Update Oct 3: PD68 TripleDown/TripleStack - Tri-Channel Driver
222 posts / 0 new
pilotdog68
pilotdog68's picture
Last seen: 58 min 14 sec ago
I have wanted to do a driver with 3 output channels for quite awhile, but never got around to finishing it. When Dr. Jones announced his rendition it spurred me to get back to working on it. I’m hoping my version will have much of the same functionality of his, even though I won’t have his special firmware for it. This version will require tweaking the firmware to utilize the FET, it won’t work with any existing firmware right now (I’m still working on that). This is an evolutionary step forward from my DoubleDown driver. I also took the opportunity to add another feature I’ve been wanting lately: The 7135 on the top of the board has a cut-able trace and it’s own LED- pad so that it can be used for a secondary led (such as red).
Features:
  • 1*7135 on PWM from Pin5 (will need center pin cut) — For lower moon mode
  • 6*7135 on PWM from Pin6 (one might need center pin cut) — For normal modes
  • LFPAK56 Fet on Pin3 (No PWM on Attiny13) — For Turbo
  • Top 7135 can be separated to power secondary LED (instead of moon mode) by cutting trace directly under the “7135” label.
  • Pads for LTC Bleeder Resistor
  • BLF Standard values/locations for all minor components
As always, let me know what you think.
Edit 1/17/16: pyro1son and DEL were kind enough to help get a FW working for this driver (not Rev2). It is essentially BLF-A6 modified to work with the output configuration of this driver. It has not been extensively tested, but appears to work great so far. As uploaded, it is configured for testing correct driver function. You will want to change mode, turbo, and LVP settings before installing in a light. Here is the link.
Edited by: pilotdog68 on 10/04/2016 - 09:27
pilotdog68
17mm Rev1.2
17mm Rev1.2z
Same as above, but BR is removed to make room for being Zener-ready. Note: D1 is opposite polarity compared to the other boards.
20mm Rev1z
Same features as 17mm Rev1.1z, plus:
- 2.2mm through-hole for LED+ bypass
- 7.5mm spring pad
- Generous 2.9mm edge clearance
Link to 19mm.
17mm Rev2
This version has a different focus. Rev1 was focused on providing the most possible control over a primary LED or controlling a secondary LED with lower current. Rev2 is more for lights that have 2 primary led’s, like the C22c or some bike lights.
As it sits, it is a FET+6 layout, basically a DoubleDown driver with 2 extra 7135’s. The FET and the 6 bottom 7135’s are on the two PWM outputs of the Attiny13a. If you cut the trace under the 7135 on the top, it separates the 6 bottom 7135’s from the FET. So you can have 2.28amps regulated for one output, and the FET for the other output. It will also work with existing firmwares, you only need to adjust mode levels to your liking. If you use an Attiny25/45/85 instead of a 13, you should be able to output PWM from Pin3, activating the 7th 7135 on the top, turning the FET side into a FET+1 side (and still leaving you with 6*7135 on the other side).
Of course this is all pretty experimental. I don’t know how the FET side will behave amperage-wise when both sides are on full.
20mm Rev2z
Same features as 17mm Rev2, but is also Zener ready, Attiny85 ready, and has eight 7135’s on the back instead of six.
TripleStack Rev2
This is the TripleStack. It has 3-channel functionality for a single output. I don’t think there is any way to use it with different outputs like you can with the other TripleDown versions. This version consists of a “bottom” contact board that holds the FET and most of the 7135’s, and a “top” board that holds the rest of the parts. You will need five 0.025” header pins to connect the two sides. The advantages to this board is that it will give you a cleaner look once installed, you can use a normal sized spring instead of being limited to a tiny spring pad, and parts were added that used knowledge from the Q8 driver to increase stability. The disadvantages are that it is harder to build (tight on space), you will need to make sure you have room in your pill for the stack, and it only has five 7135’s instead of the 7+ that other versions have.
Order Links:
15mm Top board
17mm Contact board
18.5mm Contact Board
20mm Contact Board
TripleStacks made specifically for the EagleEye X2R and X6R.
For the X2R, you just remove the top board on the original driver, get rid of the extra header pin, and solder this in its place. For best performance, you will also want to solder the big pad on the bottom to the top of the USB connector on the charger board. Headroom is tight, but the LED wire pads should line up perfectly with the holes in the shelf. If you order from Oshpark, be sure to get the thinner 0.8mm size. Also note the FET is the smaller LFPAK33 size.
For the X6R you will also use the stock pins. You will run ground wire from the charger board to the pad/via by the FET. The LED+ hole is over a spot you can carefully drill through the charger PCB to bypass the spring/PCB. I’ll illustrate all of this with pictures once I finish my X6R mod. Also be sure to order this one in the 0.8mm size.
LightRider
LightRider's picture
Last seen: 2 months 2 days ago
I’ve been looking for weeks to find a driver with some power that can control two nichia 219 on one channel and one xpl hi on the other. Idk if this driver would qualify?
pilotdog68
Well it wouldn’t be perfect for that. Either your nichias or your XPL would be limited to 380ma (or maybe 1140ma if you can stack 3 chips on top). That being said, I don’t know of any other real options right now.
Tom E
Tom E's picture
Last seen: 1 hour 54 min ago
Nice!! This is just to one LED output though, is this correct? Obviously it can drive LEDS in parallel but not separately, unless there's a way to cut/jumper mods to do that?
pilotdog68
The white line directly under the “7135” label is a cut point to separate the top 7135 from the other 6.
pyro1son
pyro1son's picture
Looking good! I’m hoping to get more time for this in the new year. I’ve got plenty of projects, which always seem remarkably similar to yours Wink
Pastebin                                      &nbs
prisma
Last seen: 1 day 21 hours ago
Thanks for your work!
Maybe this could be a replacement driver for my SWM C22? Would it be possible to control the 2 LEDs with one eswitch? I don’t like the UI but the light itself…
Subscribed.
bugsy36
bugsy36's picture
Last seen: 8 months 1 week ago
PD...Please forgive my ignorance....
Is this 3 channels 1 emitter? or...
3 channels 3 emitters?
It's the simple things that we take for granted that cost us the most
Ευκαιρία λέει πιάσε με από το μέτωπο γιατί μόλις έχω περάσει δεν θα με πιάσειs
pilotdog68
It’s definitely possible to control 2 with one switch, someone would just have to write the FW for it. Unfortunately that’s not really in my skillset.
Bugsy: 3 channels, 1 or 2 emitters
bugsy36
bugsy36's picture
pilotdog68 wrote:
It's definitely possible to control 2 with one switch, someone would just have to write the FW for it. Unfortunately that's not really in my skillset. Bugsy: 3 channels, 1 or 2 emitters
Yeah...well...you know someone that can Sealed It would be worth putting together a couple samples to send for R&D
Tom E
Tom E's picture
I've been trying to understand it as well. I've been analyzing the layout, and PD's reply to my question above. The default layout of this board is like a FET+1 driver -- drives only 1 emitter, but instead of 2 paths the MCU controls for the LED output (a 7135 and a FET), there are 3 paths: one single 7135, a bank of 6 7135's, and 1 FET.
The limitation we have to work around with the ATMEL tiny MCU's is that we can do PWM's on only 2 output pins, but with PD68's design, the FET is simply switched ON or OFF with no PWM's because you don't need them. You can use the bank of 7135's for all the in-between modes, and use the single 7135 for the lowest modes.
My preference for a mode set is 5 modes w/moon, so in the Narsil firmware, you choose a 4 mode set plus you turn on moon, so modes are as follows:
Mode 1 (moon):   3 or 5 PWM value on the 7135
Mode 2 (~2%):    30 PWM value on the 7135
Mode 3 (~10%):  full output on the 7135
Mode 4 (~40%):  80 PWM on the FET
Mode 5 (100%):  full output on the FET
So you can see from above, the first 3 modes are actually on one 7135, and the top two modes are only on the FET. TK's spreads it out, sharing the 7135 ad FET through the mid range modes.
So on this triple down driver, if I wanted to implement my 5 modes on it, I'd use the bank of 7135's only for mode 4. Six 7135's is 2.1A, so that would be 42% for a 5A max FET. However, as you know max amps on a FET varies based on the LED, cell, cell's charge level, etc., so these percentages will vary. The 7135's will give you something more solid, but still at some point, 2.1A will not be achievable depending on Vf of the LED and power/charge of the cell.
The advantages of this implementation is we are getting very efficient on all modes because PWM's on a fully open FET is pretty inefficient - it's more wear/tear on the LED by cycling 5A at a high rate, you get the tint bias for the 5A, and lumens/amp ratio is down. I can even see using only 5 7135's instead of 6 to get closer to a 35% level for your next level below hi/max. Another thing is you can treat using a full output on the 7135 bank as your hi mode, and implementing the full FET as a turbo. We have a lot of flexibility here with the 3 channels of output and can achieve very close results to a true non-PWM driver, like the LD-1/LD-2.
pilotdog68
I have no problem with sending a R&D sample, but I would want her to express interest in it first. I know she’s a very busy woman, and I don’t know if this is anything she would like anyways.
Technically it will work just fine using the 7135’s for separate outputs with existing firmware, you would just need to modify it a bit to get the FET to work.
Tom E
Tom E's picture
Another application of this driver is using it exactly the same as a FET+1, but having another PWM LED output available for something like a RED LED, or battery/status indicator light. Since you can go up to 2.1A or 2.28A (380 7135's) without stacking, you can use the full bank to do all your modes accept the highest, or turbo, which is the full FET.
Since TK wrote the Ferrero Rocher firmware, she certainly knows exactly how to handle 3 output pins with 2 being PWM's. It's well within her comfort zone I'd think, but interest/time of course is an issue.
bugsy36
bugsy36's picture
Correction ....2 coders Wink
Not trying to commit anybody to anything but the skills you all possess just amaze me.
pilotdog68
Pyro1son had been working on using Pin3 output at the same time I was working on my Olive S6 and almost had it working, I think he just got busy with life. I don’t think we will even need a new firmware, just modify one like blf-a6. We already have shortcut codes for turbo and strobe, etc. We just need a shortcut code for Pin3 and we’re done.
pilotdog68
Just finished cleaning up some very minor things on the board. Link is updated.
Since Tom stared at the circuit for awhile and didn’t spot any errors, I’m going to go ahead and order some.
Edit: 20mm and 19mm added to post 1.
LightRider
I still wish there were a good driver and firmware for a true two channel and two output driver. I have a number of projects that would benefit from this. Right now I have a bike light that needs a driver to power two nichia 219s on one channel and one xpl on the other. Ild like to drive them all at around 3.3amps on hi from four 18650s. But I just don’t see this kind of driver out there…
Tom E
Tom E's picture
pilotdog68 wrote:
Since Tom stared at the circuit for awhile and didn't spot any errors, I'm going to go ahead and order some. *Edit:* 20mm and 19mm added to post 1.
SmileCool - Didn't think my stare was worth much. I can follow it - just noticed your comment, so spent a couple more mins on it - looks good to me..
  • the C1/D1 order is fine
  • R1/R2 voltage divider circuit looks ok
  • the OTC pad connected to pin #2 is fine - doubles as an e-switch pad
  • the Bleed Resistor I understand you need for the lighted tailcaps - all good
  • just wish you could have fit the extra cap after the diode and close to pin #8 (Vc pin). I'm rigging up a 0.1 uF cap across the Tiny85 MCU between pins 4 and 8 for now. It's the only solution I know of - the problem it fixes is happening more regularly now on the wight FET+1 drivers, so I'm doing it on all of them now. When I saw it working fine on one light til I tried a LG MJ1 cell, got me think'n it's very borderline. The MJ1's are not even a top high amp cell. I think Richard will either confirm or find a better solution - he's the only one I know of now that has the methods/tools/interest to do so, but there probably are others.
Tom E
Tom E's picture
PPDB22 wrote:
I still wish there were a good driver and firmware for a true two channel and two output driver. I have a number of projects that would benefit from this. Right now I have a bike light that needs a driver to power two nichia 219s on one channel and one xpl on the other. Ild like to drive them all at around 3.3amps on hi from four 18650s. But I just don't see this kind of driver out there...
It's really not difficult to do, just takes time/effort/interest, and enough board space, which you may have in a bike light. Or you could do it manually now for sure with a couple of 7135 'farm' boards. You would wire up the two PWM output pins from the MCU, pins 5 and 6, to the slave 7135 boards, where you could have 9-10 7135's on each (9 would be 3.15A, 10 would be 3.5A). There's probably been similar projects done on BLF with a Tiny13A based board, either OSHPark custom or a Nanjg.
pilotdog68
Sorry Tom, i haven’t been following the 25/45/85 thread. I wasn’t aware of the problem. I have a layout in my head I can swap the BR for a cap, maybe I can get to it later tonight.
LightRider
Tom E wrote:
It’s really not difficult to do, just takes time/effort/interest, and enough board space, which you may have in a bike light. Or you could do it manually now for sure with a couple of 7135 ‘farm’ boards. You would wire up the two PWM output pins from the MCU, pins 5 and 6, to the slave 7135 boards, where you could have 9-10 7135’s on each (9 would be 3.15A, 10 would be 3.5A). There’s probably been similar projects done on BLF with a Tiny13A based board, either OSHPark custom or a Nanjg.
Hummm? So do you think there is a open sourced firmware out there somewhere that is close enough that I could “tweak” it to fit my needs? I am far from building my own drivers, but I am determined to find my way there:) Right now I understand the idea of slave board, but that is about it. I’ve swapped some resistors and fried a couple drivers… That’s my qualifications at the moment:) Im going to attempt adding 7135’s this week. So, atleast I’m moving forward.
I will quiet down and let you get back on track now as i don’t want to hijacked this thread.
chouster
Nice job, Pilotdog! You’re really pushing things forward.
I haven’t even tested out the DoubleDown, but will do for sure, because I love that bypass-hole-design. I’m sure you would’ve done it to the TripleDown-17mm if you found enough space… But in terms of space you managed to fit a lot into 17mm.
I’ve used a A17DD-SO8 in a Convoy L2 lately, drilled a hole through the triangular LED+ pad and managed to fit in 18AWG silicone wires. I really like the way the LED+ is arranged there. With some recent drivers I don’t feel comfortable using 18AWG if I have to use the pad and it’s very close to the ground ring. The width and shape of the ledge this ground ring sits on varies with different hosts and I find myself worrying about clearance sometimes.
pilotdog68
Well thanks for the compliments Chouster. Yeah, there was no way to get a pass through on the 17mm, and personally I hate the center pad on the S08. I find it a huge pain to solder to. This board has a bit more room around the outside than some of my others, and the 20mm board has a full 3mm of clearance around the edge.
chouster
I haven’t soldered on the S08 pad yet, probably never will, I just like the fact that you can drill and run a 18AWg wire through. Maybe there would be space for a hole if you would skip the LED+pad, but I know you’re not a fan of that. Anyways, very nice job.
pilotdog68
Uploaded 17mm Rev1.1z. Zener-ready (will also work for TomE’s extra cap.)
Tom E
Tom E's picture
PPDB22 wrote:
Hummm? So do you think there is a open sourced firmware out there somewhere that is close enough that I could "tweak" it to fit my needs? I am far from building my own drivers, but I am determined to find my way there:) Right now I understand the idea of slave board, but that is about it. I've swapped some resistors and fried a couple drivers... That's my qualifications at the moment:) Im going to attempt adding 7135's this week. So, at least I'm moving forward. I will quiet down and let you get back on track now as i don't want to hijacked this thread.
Sorry, no time to search - not sure if it would be public though. There are a few projects posted about in the past that did not have publicly posted source code. There still might be something though.. Recall pyro1son maybe did a multi-color F13 mod that sounds similar, ahh, here: http://budgetlightforum.com/node/39776
bugsy36
bugsy36's picture
PPDB22 wrote:
Hummm? So do you think there is a open sourced firmware out there somewhere that is close enough that I could "tweak" it to fit my needs? I am far from building my own drivers, but I am determined to find my way there:) Right now I understand the idea of slave board, but that is about it. I've swapped some resistors and fried a couple drivers... That's my qualifications at the moment:) Im going to attempt adding 7135's this week. So, atleast I'm moving forward. I will quiet down and let you get back on track now as i don't want to hijacked this thread.
You might look here..
http://bazaar.launchpad.net/~toykeeper/flashlight-firmware/trunk/files
pilotdog68
17mm Rev2
As it sits, it is a FET+6 layout, basically a DoubleDown driver with 2 extra 7135’s. The FET and the 6 bottom 7135’s are on the two PWM outputs of the Attiny13a. If you cut the trace under the 7135 on the top, it separates the 6 bottom 7135’s from the FET. So you can have 2.28amps regulated for one output, and the FET for the other output. It will also work with existing firmwares, you only need to adjust mode levels to your liking. If you use an Attiny25/45/85 instead of a 13, you should be able to output PWM from Pin3, activating the 7th 7135 on the top, turning the FET side into a FET+1 side (and still leaving you with 6*7135 on the other side). (Sorry TomE, couldn’t find a spot for the extra cap on this one.)
Tom E
Tom E's picture
Ordered the 1.1z. Thanx PD68!
pilotdog68
Sweet. Btw, 20mm Rev1 has now been replaced by Rev1z
Edit: also uploaded 20mm Rev2z
