Excellent find on the current setting! Should be easy enough to remove R10 and swap with slider switch with different resistors, high vs low current.
(I’m too lazy to do it, pass to someone else.)
Excellent mod, now I can make a decent charger for the 10180.
Thanks!
Keith
paging RMM or anyone else in the business of improving on things …
+1
really thank you
> quite normal that AAA NiMH get warm at 0.5A.
Agree; some chargers use the change in temp., don’t know about this one.
Yeah, let’s wait on HJK. But if you do discover anything about how your modified chargers handle NiMH, info appreciated.
I’d guess it won’t make any particular difference, but WTFDoIKnow …
My Lii-100 examples had 4.245 and 4.238V charge voltage.
Yes, that will also do it, but it takes two solder irons and a lot of skill to unsolder R6 and get it fast away from the tip of either iron in healthy state (and find it afterwards ). But at least the board has a better support by this procedure.
> quite normal that AAA NiMH get warm at 0.5A. Agree; some chargers use the change in temp., don’t know about this one. Yeah, let’s wait on HJK. But if you do discover anything about how your modified chargers handle NiMH, info appreciated.
I tried to charge a half full Eneloop XX, size AAA with 200mA in a unit modded for 200/400 mA. Happy to see that the charging stopped. Max voltage was 1.559V and cell voltage right after was 1.45V. The cell did not get warm.
light-wolff: sixty545:
- Solder a 6.2 MOhm resistor across R5. … . Can be mounted flat besides R5 and soldered at the ends (I used a 3MOhm plus a 3.3MOhm in V-form between the ends of R5.
Alternatively: solder a 3k0 or 3k3 resistor in series with R6 (also in V-form). These values are easier to find than X MOhm resistors.My Lii-100 examples had 4.245 and 4.238V charge voltage.
It’s super easy with a tweezer style soldering iron (if you have one - I do) and a 2nd pair of tweezers to hold R6.
Tweezer Style Soldering Iron for SMD. Handy tweezers with 48 Watt heating element is great for soldering/desoldering Surface Mount Devices (SMD). Includes 409-02 Tip Set
Nice!
Thank's for the link for the tweezer-iron. That is a must-have for my old hands.
Must find a vendor in CN or EU.
Anyone have any idea of the effects of 4.25V on a regular Li-ion battery?
Would it shave 5% or 10% of the expected recharge cycles? More? Less?
If it is in the 5-10% range, I think I’ll use the Lii-100 as is.
As I posted above, the 4.25V is charging voltage which is normal. The end voltage at battery is still around 4.2V.
Other chargers do this too. Charge voltage needs to be higher than intended final voltage, otherwise you cannot pump current in reasonable amount.
If you want to extend your battery life further and charge to 4.15V (for example) then you can do this procedure.
1dash1:Anyone have any idea of the effects of 4.25V on a regular Li-ion battery?
+ 1. This was my point in asking if the 4.25v was the voltage taken during the Charging process, not after from the cell’s voltage after taken off the charger after “Done”.
So this charger is just fine as it is.
Pulsar13: 1dash1:Anyone have any idea of the effects of 4.25V on a regular Li-ion battery? Would it shave 5% or 10% of the expected recharge cycles? More? Less? If it is in the 5-10% range, I think I’ll use the Lii-100 as is.
As I posted above, the 4.25V is charging voltage which is normal. The end voltage at battery is still around 4.2V. Other chargers do this too. Charge voltage needs to be higher than intended final voltage, otherwise you cannot pump current in reasonable amount. If you want to extend your battery life further and charge to 4.15V (for example) then you can do this procedure.
- This was my point in asking if the 4.25v was the voltage taken during the Charging process, not after from the cell’s voltage after taken off the charger after “Done”. So this charger is just fine as it is.
That is a misunderstanding! The correct, recommended charger voltage is 4.20V and the battery normally is 4.15-4.19V right after charging. I'm sure that HKJ will support me in that
The correct, recommended charger voltage is 4.20V and the battery normally is 4.15-4.19V right after charging. I’m sure that HKJ will support me in that
That is correct, but most LiIon batteries has a +/-0.05 volt tolerance on charging voltage, this means 4.25 volt charge voltage is acceptable.
I just had a very cheap charger charge to above 4.4 volt (the battery did survive). This type of chargers makes me think about adding a computer controlled mains switch to my charger test to automatic stop when the voltage gets too high.
After that nasty surprise I have started testing the Lii-100, but I expect the review will be mostly a copy of my Skilhunt M1 review.
Thanks for chiming in HJK!
The misunderstanding was that every charger voltage is allowed that leaves the battery on 4.20 V right after charging.
And now comes the Opus BT C100!
I’m not HKJ, but anyway: +1!
sixty545:The correct, recommended charger voltage is 4.20V and the battery normally is 4.15-4.19V right after charging. I’m sure that HKJ will support me in that
i thought this was an almost well established common sense, no?
