I can’t post unless I hit “disable rich-text” each time. It took me a while to figure out why I suddenly was not able to post.
If I don’t disable rich-text each time there is no blinking cursor in the text box no matter what I do.
Something is still wrong. Even when I tried to edit this post and the post came up blank until I hit “disable rich-text” again and then my text appeared.
I also have 4 paragraphs but once I post it’s all one paragraph. I guess that’s what disabling the RT does but that’s the only way I can even post now. I’d really like to be able to form paragraphs again I have an older computer and maybe my operating system/browser is no longer compatible but everything was fine until midway through today.
It still doesn't work but that's ok because I've been having all kinds of other problems with this old computer. So I bought a new pc with Win 7, a 6 core amd cpu and 10 gigs of ram. :bigEFFINsmile:
OK, some smileys don't work. When you add a smiley, it adds symbols, but when you press "space", for example, to continue writing, something "hidden" is added before the smiley, so it doesn't work later :| Still unsolved since that update almost 1 year ago. Worked flawlessly before.
UPDATE: btw, all smileys should be added as word by defauld
Well, it certainly did nothing good for me since I can’t create a paragraph I’ll do my part and write less but whatever I do write will be more annoying (than usual) I’m sure since paragraphs are particularly nice to have. The “confirmation box thing” is only annoying to me but having no paragraphs is annoying to everyone
One thing that makes it go klablooey is when I use the "insert custom symbol." If I do this, "Foybezels™ " sometimes it forgets everything below the line with the custom symbol.
Not complaining, just letting you know if you already don't know. Lost the bottom 60% of my M8 review today and had to re-write it. Not that it matters anyway, nobody seems to care about that light.
It's all good, SB. Best forum on the web. Wish I owned one like it.
I have an older operating system so I can’t upgrade with the latest browser. I have Firefox but it’s not the latest version. It works everywhere else however.
Yes. There was no problems with being able to post. Now I don’t even get a cursor unless I hit that link at the bottom that says “disable rich-text”. When I do that I can’t use paragraphs. The “confirm box” issue that I mentioned in another post occurred sometimes but not for every page I look at as it does now. I don’t get that or the posting problem on any other site. There are a few sites that has excessive Java based ads or scripts that sometimes cause a pop-up asking me if I want to stop the script but that’s only on a few large sites that have nothing but moving ads.
I would think (hope) the fix would be something pretty basic. This is a text editor we’re talking about I get a cursor in the “Subject” box but can’t get one in the comment box. I tried an even older version of MS IE and that aspect worked but that browser is just too outdated for me to use in general. The fact that I don’t have this problem anywhere else nor do I have the “confirm” box after viewing every page anywhere else tells me that it should be a simple fix.
