45 vs 85 is just a matter of space and cost. I figure I’ll mostly get 85-based drivers because I don’t see much point in the 45.
My non-v 25 driver seems to work fine, but a v version should in theory let it work at somewhat lower voltage. The non-v might die before LVP finishes activating. I haven’t tried one below 2.7V, so I’m not sure exactly how low it’ll go.
I thought I remembered someone having more trouble flashing either 45 or 85 at some point but I can’t remember which. I’m only planning to order a few so cost isn’t a huge issue, should I just go with 85v’s?
I’d recommend plain 85. 45 is pointless, same package size but less code room. I’ve actually seen 45 be more expensive in some places. So far no one has shown a need for the low voltage “v” versions. And they are a good bit more expensive.
TK (or anyone who knows) -- I thought there were some issues with the X6/X5 Rev 2 ATTiny25 based drivers. I had to double up the 10 uF cap or add another cap after the diode to get it working reliably at high amps. Was that a problem? If so, how was it solved?
I thought TK mentioned this a while back - was anything done in hardware to the drivers that shipped? It couldn't have been a firmware change because they shipped it with the October version.
** For the 45/85 issue - I agree, for same cost go with the 85. I bought my last 85's from Richard.
Ah, ok. That's exactly the problem I had, sounds like, and think it was only me that tried the doubling up of the 10 uF cap to fix it, originally.
I got 2 of the 3 X6/X6 rev2 sets I ordered, other might be here today or tomorrow. Was wondering because I didn't see any obvious changes, but dunno how to tell what size cap they used. Didn't get a good look at the driver yet - wires were not long enough to fully flip over the driver and was hesitant to unsolder the LED leads. They could have done the cap thing or maybe found a FET that didn't cause as bad a spike.
On that board, the bleeder resistor, cap, and LED+ wire are all done with one solder blob - kind of nasty to work with.
I removed the supposed 10 uF cap off the new SS/Cu X6 driver and tested it. It reads about 11.5 uF consistently, while a 10 uF cap reads about 9.6 uF consistently. So, pretty sure they changed the 10 uF cap to a 12 uF, or possibly 14/15 uF. Only ones I could find in 0805 size were 15 uF at +/-20% tolerance, but they might have found a 12 uF in that size.
The SU should work fine, but it’s bigger than the SSU. It might not fit onto the usual driver layouts, or it might need its pins bent underneath.
The temperature threshold can be defined in the code (and already is), but I’ve found individual variation between attiny units is generally too wide to make a “factory default” very useful. I calibrated one carefully, flashed the same firmware on another unit, and it started stepping down at room temperature.
I doubt it matters much. The data sheet says they’re the same package but 10SSU runs at up to 10MHz with a voltage down to 1.8V, while the 20SSU runs at up to 20MHz with a voltage down to 2.7V.
It’s usually abbreviated here as attiny25 (20SSU) versus attiny25v (10SSU).
Most drivers are using the lower-voltage version, attiny25v. But I have an early one from RMM using the non-V version, and it seemed to work fine too. It just runs the risk of failing before LVP is complete. I don’t know what happens if the attiny voltage gets too low to function.
Last night I tried a Attiny85 on a PD68 Double-down 17mm board for the first time and couldn’t get the 0.1 uF cap across the MCU grnd and VC pins to fix the problem. Also adding the stacked 2nd 10 uF cap didn’t work as well.
I’m testing the driver on the bench, even using a low performing under charged TF Flame cell, and the highest level modes don’t work, and strobe modes don’t work as well (strobe uses full FET). Not sure if it’s just FET full mode, or also the 30%40% 2nd high mode also. I’ll try another 0.1 uF cap to see if it’s just the cap could be.
Boy, sure wish there was someone helping with this trouble-shooting of the 25/45/85 problems. Yes - I’m begging for help again. Also wondering if anyone else is having these problems. Not sure if no one else is working with these MCU’s or just being silent on it.
This behavior of losing all high FET modes is one type of failure. The other is more subtle, where changing modes seems to work for a while then, occasionally resets the MCU - I can tell because in my Narsil firmware, I blink twice with low power on startup.
Ohhh? Shoot, missed that. It was indicated to me to keep the cap as small as possible, interesting… I’ll try that tonight. thanks!! Do you have a thread link, or search criteria I could use to find that thread?
I do, actualy i have a builded driver with a Narsil firmware and initial test show its working but i am quite busy lately at work, family and those hunting flashlights
BTW Tom, what had happened with that Y3-like firmware? Did you finnished it?
Hi Tom, I could probably do more to help. I have the test equipment, just limited time and still using 13As exclusively.
As discussed last time, you should not need more than 1 uF for local decoupling (the C spanning pins 4 and 8). So 10-20 uF in the C1 spot and an additional 1 uF directly across pins 4-8 should do the trick. It really is not normal for the 13A to work as well as it does without proper decoupling.
I just recently set up a ‘test-bench’ with an A6 driver in the open. The di/dt spiking/ringing on the FET drain pin is impressive. A second improvement you can try is to add 100-200 ohm resistance between the MCU output pin and the FET gate. This will slow the FET switching and reduce the inductive ringing. Depending on the driver PCB layout you will probably have to cut and scrape a track to fit this resistor.
Ohh, the resistor has to be in-line then on that trace. Hhmm - I usually use a 10K-12K resistor on the FET gate, but the resistor goes to ground, so I’m sure not the same effect as what you have proposed. Ok, I’ll see what I have, and see if I can do something like that. Think you might have told me the same thing, or something similar wayy back, but I’ve been using the caps successfully up til now, but on the wight FET+1 boards, not the PD68 Double Down’s.
Actually got some 0402 10K resistors, and am using that on this board for the FET gate to grnd resistor because it fits better to the FET pins. Maybe I should remove it for testing going forward — it’s a real PIA anyway to solder it. Basically, can’t see what I’m doing when I solder, and only with a magnifier afterwards can I inspect it. Gonna go back to 0805’s.
