FastTech New Arrivals & Promotion
848 posts / 0 new
scrumpypaul
scrumpypaul's picture
Last seen: 1 week 2 days ago
Just a wee heads up – this works out at around £35 with the code – I could be so, so tempted had I not ordered a normal S1 from AE earlier today for about £23.
ewhenn
Last seen: 3 years 4 months ago
Picked up a Convoy S2+ and 4 18650’s
Great price with coupon!
1dash1
1dash1's picture
Last seen: 12 months 3 days ago
led4power wrote:
Teclast x98 pro for ~193$ after coupon?
https://www.fasttech.com/products/4141001
I need general purpose computer that will replace old desktop PC (big screen stays),and be portable,also Windows support is important(x98 pro is win10+android). Is this good option?
If Windows support is a necessity for you, I’d suggest sticking with a laptop or desktop. Windows support of these type of devices is poor. (What works now, works. When they issue an upgrade, all hell breaks loose.)
As an Android device, it looks great!
Rule 1-1 as it applies to life, take it as it comes.
1dash1
1dash1's picture
Skytrooper wrote:
The tablet I’m tempted to buy is the Chuwi Hi10 which is around $160 with the current 20% discount. Unfortunately, FastTech doesn’t sell the keyboard made for the Chuwi Hi10.
You’re talking about a matching keyboard, right?
Otherwise, any bluetooth keyboard ought to work.
And if you really need a keyboard, you’ll probably end up with a laptop, anyway.
jhalb
jhalb's picture
Last seen: 3 years 3 days ago
Got a bunch more stuff, Sanrenmui's, Ganzo's, the BTU, Skyray's 4x's, tools galore, drivers, xm-l2's, 2.5 and 3mm solder wick, solder paste, Convoy S2's, 3's and 4's. That was just today..Smile
Literally saved hundreds!
Thank you FT!!!!!
isti242
isti242's picture
Last seen: 1 day 2 hours ago
ewhenn wrote:
Picked up a Convoy S2+ and 4 18650’s Great price with coupon!
What sort of 18650 should I choose for the S2+?
1dash1
1dash1's picture
The stock S2+ draws a maximum of 2.8A, so just about any good quality 18650 will do. The flashlight has springs at the head and at the tail, so it doesn’t matter whether the battery is a button-top or a flat-top. And the choice of protected or unprotected cells should be based on your comfort level in following proper protocols for charging and recharging the cells.
Here are a few suggestions: http://budgetlightforum.com/node/43577
1dash1
1dash1's picture
Skytrooper wrote:
These are what I often put in Convoy S2+ lights I give away to friends.
https://www.fasttech.com/products/1420/10001980/2741003-authentic-panasonic-ncr18650b-3-7v-3400mah
Hope your friends know what they are doing with unprotected li-ion batteries. Sushi
isti242
isti242's picture
Skytrooper, 1dash1 thanks for the info!
I’ll order protected ones.
NickBose
Last seen: 2 years 5 months ago
Tried to order 3 car micro USB charger. KUNGHEI did not work. Time now is morning 7 Feb Eastern US time.
Update: it worked but I had to order 1 only, then changed to 3 then it worked.
If ordering 3 straight away the code did not work
bmwsancho
bmwsancho's picture
Last seen: 7 months 2 days ago
code works for me, free/flat shipping and tried on AMC7135 chips, lenses, parts. some of them single parts, some multiple units.
have been shopping throughout the last 24 hours and it seems to be fine? I do have to reenter the code for every checkout thought but that is fine.
lumiere
Last seen: 1 week 3 hours ago
Skytrooper wrote:
Next, I experimented with adding individual items then seeing if I was “allowed” to checkout. I added some Sanyo 18650s and could checkout, again only using Sweden Post. In the past, USPS Expedited for Battery Products was an option and the one I selected.
I ordered some batteries yesterday and was also presented with Sweden Post as the only option (in the past I’ve used USPS Expedited for Battery).
I received a battery the other day from BangGood and noticed it was shipped via Sweden Post. Perhaps there are new shipping restrictions in place that’s forcing vendors to use Sweden Post for batteries?
The Last Katun
The Last Katun's picture
Last seen: 3 weeks 5 hours ago
I, with 20% discount, I bought SHADOW JM35; I also order the batteries, but the Swedes post have placed far too slow; also they serve 50 days, to make me get the goods, I left the batteries.
jhalb
jhalb's picture
Skytrooper wrote:
I just had the strangest experience while trying to place an order for some knives, batteries, and misc. items with FastTech. With the exception of a couple Nitecore 16340s, every item was one I'd ordered multiple times before from FastTech. When I went to checkout, I couldn't do so because no shipping option was available. In the past, I'd usually be given a choice of at least two options. Realizing some shipping options don't allow knives, I deleted the Enlan pocketknives (even though I'd successfully ordered them before). Still no shipping option. Then I removed all the batteries. Now, I was allowed to checkout but only with a single shipping option: Registered Airmail via Sweden Post. Since I wasn't going to bother placing an order just for some plastic battery storage boxes, flashlight holsters, and a butane lighter, I deleted all items in my cart. Next, I experimented with adding individual items then seeing if I was "allowed" to checkout. I added some Sanyo 18650s and could checkout, again only using Sweden Post. In the past, USPS Expedited for Battery Products was an option and the one I selected. Next, I added the Nitecore 16340s and was still allowed checkout with Sweden Post. Then I added the Enlan knives and couldn't checkout because there was no shipping option. I removed the knives then added the butane lighter. No checkout allowed ... even though previously the same lighter in my cart wasn't a problem. I finally gave up. Perhaps I'll have better luck later in the day, hopefully before the 20% discount expires.
Sounds like you may have found some faults with their shipping system. If your having a problem, know what you want and send them your list and tell them the problems your having. Definitely make a ticket to make sure you get your discount, I would have done that right away as you may have. I've spent well over a thousand dollars over this discount period buying everything from solder wick to 100 dollars flashlights, over multiple orders. I have not run into any issues. But as you have noticed, batteries are a strange bird to ship. For the most part FT has been well above any of the other asian companies to deal with when issues arise. For me over the years they have been around 98% consistent. The longest I have ever had to wait for something to reach my door is 14 days. Earliest has been 6 days. Not one of the other companies can even reach FT's worst shipping time. I pretty much use them exclusively.
1dash1
1dash1's picture
I experienced similar order problems this weekend.
And I had to mix-and-match, split up my orders, to get the desired shipping options.
Some of it was due to restrictions on knives, some of it was due to restrictions on shipping liquids. I didn’t order any batteries.
1dash1
1dash1's picture
jhalb wrote:
For the most part FT has been well above any of the other asian companies to deal with when issues arise. For me over the years they have been around 98% consistent. The longest I have ever had to wait for something to reach my door is 14 days. Earliest has been 6 days. Not one of the other companies can even reach FT’s worst shipping time.
My experience differs from yours.
Ordered _________ Shipped _________ Delivered __
09/07/2015 ……….. 09/25/2015 ……….. 10/08/2015
09/07/2015 ……….. 10/06/2015 ……….. 10/13/2015
09/29/2015 ……….. 10/06/2015 ……….. 10/21/2015
10/14/2015 ……….. 10/16/2015 ……….. 12/03/2015
10/20/2015 ……….. 10/21/2015 ……….. 12/16/2015
10/25/2015 ……….. 10/27/2015 ……….. 12/16/2015
12/07/2015 ……….. 12/08/2015 ……….. 12/23/2015
Average time order to shipment: 8 days
Average time order to delivery: 37 days
jhalb
jhalb's picture
1dash1 wrote:
My experience differs from yours. +Ordered _________ Shipped _________ Delivered __+ 09/07/2015 ........... 09/25/2015 ........... 10/08/2015 09/07/2015 ........... 10/06/2015 ........... 10/13/2015 09/29/2015 ........... 10/06/2015 ........... 10/21/2015 10/14/2015 ........... 10/16/2015 ........... 12/03/2015 10/20/2015 ........... 10/21/2015 ........... 12/16/2015 10/25/2015 ........... 10/27/2015 ........... 12/16/2015 12/07/2015 ........... 12/08/2015 ........... 12/23/2015 Average time order to shipment: +8+ days Average time order to delivery: +37+ days
That is highly bizarre, but living in Hawaii might have something to do with it. I think it all gets shipped to the continent of the United States. The reshipped to Hawaii. I've never waited more than 14 days. What do you think?
I have noticed that FT has been slipping on shipping items that show in stock within a few days. I ordered the BTU when they brought it on board the same day and it did not ship for a whole week when it said in stock. I cancelled the order. But I went ahead and bought it yesterday because of the 20%.
AmirBagatelle
AmirBagatelle's picture
Last seen: 4 years 1 month ago
I just made a purchase (2/7/2016), used coupon code and got 15% discount. Should have gotten 20% discount.
Coupon code: KUNGHEI
Feb 5-7 : 20% sitewide discount
Feb 8-14: 15% sitewide discount
jhalb
jhalb's picture
AmirBagatelle wrote:
I just made a purchase (2/7/2016), used coupon code and got 15% discount. Should have gotten 20% discount. Coupon code: KUNGHEI Feb 5-7 : 20% sitewide discount Feb 8-14: 15% sitewide discount
That is odd, did you open a ticket? Looks to me that you are within the est timing they prescribed in their first post.
AmirBagatelle
I just realized that while it was still the 7th here it has already become the 8th in their time zone.
strongest2004
strongest2004's picture
Bought an extra miller ml-102 charger, a couple of AA placeholders and 2 nitecore tube keychain lights, all with 20% discount.
Thanks Fasttech!
Low mode and long runtime lover…
TheBo
TheBo's picture
Last seen: 3 months 5 days ago
When there are no shipping options is because there’s no “intersection” on any delivering method between “batteries + knives + your country”
Rufusbduck wrote:
Getting discouraged is normal but doesn't finish the job.
WhitedragonBC
WhitedragonBC's picture
Sirius9 wrote:
Talking about the light sources…
(even had to exclude some intriguing 3000K HI XP-L’s because of the budget :~ )
Cree XP-L HI U6-5A 380LM 4000-4500K LED Emitter
Item# 3594908 $4.07 USD
Cree XP-L HI V5-1A 460LM 6500K LED Emitter
Item# 3740302 $4.95 USD
Cree XHP70 N4-1B 1830LM 6500K LED Emitter
Item# 3740700 $9.47 USD
Cree XP-L HI V2-5C 420LM 3700-4000K LED Emitter
Item# 3849700 $4.22 USD
Cree XP-L HI V5-3B 460LM 5000-5300K LED Emitter
Item# 3849701 $4.06 USD
1.75W 160LM 620-630nm Red Light COB LED Module
Item# 1944900 $1.70 USD
18W 1000LM 6000-6500K Pure White Light COB LED Module
Item# 1804604
I’d love to order some of these but the V5 bins make me think they’re all fake/mislabeled.
-X3-
-X3-'s picture
Last seen: 23 hours 49 min ago
I can’t checkout my oreder Sad anyone else ?
EDIT : NEvermind, I had li-ion mixed with other stuff…splitted them and it’s ok.
HUNKHEI !
"-X3-, is there any place in your house without a flashlight ?"
My Flashlight public album (mods, emitter swaps, eye candy)
My reviews channel (French language, Olight, Thorfire, Sofirn, Lumintop : 60+ lights tested)
My personal channel (including Olight SR mini, S1, S2, S1A and S-mini disassembly)
M4DM4X blog, saves you $$$
fasttech
fasttech's picture
Last seen: 1 week 1 day ago
Hi everyone,
How are you all doing. Just a friendly reminder the KUNGHEI promotion will be ended on 2/14. Grab the last chance to enjoy the 15% off discount!!!
Cheers Smile
Noel
FASTTECH - LED Flashlights, Lasers and Electronics
HarleyQuin
HarleyQuin's picture
Last seen: 1 year 4 months ago
Just ordered and the 15% discount still works
Thanks for the promotion
HQ
Oshpark Boards:
HQ ProgKey: Universal Driver Programming Key . Boost: HQ 15mm/17mm programmable boost driver with ATtiny13A
46mm Triple-Channel: BLF SRK FET v3 . 17mm Linear: HQ10D / HQ4D / HQ4S . Contact Boards: 22/24/26mm
jerm03
Last seen: 1 month 4 weeks ago
I was going to order a couple of Tank 007 e09 lights, but the code KUNGHEI was invalid. It is the 14th here in New Mexico, but I do not know what it is where it is being ordered. I wish I had seen the sale earlier. The Tank 007 e09 has increased a lot in price.
I wonder about the FT FandyFire AK-007?
Jerry
fasttech
fasttech's picture
Jerry
Hi Jerry,
I checked the code and it is still valid. Please make sure you place the code in “ Have a coupon code” in “Summary of Cart”.
Thank you.
Noel
antiparanoico
Last seen: 1 week 3 days ago
I ordered a few minutes ago and coupon (15%) still working.
Thanks!
If anything can go wrong, it will.
Matter will be damaged in direct proportion to its value.
AmirBagatelle
Dear FastTech
I recently received an order from you for a number of items. One LED was missing from the order. I tried telling you this on your website but you wanted to have a form filled out including pictures of the front and back of the package and another picture of all the items displayed side by side. I couldn’t do this, so I spoke to your chat person. He said without the pictures I could prove nothing. I asked for your email, and gave him my email. He said you could not communicate by email.
I order a lot of stuff from you. In fact I have two orders ready to be shipped right now. If you can’t take my word that one single LED was missing from one of my orders, or make communication easier, then perhaps I should be looking for a different dealer.
