Iād suggest starting by asking Neal for a replacement driver. Itās the sort of thing which is A) clearly broken, and B) can be fixed by a replacement part.
Iām not sure if the drivers will be sold by themselves, but Iām guessing they probably will be after a while.
The XPL Hi is an emitter without a dome and yellow is NOT out of the ordinary in some of the emitters regardless of batch. IT happens. It is the nature of it.
Just return the lights. returns with you are inevitable. You are not just a chronic complainer. You will break whatever rules to satisfy your desires. At the present moment...you should not even have those in your hands AND I know that had someone else had them they would most certainly appreciate them. PLEASE do not tell me how financially hurt you are. Fact is the light does work. Don't like the yellow....sell them and stick with the aluminum sets but chances are that you will look for reason to get refunds there too.
The better DMM's have a setting for it, usually shared with the resistance measurement setting. I used a Fluke, but my UNI-T UT50B DMM and my UNI-T UT210E clamp meter can read Farads as well. Biggest issue is the cap usually can't be read in circuit because of too many effects of the circuit, unlike resistors that can be read on the board .
Ken, use a sandal or a tennis shoeā¦ a deck shoe for wearing on a boat like a Sperry Topsider is idealā¦ press the open face of the reflector against this rubber to grip it, twist the head of the light. Should unscrew. Or lay the piece of rubber down so you can press the light down onto it and twist off.
Obviously, make sure there are no little rocks or pebbles stuck in the tread of the rubber before you try this.
My lights showed up monday, #042 of 400.
The box had dents and chips in 3 of 4 corners but not too noticeable.
I ordered the 3B emitters and the X6 was 3B but the X5 is 1A.
I would have ordered that combo if I could have so thatās fine too.
In all a great deal, Iām really happy with this group buy.
Thanks for all the effort.
You do understand that I have NO issues with the SS/Cu set. The issue I have is with the Al X6. So stop talking about the SS/Cu set.
Iām not out for refund each time a have an issue. But I MUST be allowed to write about my issues like all others in this thread. Donāt know why I is so unlycky with stuff like this, but I had no issues with the 7 BLF A6 lights, or the 4 BLF D80 lights I got. Also got several EE X6 XP-L HI without any issues, and a ton (around 30) of S2+ from Simon and Gearbest, all working 100%.
Still, why do you hate me so much? It is not me that have make this light, itās not me that has glued or tighten the reflector and itās not me that have made the yellow spot. But you blame me for it it seems.
So Iām not allowed to complain when something is wrong? The Al lights is public, so I can buy so many as I want, still, issues is issues.
A screwdriver and some fine-tuning and possibly a strap wrench will fix this.
Possibly a thin spacer too, like the one RMM at MtnElectronics carries (linked a couple pages ago), or a few sheets of paper cut to fit (or whatever else you can wedge in to keep the reflector from going too deep).
The issue here is that the reflector is stuck, so I can not open it to fix it. That is the main issue. If I could get the reflector open, maybe there would be a easy fix for the issue.
A couple people have mentioned that. I wonder if there was more than one batch made, with slightly different processes. Or maybe more than one chunk of copper used as source material. Got a picture? Iāve never actually seen a copper mismatch.
MY mistake thinking it was the SS/Cu set but my position still stands.
Ken, you need to learn more....just fact of it. You look for the tiniest fault in everything and that is not what this place is (at least in my opinion). This place takes great pride in taking nothing and making something. With these group buys we do our best to make that possible for everyone with no effort AND at a cost less than what one could do for the cost of parts alone.
The yellow may or may not go away...I do not know because it IS not uncommon BUT once you mentioned "Contact Neal" all bets are off in my book. If you can make it go away ...great...if not, then just sell them...you are after-all in the flashlight reselling business.
Arrival! 8 total days with that free Priority Direct shipping, canāt beat that. I got them about 1:00. Wanted to go for a bike ride. Didnāt open the package at all, how many could do that? Came home from the ride and opened it, first the S.S. OH MY GOODNESS! Not a mark on it. People werenāt lying when they said these were HEAVY! I got 2 clips with mine, both in the bag. The light/UI works great. Thanks to Daleās config. video posted earlier it was simple. Havenāt attempted changing the number of modes yet howeverā¦ Iām giddy over these. Should have bought more sets :bigsmile: Will definitely have to get an aluminum set as well, as these will be shelf Queens. The lit tailcaps are nice but canāt get used to them. Not going back to find a post but this lit tailcap doesnāt draw too much power? No worries? I donāt want to have to keep unscrewing the tailcap to turn it off. And then there is fear of GALLING Whatever.
The copper one is awesome as well. Great lil size. After seeing some pics it would be nice to have an amber or red tail light in this one. The clip came on the copper light. How do I get it off without scratching the body?
These two lights are amazing. Sorry for the others, but mine do not have a mark on them. I did not get the box. I think TK said the S.S. put out 1400 lumens stock. How about the copper one? Did I hear 1300?
I couldnāt be happier with these. Iāll just keep these 2 and get rid of my other 70 lights! Wait, Iām keeping the A6 too. The wait was worth it. No way to show my gratitude. Hereās a couple of pictures:
Thats because I ordered cheap (type Ultrafire and Cree) lights, thatās promised the world, and was just crap. The last 6 months or so, I have only got Convoy S2+ (30 pcs) and Convoy C8 AK47 (10 pcs) lights from Simon, each specially modified (and Gearbest), Eagle Eye X6 XP-L HI (6 pcs) from a producer that made a small batch, then I have been on three Group Buys here, actually 4. BLF A6 (got 7), BLF D80 (got 4), 4 x BLF-348 - Classy and Small 1xAAA Stainless Steel light and now the BLF X6 SS/Cu and Al GB. Also got some JM35, Yezl y3 and a Nitecore MH20 (it was expensive)
I have learned from my mistake, and would say that I only buy premium lights now, since the GBs provides premium lights. If they donāt do that, and people still think I buy crap, why do we have the GBs then?
But still, this time I was unlucky with ONE Al X5 light of all the lights mention over
Uncommon, yes, but not for lacking of trying to get premium lights without the knowledge to build one my self.
Thats little of my point. You use so much time to create the āperfectā light, for a good price. You work for months. Then, when I buy a such light, I have higher exception to that light then to a $2 Ultrafire light on Ebay. I must be the most unlucky person on this planet, for what is the change that I get a slightly ādamagedā light from this great GB?
Stop taking it so personal. I love the work you and the rest of the team have done. Love the SS/Cu set, love the taillight, love the UI, you have done a hell of a job. But some Chinese person has not done a good job on this Al X6, no QC. Thatās not your or the teams fault, but the producer.
Neal is selling thees lights, and if any, he can fix this issue with my light.
So, no personal to you or the team (despite you are very personal with me).
