Fought my fet+1 most of the day. Took a break to bake some Convoys
Overhauled one of my first 3up X6’s and played around with GITD stuff applied to some optics,
This X6 had a glued Al-Heatsink, 3 badly dedomed 219B on a FET driver and additinal glass lens. Board was also glued down. I managed to force the board out. Heatsink was left in place but I drilled and tapped two holes into it to secure the board. Sanded down the 32mm board and soldered it under the new one. LEDs are 219B-V1 R9050 sw57, by the way. Sanded down the bezel a bit and now it’s a perfect fit without additional glass lens. While the optics are curing, I prepared a 105C based driver. It’s a dual channel 11+2 AMC7135 driver now, 4.67 A max, running BLF-A6 firmware with BATTCHECK_VpT (EDIT: doesn’t work), 6- and 4-mode-groups, where in the 6-mode-group, 4 modes are running solely on the 2nd 2x7135-channel, in the 4-mode-group, 2 modes are 2nd channel only. Didn’t dare to touch the optics yet, hope they’ll turn out nice.
PICS!!!
I too would like to see more pics of baked convoys.
I’m fine with throwing some Ultrafire cheapies in the oven, but I can’t bring myself to putting my convoys in there.
Yesterday I bypassed about 50 driver and tailcap springs. I had some free time.
50? Wow
I thought the Clnvous have HA3
But mine are very nice in grey and mat black no need to bake them (I use the gas flames much faster then heating the whole oven)
The white smudges on the C8 is thermal past.
I am super happy with the way they came out.
Right click and open in another tab to see larger photos.
I also baked a blue convoy shorty tube, but I cant find it.
Turned out greyish blue. At one point the C8 head was grey, I took it out and it went back to black. Then It went to far to orangebrowncopper
On flames it is easy to remove with pliers
I really like your results, like old copper.
I used a cookie sheet on top rack of oven. Would like to try torching some for some effects.
On the previous page you can see my take on baking blue convoy tube, if you are stuck on blue/green tint you need more heat.
I might have to bake it some more. I would like to get to a grey color.
I did a complete mod. today. Using the driver I planned didn’t work out easy, so I used an old SK-68 clone driver with a new Nichia to up the output of a RoMiSen RC-A8 on CR123A.
From XP-G2 to XP-L HI 3D using the same copper PCB.
Resistor mod (R100) increased current from 1,8A to 2,9A.
Cooked in the oven for one hour.
Cool cooked job. What temp did you use ?
Did it go past orange before that color ?
I used 300ºC. (max temp)
No orange color. It turned from dark brown to light brown, without orange. Tactical ring was burned with a kitchen burner.
Thanks, I used more heat, less time.
Will try another Convoy soon.
Same temp and same time, in a cheep light. It took a gold finish.
300.000 Cd running a gas dedomed direct drived XP-G2 .
with BATTCHECK_VpT(EDIT: doesn’t work), 6- and 4-mode-groups, where in the 6-mode-group, 4 modes are running solely on the 2nd 2x7135-channel, in the 4-mode-group, 2 modes are 2nd channel only. Didn’t dare to touch the optics yet, hope they’ll turn out nice.
EDIT: Got it working now, BLF-A6 with BATTCHECK-VpT. TK could have done that in an instant I guess, just a green quest, but for a coding newb like me, it’s quite an achievement.
Nice results… I will have to start baking my lights as well
I did the RMM SRK driver swap. Now I have 7 nice even modes. First thru hole I’ve done. Got a Trustfire 12 led on/off only which I’ll put the old SRK driver into and at least have L/M and high…I hope. Still learning
