It sounds like you already fixed this, but … yeah, you can unscrew the reflector and MCPCB, adjust the centering, then screw everything back down. You might also want to adjust the depth of the reflector, to fine-tune the beam. On my aluminum X6, the beam was nicer (and measured as more intense) after I inserted a very thin spacer. My steel X6 was pretty much optimal without any changes though. So, your mileage may vary, but it may be worth attempting to fine-tune the focus yourself.
Just to report , my SS/Cu X6/X5 set showed up today. All serial numbers match (235 of 400) The box in perfect condition no nicks or dings anywhere. The X5 had ridden up out of its spot but no damage suffered to either light that I can see from that. There is one small ding on the X5 but you almost have to have a magnifying glass to find it. Emitters well centered on both ,beam, looks good on both, no fogging of lenses or reflectors anywhere and not stuck in any modes that I can find.
I would say overall, my set got to me in as near perfect condition as any light or set would arrive to your door from any destination of the world.
Great job Krono, bugsy36, Johnnymac, Dale, Toykeeper and if I missed anyone thank you too. Love the lights and thankful to be able to be one of the lucky ones to have gotten in on this GB, Keep up the good work and kudos to you all.
Normally a yellow spot in the center of the beam means that the LED is too far up the reflector and needs to be lowered, or in this case the reflector has to be raised a tiny bit, less than 1mm. It happened to me in several mods and using a XP sized clear plastic insulator solves the problem. Richard has them.
The XP-L HI has much more even tint distribution than a domed emitter, but it’s not 100% perfectly distributed. It still leaks more yellow out to the sides than it does to the front. So, it’s pretty much guaranteed that the hotspot will be a bit more yellow than the rest of the beam. Not as much as with older emitters, usually, but the effect is still somewhat visible.
To reduce it, you will probably need to fine-tune the focus yourself — both centering and depth. IIRC, this process was already discussed within the last 50 posts or so, if you’d like more information.
I’ve had distinct spots in the beam even from premium brands like Zebralight. One nice thing about these BLF lights is that we can open it up and fix it.
Again, what have I done to you to deserve so many negative comments?
The SS/Cu set was super, ok, some dent corners on the box, and some scratches on the Cu light. But nothing big. I’m really happy, love the tail light, and the only thing I’m sorry for is that I will not use them, just have them in the box.
Therefor I have ordered 3 Al sets. At least one for my self. And the first that come here, has a really yellow spot right in the center of the beam, you can’t miss it. This is not normal, my other three lights have not the yellow spot.
Then, trying to fix it, the reflector? is stuck, no way to get it open. Is this normal?
Would you say that this light is 100% and what I paid for? I can not center the led, I can not open the reflector, I have a yellow spot in the beam.
Others with the same issue?
Don’t blame me for getting a light that don’t meet the standard the lights from this GB should have. But you of course think, it’s just Kenneth, he can live with the damaged light, no biggie. Good I have two more Al sets coming, hope they are OK, and then I can put this Al X6 in a drawer and forget about it. Good that I live in Norway so I have lots of money to spend on this.
And really nice to have a so supportive team member that supports the GB customers that you bugsy36. I can not fix this light, so I have to live with it. Would you have paid $50 for something broken that you could not fix?
I have nothing against you or anyone but honestly you have build up a reputation where most of the things you order don’t work as they should and can’t be fixed by yourself, which is… Uncommon?
I’d suggest starting by asking Neal for a replacement driver. It’s the sort of thing which is A) clearly broken, and B) can be fixed by a replacement part.
I’m not sure if the drivers will be sold by themselves, but I’m guessing they probably will be after a while.
The XPL Hi is an emitter without a dome and yellow is NOT out of the ordinary in some of the emitters regardless of batch. IT happens. It is the nature of it.
Just return the lights. returns with you are inevitable. You are not just a chronic complainer. You will break whatever rules to satisfy your desires. At the present moment...you should not even have those in your hands AND I know that had someone else had them they would most certainly appreciate them. PLEASE do not tell me how financially hurt you are. Fact is the light does work. Don't like the yellow....sell them and stick with the aluminum sets but chances are that you will look for reason to get refunds there too.
The better DMM's have a setting for it, usually shared with the resistance measurement setting. I used a Fluke, but my UNI-T UT50B DMM and my UNI-T UT210E clamp meter can read Farads as well. Biggest issue is the cap usually can't be read in circuit because of too many effects of the circuit, unlike resistors that can be read on the board .
Ken, use a sandal or a tennis shoe… a deck shoe for wearing on a boat like a Sperry Topsider is ideal… press the open face of the reflector against this rubber to grip it, twist the head of the light. Should unscrew. Or lay the piece of rubber down so you can press the light down onto it and twist off.
Obviously, make sure there are no little rocks or pebbles stuck in the tread of the rubber before you try this.
My lights showed up monday, #042 of 400.
The box had dents and chips in 3 of 4 corners but not too noticeable.
I ordered the 3B emitters and the X6 was 3B but the X5 is 1A.
I would have ordered that combo if I could have so that’s fine too.
In all a great deal, I’m really happy with this group buy.
Thanks for all the effort.
You do understand that I have NO issues with the SS/Cu set. The issue I have is with the Al X6. So stop talking about the SS/Cu set.
I’m not out for refund each time a have an issue. But I MUST be allowed to write about my issues like all others in this thread. Don’t know why I is so unlycky with stuff like this, but I had no issues with the 7 BLF A6 lights, or the 4 BLF D80 lights I got. Also got several EE X6 XP-L HI without any issues, and a ton (around 30) of S2+ from Simon and Gearbest, all working 100%.
Still, why do you hate me so much? It is not me that have make this light, it’s not me that has glued or tighten the reflector and it’s not me that have made the yellow spot. But you blame me for it it seems.
So I’m not allowed to complain when something is wrong? The Al lights is public, so I can buy so many as I want, still, issues is issues.
A screwdriver and some fine-tuning and possibly a strap wrench will fix this.
Possibly a thin spacer too, like the one RMM at MtnElectronics carries (linked a couple pages ago), or a few sheets of paper cut to fit (or whatever else you can wedge in to keep the reflector from going too deep).
The issue here is that the reflector is stuck, so I can not open it to fix it. That is the main issue. If I could get the reflector open, maybe there would be a easy fix for the issue.
