen in Adobe. So I would setup, take a few baseline images, then de-dome, redo the test, and see what Adobe says the new CIE data is composed of. Seem or sound logical? I haven’t tried this yet, until I realized how well the entire surface took on the tint, even if hit by a 3x3” square of light, the entire lens still glows evenly. I could do some tests, but I haven’t thought this all the way through, so I don’t know if it truly is a good idea to start doing. I suppose it’s better than catching the pure hotspot alone in a photo and trying to analyze that—then other tints are involved (from small objects, wall reflections, etc) and would create erroneous (though possibly minute) extra color data.
I will try it, but must get some bezels turned out right now. Cerakote runs in the morning. Won’t be tonight.
:bigsmile:
I think I understood most of that. I’ll be interested in the results if you do decide to do some kind of test.
However, maybe I should just convince myself that slicing the 219c’s dome will actually improve the CRI, then live in blissful ignorance of the fact that I am probably wrong. It’s all in the head.
I can say this much. A solvent de-dome provides much cleaner and more repeatable de-domes (especially on hard to do emitters, apparently Nichia for those doing “hot” de-domes). CRI should not grow higher necessarily. CCT just drops in kelvin. This doesn’t expand the color range to include any more red, for example, or any more colors, just slightly changes their ratio. This is why I posted the PDF.
A LED dome is made to take on heat and stay bonded to the phosphor (to extent). It’s not made to resist solvent. Attack it at the weakest link in the chain. Only makes sense. A dome has enough buoyancy to “pop” after a swell, and lift itself right off with a very small swirl of the fluid if still attached anywhere. If you’re not having this happen, something isn’t right. Like I said, I never slit domes, that is to finish, or to provide a de-dome aid. The plastic is highly porous when in solvent, slits aren’t needed and will possibly negate from the desired “full dome” lift.
After a de-dome, untouched by tools/razer, a full dome lies at the glass bottom:
The 5000K 83CRI 219C that I butchered dedomed and used for last evenings Supfire S1 mod, as described in your DIY-trit-replacement thread, has tint shifted visibly, the current tint I estimate at (a beautiful :-) ) 4000K. And as with all higher CRI dedomes, the light quality has not decreased (but increasing CRI by dedoming sounds very doubtful). As pointed out above by MEM, the phosfor mix has not changed by the dedome, so that must still show.
That looks like the perfect way to dedome Nichias.
Would you be so kind and tell what kind of solvent you used?
Some kind of nail polish remover, acetone or simply gas?
Djozz, how’s the tint after the dedome? Have you had a chance to check it through both plain and coated lenses?
I have not seen it through a coated lens, and there's many types and quality of coated lenses around, so one would not tell much.
This dedome might not be typical: a thin mess of silicone leftover on the die, the sides with the white stuff cut away.
This will be a subjective description as I have no way to measure tint and CRI apart from estimation with my own (trained) eyes.
That said, I compared the light to a (newest version) Oslon Square 4000K 92CRI that I have in a flashlight with similar beam, and the colour temperatures are comparable (so ~4000K), the tint of the dedomed 219C is more a clean white, which looks more rosy compared to the Oslon which is slightly green, it reproduces all colours really well, just in the saturation of bright reds the Oslon is a bit better despite the greenish appearance of the tint (but as expected from its high CRI).
Please don’t take this the wrong way, but holy moly that’s an ugly dedome. It looks like chemical dedoming is going to be the way to go with these. That or slice and polish.
:smiley: I think it’s a pretty attractive, ugly dedome. Experimenting is the way we learn!
LOL, I agree on the ugly dedoming procedure and looks. I actually made a video of this dedome, the idea was to do the dedoming procedure entirely while the led was on the heatblock that I slided under my stereo microscope for good vision, the block temperature was just under solder melt temperature. It did not make the dome stick less wel to the die/substrate unfortunately. After what you see in the video I cut away the sides of the silicon and the white stuff.
So the idea did not work out, but this ugly dedomed led did the job anyway: noticable tint shift, improved throw, draws more than 5A from an Efest 16340, with 800 initial lumen OTF, that is close to 1000 ledlumen. I love the tint.
Thank you for all these dedome method attempts djozz! Great info.
As one that sees beauty in functionality, that latest one pictured above . . . oh, who am I trying to kid. It may not be pretty, but it's getting the job done and that is a truly redeeming value for me.
Would like to know what solvents MEM is using.
Dedoming increases the action of the phosphor, so it makes the tint warmer. That might increase the CRI.
The optics matters because the light re-emitted at longer wave length from the phosphor goes in all directions, so it comes out at wider angles than the blue band directly from the die. So zoomies have cooler spots than reflector lights do.
I have not been able to observe CRI. I don’t remember the color bin, but I have a neutral white Cree LED with about the same tint as my Nichia. Comparing the two shined on flowers and colored pens, I can’t see any difference. Using a camera and Gimp, would be more sensitive, but not necessarily meaningful because it would depend on the camera’s color response not on anyone’s eyes.
That’s where a GretagMacbeth Color Checker Chart would come into play. :wink:
I personally find the whole argument confusing. Different camera sensors pick up colors differently, the processor handles the colors differently, the screen shows colors differently, as do printers. Each and every person’s eyes are slightly different, like fingerprints. So if there truly is no standard, why do we get so hung up on it?
I go to great lengths to make sure wedding pictures are perfect. I have a Dell Pro monitor with a Adobe RGB gamut, I use a colorimeter to ensure the computer graphics card is handling the signals to the monitor correctly, I color process each and every picture to the best of my ability. Then the couple looks at their pictures on an iphone. Why do I bother?
To whit, where do we use flashlights that color is so important and how many of us actually have eyes that can tell the difference? What does it pay? ?
Striving for perfection, I know, and it’s a brutal mistress…
That sounds right to me.
Since there is usually a big dip between royal blue and green, some blue things should look like a wrong hue, but I haven’t found an example.
I am looking up GretagMacbeth Color Checker Chart.
If you strictly dismiss the idea that color data is important, and that because our eyes are different we shouldn’t pursue it further, then it could be extended to say that we also shouldn’t care about high-CRI LEDs, lens coatings, copper cooling, and new battery technologies.
Some put hard work into making wedding photos look the best they can using the CIE standards, others choose their own areas to apply the CIE standards. I can completely see ones side of the argument. Trust me, (over)complication can be a b!tch. But the very thing we as humans do, is learn to innovate, experiment, and pursue things many have said we couldn’t do—doing it in our own garages now. Now, this isn’t a “mission to the moon” speech by JFK to push a country towards inspiration (here goes MEM you are saying by now :slight_smile: ). The parallelism involved can be ironic at times though, and the lengths some of us go to, to get something right. Even if it is for the pure satisfaction of new accomplishment; I would rather learn how to innovate a design with purpose than turn my head with frustration.
We say “eyes” so many times, so often…his eyes, her eyes, my eyes. YES! The eyes are the answer. A very large amount of stuff we deal with is based on our eyes. Not a cat’s or dog’s, but human eyes. The film industry, your monitors, TVs, camera/video hardware, printers/scanners, dare I mention LEDs? :wink: As time moves forward, we approach a unification of standards, which is why we have standards like CIE, and tint binning to begin with. LEDs are one of the most important little devices to adhere to those standards, or not adhere at times. Our eyes can be different. From what I have found through use of lasers at far extremes of our vision spectrum and using simple questions/answers to describe what one sees, it amazes me how close our eyes really are, though. Monitors to cameras, yes they have variance which is well known. But even that iPhone screen is approaching the same standards, and one day such devices will nearly all duplicate one another in look. (Laser television, anyone? It is coming.)
We talk about it all just as much. Saying how one likes this tint or that tint, a high-CRI version of this or that LED. I’m simply suggesting we figure out that we know what we are doing when we do it. With color/tint/CRI and general wavelength knowledge, comes other knowledge to improve other things. I.E., Focus, de-doming, and intensity itself—the big one.
I would like to do a write-up on the forum in the near future to help some understand why lenses can work far better than reflectors in many situations, and how they can influence performance in combination with other optic types. Even though some shrug at the idea of lenses, the LED is a directional light source. It is not omni directional. Lenses are best used with directional light sources. Notice how the industry is shifting with this idea as time moves forward.
I’ll get to a better point for this CRI thing.
My idea with RAW data is this. A JPEG is worthless as far as maintaining data consistency, we know that much—it’s a compressed file format. Compressed file formats are blended, encoded, processed, and spit out as a representation that’s “sufficient” for use, while intended primarily for saving memory space. If I think to myself, “What is the best way I can capture and know the actual colors that are emitted?” The answer to that would be by use of a reference spectrometer. I stated before in another thread that when I had looked into a tested unit with a high wavelength-sensor count spanning the entire visible region, it was roughly $8,500USD, and then some. I put a tack in that idea. :slight_smile: Though, it sure would not hurt for a forum like this to have someone with access to one. That information could be very valuable. Anyways. That is probably not going to happen. So I thought about what I had mentioned using a very big fresnel lens. Sensors and cameras do vary, but the high-end stuff has less variance, and is why such things like RAW output is common on higher grade camera types. They can reproduce a standard within a fairly accurate measurement range. A camera sensor is the most accurate sensor type to likely be found in your own homes. Since they too are based on CIE standards, that flow right into photo programs based on the same standards, it started to make sense. There is likely a combination of parts found in some of our homes which can be used to identify color/tint/CRI. If a baseline is found, as usual, comparison can begin to be made. What is ironic about this, is that we are dismissing Nikon/Canon/Sony image sensors in front of us, and ordering lux meters from China with $1 sensors inside them to obtain measurement, that is supposed to be based on a CIE standard. :wink: Now you can start to see why I am trying to convey a message here.
I am going to try developing a strategy to do this properly with more time. I know that a good chunk of obtaining the correct data is not exceeding the sensor’s range. If image intensity is in the correct region, the sensors can compute more accurately. It may involve a filter, or more. But the net result of a setup might just prove to be more useful than previously thought, since intensity itself as measured is driven by CIE spectrum.
I recently witnessed how much impact an aspheric-achromat had on tint, it is simply amazing. Coated lens #1 asphere has lower tint, because it appears to focus best where it ends up satisfying the eye for intensity and sharpness, while some blue is lost from the projection (we typically see this as a blue-purple halo or outline around the LED image projection which is lost light out of collimation [aberration]). Coated lens #2 aspheric-achromat makes the same image, without throwing out so much blue, no blue halo, and a whiter, higher-K projection is made from the same LED at the same distance from the LED. I do know why this is happening, it is simply focal-length span between red and blue being greatly reduced in an achromat—it is just that I finally obtained an 85mm aspheric-achromat to do it with. Contrast of projection grows greatly, too. More rays of light stay in the same image, meaning intensity of that image is greater and packed with more photons available from the source. More lumens come back that get lost in a de-dome+basic asphere lens configuration due to the aberration losses.
I’ll come back and talk about the de-domes, too. One asked what solvent I’m using, and I have to dig up the MSDS to be sure about one part of it at least. The other part, simple, you must buy it at stations located everywhere. :slight_smile: I’m going to run another Nichia through, setup in a time-lapse macro arrangement for a video like I’ve been doing. I had a good one of an XM-L2 I just did, and I deleted it because the thumbnail was gray while I was making drive space, and usually the gray ones are blips where I activated the IP camera briefly to generate a new video. In this case it was the entire video. Doh.
Anybody get/use one of Cutter’s 4000K 83CRI D280 219C’s on a 20mm notigon yet (here?) Curious if it’s really a D280 like Djozz’s 5000K one was. Seems like a good deal if shipping doesn’t kill ya.
