The first decent dedome of a 219C.
Looks kinda similar to Djozz dedome
Is this with MEM’s method?
I wonder if the uneven surface will cause artifacts? maybe some 1500grit is in order
Maybe a close shave and polish might be a better option?
Ok, I’ll order some when I can afford it.
Here’s a beamshot comparing the dedomed Nichia NVSW219C @ 5.7A vs a dedomed XP-G2 S4 2B running direct drive. Both are focused for highest lux in 1504’s. I got a reading of 326kcd from the dedomed Nichia vs 463kcd for the XP-G2. The colors are fairly accurate. The Nichia is on the left.
It feels like there’s more to be had out of this LED, perhaps more dedoming attempts are due.
You have been busy! Nice work and comparison. The result looks suspiciously close to my sliced result of post #106: good tint shift but not the expected increase of die luminosity.
I'm not sure what's to blame. Could indeed be dedoming quality, but it may be caused by a difference between the Nichia and Cree phosfor recepies as well: the photon recycling causes a different spectrum that is more towards red and is thus measured lower. Or the Nichia phosfor mixture is saturated at a lower light intensity. What really happens in the different dies is easily beyond my expertise and may actually be extremely complicated
Let's hope it's just dedome quality and a succesful method pops up soon :-)
I’m starting to get the hang of what tools to use and how to get the dome off these. Only screwed up 2, and 2 good ones now. One thing I notice is that these are just really ugly in pictures compared to real life. You’ll be able to tell from the side profile picture that the top of the die is actually quite clean and flat, contrary to the head on picture which makes it look like there are chunks of silicone still on the die. Weird.
A better side on view showing how flat the surface is. Takes some precision razor work to slice the last stuck bits off.
I like the color of the one on the left. Is that the Nichia?
Yes it is. I’ll edit the post, I should have had that bit of info in there.
A Nichia NVSW219C on the board with an XP-G2 S4 2B next to it, both dedomed.
Excellent work djozz and Dale! I gotta get some of this. I know I'm late to the party, been seeing things, just didn't get the whole picture till I read through this.
I've been frustrated with the de-domed XP-G2's for a long time now - hope we can find a good solution with good results to de-dome these.
Dale?
I’m pretty sure Dale is DBcustom.
I put a stainless collar on the 1504 with the Nichia. With the collar it makes 383kcd. A 17.4% increase.
Tom got excited and missed that it was Henry doing the de-domes. lol
Y’all all know how easy it is on these forums to get discombobulated and post a comment slightly wrong, or a lot wrong, now don’t ya?
Tom, I haven’t done any testing to speak of on the Nichia other than wire 4 of to a harness and run em ragged.
It’s nice to know that the Nichia has a nice tint when dedomed. The one on the right has Dean Martin’s complection
Actually I thought I was staying with the tone of the thread, as earlier. You were the first to post results in a real light build/mod, so I thought, and went thru hoops to get the 219C early on. I know djozz, of course, did the incredible testing and presentation - again, phenomenal effort!
I ended up ordering a few from Cutter, because I saw other LED's of interest you don't find at MtnE or IOS: XM-L2 U4 1A and XM-L2 U2 3D. The AUS dollar prices are a bit scary, but once you see the PP transaction with the currency conversion to USD, not too bad, in AUS dollars (total US: $62.83). I should have gone over $100 AUS though (stupid me), to get the free shipping...
Name | Unit Price | Quantity | Total | |
Cree XML-2 Cool White U2 3D | 6.99 | 3 | 20.97 | |
Cree XML-2 Cool White U4 1A | 7.29 | 3 | 21.87 | |
Cutter-NVSL219C-20-E5 | 4.69 | 6 | 28.14 | |
Sub Total: | 70.98 | |||
Shipping: | 14.10 | |||
Handling: | 3.40 | |||
Grand Total: | 88.48 |
Ok, I just put one of these in a S2+ with FET+1 driver and I’m seeing 7,5A with 25Rs at 4,05V :bigsmile:
Actually, this is a little bit too much according to the chart in the OP.
Using a protected Keeppower 3400mAh cell (this is a non IMR cell) at 4,08V I get 4,85A.
Before I swapped the emitter it had a dedomed XP-L V6 3D in it, with this LED I was seeing around 4,8A with the 25R.
