Difference between Opus BT-C3400 & BT-C3100 v2.1?
Moose and squirrel, together again. :)
The squirrel is still taking over my life. I could not move the bludger from my signature the cheeky bugger.
I was wondering how the squirrel got into your signature for just one post. :evil:
Ran across this thread on a Google search and wondering if I might be able to use the BT-C3400 Charger Analyzer to test the mAh capacity of my cell phone’s Li-ion Batteries? Since cell batteries are of course square and will not load traditionally into the BT-C3400… my plan is to open the charger/analyzer and affix jumper leads to the /- terminal and then run/secure those leads to the/- terminals of my cell phone battery. Any thoughts on this would be greatly appreciated… also interested in any leads on any other chargers/mAh analyzers which may be more suitable for testing mAh capacity on cell phone batteries(?) Incidentally, I find it rather odd that someone has not designed a (economical) charger/analyzer to test all the square cell phone batteries on the market these days!?
I hope this thread covers your concern:
As to your next concern about a dedicated charger/analyzer for cellphone batteries, perhaps IMO, manufacturers are afraid it won’t be a commercial success for the sole reason that only few people buy extra batts for their phones.
Great info (thanks) already planned on gutting my universal fit mobile phone charger, now looks like the bigger challenge is finding a relatively inexpensive charger/analyzer that can be set to charge low enough for a accurate mAh reading re my Samsung 3.8v 2600 mAh li-io’s. There are a few bare bones li-ion charge analyzers on ebay (price is sweet) but the Asian/English instructions look a bit challenging and unfortunately most listings aren’t providing a min/max charge rate spec, nor are they confirming if their units display analyzed capacity in mAh or %(?) Anyone know the min charge rate I should be shooting for in a charge analyzer to get a good mAh read for mobile batts… 50-60-100ma? Anyone by chance ever seen a c/a on ebay that even comes close to such low charge/test currents? Should I just go with the BT-C3400 and call it a day?
btw… had no intentions of high jacking this thread. If need be I can copy, paste and repost in the other thread if need be(?)
A new thread with a more targeted title would attract more suggestions
From what I’ve read from several reviews. The Opus BT-C3100 V2.2 is exactly the same as the BT-C3400 V4.4.
The BT-C3400 is branded with a different model number for other marketing.
Currently on sale for the next 5 days, for $33.16 (US Plug) with free shipping.
http://www.gearbest.com/chargers/pp_173012.html?vip=85916
LCD Screen
Auto Circuit Detection
Built-in Protected Circuit
Over Voltage Protection
Short-Circuit Protection
Over-Charging Protection
Over-Discharging Protection
Operating Voltage 12V DC
Power Adapter Input: 100~240V~, 50/60Hz
Output: 12V DC, 3.0A
Charging Current range 200,300,500,700,1000,1500,2000
Discharging Current range 200,300,500,700,1000mA
Max. Charging Capacity 20000mAh
Operating Temperature 0 to 40 ℃
Voltage Deviation <0.04v
Current Deviation <5%
Just order the BT-C3100 V 2.2 with a Sky Ray 5 XML-U2, hopefully Expedited Shipping is worth it.
The BT-C3400 will charge 'C' batteries and the BT-C3100 will not.
Welcome to BLF,
Sorry this being your first post and all, but……
The charger has a standard 12V DC connector. You can just buy a 12V AC adapter with the desired line cord/plug as long as it can output at least 3 amps at 12V. Because of the issues on the V2.0, I actually use a 6 amp AC adapter, and that solves the problems that v2.1 fixed. The problem is that the charger basically uses PWM to charge, so during the charge cycle the peak current is a lot more than the average current, and the original 3 amp supply didn’t have enough output to provide the peak current required. A larger power supply solves that problem.
So, in your opinion, what is the real difference between the 3100 and the 3400 other than a number on the product?
Hmmm? OK, but do you have any specs from an operation manual to show that the 3100 works with 'C' batteries? All the specs I have read on the 3100 do not list 'C' batteries as being compatible, but they list 'C' batteries in the specs of the 3400 as being compatible.
Nevertheless, do you have a pic showing real capacity with mAh with the exact same batteries in the test mode?
I think the question here is that if the 3100 was apparently not designed to work with 'C' batteries but does appear to be working with 'C' batteries, is it really working properly with 'C' batteries?
I'd love to see a pic with those same exact 2000 mAh batteries showing the mAh real capacity in the test mode. This would be very convincing that the 3100 works properly with 'C' batteries even though it wasn't apparently designed to work with 'C' batteries.
By the way, have you been able to get it to test for mAh real capacity with 'D' batteries?
http://imgmgr.banggood.com/images/upload/2014/04/Powerfocus%20BT-C3100%20OPERATING%20INSTRUCTIONS.pdf
The only difference between the OPUS BT-C3100 v2.2 and the OPUS BT-C3400 is the model number.
The BT-C3400 was “badged” for a particular dealer.
I remember reading this quite a while back here.
THIS is the only difference between the BT-C3100 v2.1 & BT-C3100 v2.2 / BT-C3400
And, to advance this discussion to the reported v3.1, this is the difference:
This is a customer made model. We changed some function like voltage for termination is changed to voltage with load condition, and discharge termination voltage is changed to a higher level to prevent charger from triggering protection for cells with protection.
This is a customer tailor made model.
Hi,
BTW, the BT C3100 V2.2 price is showing as $31.39 now when you select ship from the US-LA warehouse to US.
Healthy Guy
I am guessing by your username that you are into eating right.
As you already know I’m sure, you can’t always believe what’s inside the package no matter what it says on the outside. :wink:
OK, I just had a little fun.
One legitimate concern could be that if one tries to charge a “C” or “D” cell that has too high of a capacity, the delta V voltage may be missed by the hardware. In order to detect the delta V, the recommended charging current for NiMH cells is approximately 1/2 C where C is the mAh capacity.
The OPUS will charge at a maximum of 2000 mA if only the 2 outer banks. Perhaps charging a 10,000 mAh “C” cell at 2000 mA is too low to enable the OPUS to detect the delta V point. I would assume there would be a secondary point of shutdown, perhaps as simple as a maximum measured voltage across the cell.
That’s a great price. If I hadn’t recently bought Lii-500, I would have jumped on this deal.
Good observation! Yes, I'm a health food nut, but usually people think that I'm an obese junk food junkie who loves big buffets. ;)
On another note, do you think the Opus BT-C3400 will give correct mAh results for NiMH 5000 mAh batteries in the test mode?
