How can you order these protected???
I can't even put these items in my Shopping Basket??
I would love to knw more specs of these protected batteries...
Size?
Flattop?
Size?
Flattop?
It works fine for me. There are instructions on the page, read.
Looking at the photos you can see the length. They are button tops, but the button are not at the same level with the rest of the battery length.
Nope, It does not work for me.
When I hit the 'add to cart' button I get this :
http://www.intl-outdoor.com/panasonic-ncr18650a-3100mah-liion-battery-p-213.html
I can't put these in my basket.
Works fine with al the other batteries, except for the 3100 mAh ???
I've tried again, and it works just fine. Could it be the browser? I'm using Firefox 7.
OK, no problem with Firefox.
Seems it does not work fine with Explorer!
Thanks Hikelite
Ordered 4 protected (blue). Couldn't resist the temptation to own 3100mAh 18650 batteries.
I guess I need to ask, if they really charge up to 3100mAh?
My memory says that some batteries need to be charged to 4.35V to reach max mAh..
It looks like in this case a 4.2V might be max...Full mAh..
or not?
or not?
There's info on the website saying, full charge 4.2v. That's correct.
We have discussed about it these days here, down from that post.
Well I thought I'd try a GOOD 18650 battery so I ordered a Redilast 2900 mah after reading some charts etc. I can squeeze an Ultrafire Blue with 2 pennies ( 2.86 mm ) into the little travel charger so if the Redilast is really 69 millimeters long it should barely fit, right ? EDIT - YES. Torch is no problem lots of room with the spring flex. Well- should be about a week till I see the Redilast - will a Cree Q5 pull more current from these in addition to 40% more runtime than an Ultrafir…
I think Hank owes me a free battery
Thanks!
Hikelite:I've tried again, and it works just fine. Could it be the browser? I'm using Firefox 7.
Thanks Hikelite
I've tried using Explorer 6 but it's no displaying the page correctly, there are several photos of the products on the website but none are displayed. Add to cart doesn't work either.
Firefox 7.0.1 displays everything correctly and add to cart works just fine.
Curious to know where this company is located ? any one have any idea .?
China
China
That's why I'll wait for someone to test them.
The cells are made in Japan not China.
thommy: Hikelite:I've tried again, and it works just fine. Could it be the browser? I'm using Firefox 7.
Thanks Hikelite
Right!
Just ordered 4 pcs protected 3100/ 18650.
Works just fine with Firefox.
just curious about its performance. i am intending to get panasonic 3100mah soon, how does it compare with panasonic 2900 and samsung 3000 (4.35v)
if only this panasonic 3100 performs so much better than the others two, the i will definitely get it.
Even I put 1 battery in my cart.. it still shows; Free shipping.. as being the only method of shipping..humm
Ya I'm waiting this one out....
Cells, yes, vendor - no, that's why I'll wait and see if they sell genuine Panasonic cells.
