yes!
un?protected?
which purpose?
high drain?
capacity needed?
yes!
un?protected?
which purpose?
high drain?
capacity needed?
Martin,
Any codes for 18650 Keeppower 3500mAh or NCR18650GA?
Thanks
my active 18650 Codes:
(due to rules only a list…)
nitecore IMR MAP
Olight 3600mAh –15%
LG INR 18650 MJ1 –15%
Sanyo NCR18650GA $7,64
NL189 18650 3400mAh, protected MAP
LG 18650HE2 2500 mAh 2pcs $9,35
Panasonic NCR18650BD 3200mAh 10A $7,99
Panasonic NCR18650B 3400 mAh $11,60
PM code and links for the Sanyo GA and Panny BD’s please
I was after something for the upcoming D80-SE, was hoping for the Samsung 30Q, but if not available the LG HE2 looks to have performed well.
i to get a good price for the 30Q again…
or comparable battery. Looking to buy 5 or more, depending on price. Thanks M4D M4X!
due to rules i pm you the code…
Olight S1
Ahhh I see what you mean now, please pm me for the 30q, cheers
also pls PM me for the 30Q. Thanks.
its on the list of requested lights Sb …
i post as soon as i get that code
I see the 30Q’s currently at GB for $8.99/pair, will BG beat that when they get stock?
they got 1000 yesterday
believe me - i am poking hard towards east
i got a sitewide Code (“only” 7%) but it works for nearly everything except flashdeals, 3D-Printer, Tablet-PC, Smartphones, Feature-Phones…
i share via PM
I vote for:
Skilhunt DS10/15/20
Nitecore MH20 NW
Please PM the price for the 30Q as well, thanks.
as soon as i get a good deal i publish here
I wait for a great 30Q deal.
But for two days I have my bank acount in red numbers
Crelant 7G10 Code: 8708e9 price: $ 83.08
from the member who requested the Code:
Have you ever seen the Crelant 7G10?
It has 3- FET’s and 1- 7135 in the driver, jump the 4 R056’s and it doubles the out put, 6-7 amps. I ordered some better FET’s and Im going to swap them out and see if it will produce more out put. This driver has a nice smooth ramping that you can set for a 2press mode. H/L or reverse L/H or just ramp up/down. I put a shaved XHP70 in the one I have now, and it’s the same as a stock SD75!
