300M+ Throwers...what do you have...?
whats your point
That I've taken your's
HID for throw.
This is a Palight BG-002 (28w) at about 46m.
It throws a nice bright spot out to ~500m.
sorry hikelite that came out wrong
it is winter here, Australia is warmer then some other places but i have not done full bore runs in summer yet as its not summer yet, a 2400 mAh battery should be able to give 2.4 amps for an hour in theory, so at 1.7 amps 85 mins is about the maxium run time before it drops out of regulation and the light will dim's.
85 mins timmed on my iphone while bush walking with the TR-1200 on high is as far as ive pushed mine, with 3 x 18650 the current draw is lower so run time should be longer but ive never pushed my past 85 mins as thats a bit extreme on high.
its warming up here and ill try long run test while bush walking on warm summer nights and see if i fry the driver but sofar its a great torch, i have seen some specials for them on here but they are cheap 2 x 18650 versions with plastic lens lols
i would like to try the HA3 model, but ill wait till this one is totaly worn out as my wife brought it for me, it turned out to be one of the best buy,s
Could you post a 200m beamshot?.
Most of the flashlights fare very well @ 46m.
The FandyFire STL-V6 should be one of the best throwers available - as long as we stick to reflector based LED budget lights.
I just got mine, 47kcd, 430m of NEMA-throw, with batteries not even freshly charged.
I doubt that a quite smaller reflector like BC40 can really compete with that. And my TR-1200 5*R2 gives 27kcd/330m.
Edit: Added the word "budget"... Well, there's the Fenix TK70 of course, 130kcd/720m.
Coolperl's results are impressive for the Crelant 7G5 which is not a clone.
My Trustfire X6 reaches 300 meters driven at 7.0 amps, but if you push 10amps may be it could be way better!
Looking forward to his beamshots!
Ok guys so nearing a decision on which light to buy: Either the Crelant 7G5 or the Sunwayman T40CS...? Which would you go for...? :D
Get both.... LOL!
One is 78 bucks, the other is 96 bucks, can't go wrong with either.
They should be pretty close, but it's at least 2 weeks more before the Crelant lands here.
2100
Where is the Sunwayman T40CS for $96?
Hahaha true flashaholic reasoning..! :D Where did you score your T40CS for $96...? The ONLY thing that even slightly puts me off of the Sunwayman is the "dark ring" around the hotspot as seen below.
The above gif is taken from selfbuilts review over on cpf forums.
Andy : http://nighthawk.taobao.com/
Also known as Olightworld on Ebay. Email him for best price.
Thanks
I'd go for Crelant 7G5, it's cheaper and throws better.
I also have a Fannyfire STL-V6 (Sky Ray STL-V2) and it’s a budget xml led value.
My single die emitter green led PT120 aspherical 4D 10,000ma powered Mag build is my best thower @ 4000+ lumen.
Ok guys and gals...so Crelant it will be. Now where to buy from...? Intl-outdoors looks like heir site is completely down...? Crelant 7G5 XML U2 3 mode 860 Lm. flashlight [Crelant 7G5] - $78.00 : Led Flashlight-International Outdoor Store
Wait for the site be back up.
It always makes me slightly nervous when these guys have their sites go down. CNqualitygoods was also down for quite a bit recently.
