Light lost in aspheric lens flashlight
You are right that the intensity vs angle is close to cos(theta), but wolfram alpha would not calculate the answer in that case because it took too much computation time, so I went with the quick approximate answer.
That is a strong Fresnel lens, maybe the strongest lens in general that I have seen for sale, but it would still only collect about 67% of the light from the LED, though it would make a nice light weight spotlight. I hope that a well designed two lens system can get higher light collection efficiency. I have been doing some calculations and it seems the pre collimator lens should be as strong as possible for this purpose. There is a 20mm diameter, 11mm FL lens at edmund optics.
By the way, check out this two lens thrower I put together a while back. It worked out pretty well, but I didn’t really take any measurements regarding the light extraction efficiency.
That was 2 years before I joined CPF and later BLF :slight_smile:
That was a really cool light, optically well thought out. I wonder what the throw number was (is?).
Thanks. I still have it but it is disassembled. It never got past prototype state, so it was fragile and awkward to use. As it was in the thread I would guess it had 300-350kcd. It could be much higher now I think, if I installed a brighter, dedomed LED. One of my favorite things about flashlights is they can be so portable, so this UF 1504 that I’m building, to me, is sort of a new and improved version of that light I built 6 years ago.
I thought it was interesting how Ervin used a small aspheric situated at its focal point within a large reflector to both capture and focus virtually all emitted light. It seemed pretty effective.
That is a neat idea and impressive execution.
The inefficiency of software never ceases to amaze me. That should take something like a microsecond per angle on a laptop.
I like this type of threads,
Did you seen this thread: Dereelight DBS with de-domed XP-G2 and pre-collimator lens | Candle Power Flashlight Forum
That certainly looks like a good result. It seems like he is getting good light extraction efficiency from his ceiling bounce test comparison to the 860 lumen light.
There is no direct before/after comparison for adding the pre collimator lens, but we can tell something from the beam shots. I assume the XP-G was dedomed. The XP-G with pre collimator has about the same area in the beamshot as the dedomed XM-L which has about double the die area as the XP-G. So the light collection efficiency approximately doubled by adding the precollimator lens.
I can’t help plugging my own fresnel lens contraption here that I made last year O:-) 37.5cm fresnel lens spotlight build
Vinz is really advanced modder. I wonder what happened with him? He was member here on BLF?
That was 3 years ago. Pre collimator lenses(really working, confirmed and tested by various people) and tint changing of de domed emitters are his biggest inventions… Everyone talked about it at that time and just few people managed to crack right pre coolimator lenses and to change tint with “diamond treating” as he said :).
We can tell a lot from that picture… It is 100% bigger die projection without lux drop. That is huge upgrade to led because dedomed XP-G2 grows to XML dedomed size(xml grows even bigger :slight_smile: )
I tried one pre collimator lenses and I got MTG2 size projection of XP-G2 but about 50% lux drop with poor flood mode. So in aspheric flashlight if you achieve bigger die projection with pre collimator lenses you will have extreme hotspot size with poor flood mode.
I think a lot can be achieved with right lens choice and placement which is not easy at all. It needs to be placed around 0.7mm above led as Vinz said.
So due to my lacks of knowledge in such deep details, I’ve nothing to add to the technical debate about pre collimator lenses,
but since a couple of times ago Vinz had pimped up some of my Dereelight pills for the Night Masters and X-Searcher,
I can show you a practicle kind of example.
The effect of the pre collimater:
Allthoug the X-Searcher and the UF. 1504 have nearly the same headsize (maybe the X-Searcher is a little bit smaller), I think it’s good to see that the spot of the X-Searcher is quite significant larger.
As I remember it well, Vinz said that by using such a pre lens you might have a very little loss of lux (around ca. 5 %),
but this price is worth to pay for, concerning to the amount of lumens you are gaining, which in relation should make the pre collimator
even more effective with a brighter LED.
Some Beamshots of the Night Master and the X-Searcher (and other companions) with a pre collimator XP-G2 ded. / XM-L2 ded.
you can also find here - A little beamshot comparison of my decent Thrower material.
We needed such reply in this thread :slight_smile:
About this “Vinz said that by using such a pre lens you ’ve a very little loss of lux (around ca. 5 %)”
He said once that even small lux gain can be achieved sometimes. But mostly it is 0 or ± 5% which depends on how accurate you placed lenses.
Thanks for these pics, MAC. I think that is close to the before/after comparison I was looking for.
I’m aware of the principles and compromises of using pre collimator lenses. I made a larger version of the two lens system back in 2010 (CPF thread linked above).
The objective is to collect most of the light with the pre collimator lens and have the lens project the light in a smaller cone towards the main lens. The picture below is of the light that I made, with the lenses in the optimal positions, with the cone just filling the main lens.
If the pre collimator lens were closer to the LED, the light cone would become larger and it would overfill the main lens, losing some light around the edges. If it were farther away, the cone from the pre collimator to the main lens would be more narrow, but then the pre collimator lens would not collect as much light from the LED.
The pre collimator lens should have as large a diameter:focal length ratio as possible to optimize light collection (a ratio of around 2 is what I used in the above picture). If you are familiar with ray optics or play with a calculator like this one:
http://www.photonics.byu.edu/Thin_Lens_Calc.phtml
you can see that when the LED is very close to the lens the image is close to unchanged in position and magnification. When the LED is close to the focal length, but inside the focal length, the image appears to be farther away from the lens and there is significant magnification. The light cone from the pre collimator lens is very narrow in this configuration. The magnification is what causes the beam to enlarge; the image that the main lens sees is larger than the actual LED. Some position in between these two extremes will be the optimal position for the two lens setup. The reason you want as large a diameter:focal length ratio as possible is so the pre collimator lens is as close as possible to the LED when the light cone just fills the main lens.
In the picture above, the light coming from the pre collimator lens appears to be coming from an image of the LED that is slightly below the actual LED and slightly larger.
there are two ways to use two lenses…
1) you arrange them in a typical Galilean Telescope fashion.
or…
2) you are actually making a “compound lens”. the rear lens closest to the light source is typically the shorter FL. The bigger FL lens is out front. FL of the NEW resultant compound lens? is determined by FL-1 and FL-2, and the airgap between them.
some general rules…
a) two lenses of equal FL, touching (airgap = 0mm) will make a single compound lens of exactly half. Example, two 100mm FL lenses touching? make a new compound lens of 50mm FL.
b) using example a… as you introduce airgap bigger than 0mm (not touching), the FL of the compound lens gets closer to 100mm FL, but never quite reaches it.
c) as the airgap gets bigger? the rear lens gets closer to the light source
d) the SIZE of the well focused emitter? is determined solely by the FL of the resulting compound lens. Smaller overall FL, bigger die projection size. larger overall FL, smaller die projection.
e) cigarette smoke is your friend for seeing you are not wasting light from lens to lens, lol.
f) theres no reason to limit yourself to 2 lenses, grasshopper… i have used 3 and 4 lenses before, with IR LED’s… to good effect.
g) since 2 lenses actually form ONE compound lens? and another 2 lenses form a second compound lens? using those 4 lenses, is actually like using 2 lenses, for the purposes of the math governing it.
h) if the two lenses are different FL? radically different? like… 25mmFL and 600mm FL ? the resulting lens will be a lot closer to 25 than to 600… but theres equations you can work out to accurately predict it based on both FL’s, and the airgap.
everytime i brought this idea up HERE, and on my other site? everyone poo-pooh’s the idea, and makes up ideas why it doesnt work and how it cant be efficient… even though the MATH shows it works. (also? Dr Jones described it… also? a “white paper” from edmunds describes it…)
I only use it on IR emitters… i’m glad someone started doing it with visible light…
when you use 2 lenses, and 2 lenses… and put THOSE two compound lenses together and use them as if they were 2 lenses? you have the advantage of tuning the system greatly…
1) you can adjust the FL of compound lens 1, by adjusting the airgap.
2) you can adjust the FL of compound lens 2, by adjusting THAT airgap.
3) you can adjust the FL of the overall 4 lens system? by adjusting the airgap between both compound lenses…
its a lot easier tuning a 4 lens setup with visible light and cigarette smoke, LMAO, i was working with infrared emitters… it was a PITA… ha ha.
You guys are talking about and you all made double lens systems lights.
There are diy lights with triple or more lens system and I’ve also done them. Seedstar will be familiar with them (T20 with doubler and Sunnranger). T20D(adding telephoto doubler lens on main t20 lenses) SR (adding night vision IR coated objective lens instead of stock T20 lenses). All of them have recessed flood comparing to stock light.
While they have very clear die projection and indeed performance will improve over stock T20 neither of them can’t beat quality single aspheric setup (50mm).
This are nice experiments indeed:
EasyB: http://www.candlepowerforums.com/vb/showthread.php?282184-SST-50-homemade-spotlight
Djozz: 37.5cm fresnel lens spotlight build
Double or multiple lens system is different story for me and although small lenses in front of emitter of mentioned setups are pre collimator I don’t experience them like that.
I experience pre collimator as emitter dome replacement which protects emitter and enlarges main beam projection… Possibly without loosing lux performance or small gain if possible, and I really think it must be in as small configuration as possible.
I got my UF-1504 and installed an XP-L HI V2 1A emitter and FET driver from mtnelectronics. First, I made some external modifications. The big square protrusions on the body and tailcap make it uncomfortable to hold, so I removed them. I don’t have access to a lathe, so I used a saw, dremel, and file. It looks a bit rough, but it is now much nicer to hold in the hand, and I can now comfortably use an overhand grip, which was very uncomfortable in stock form. I also attached a belt clip to the head.
I then went about searching for a suitable lens to use as a pre collimator lens. I decided that the included threaded retaining ring would make a great height-adjustable lens mount. I decided on a 15.3mm diameter double convex lens with 7.6mm FL from anchor optics. It does not have AR coating. I wanted as strong a lens as possible and there was not an AR coated lens available that was as strong.
I drilled out the retaining ring to 12.5mm, then used a dremel and file to enlarge the ID to ~15.5mm. The lens just fits inside. I put small dots of epoxy around the perimeter to secure the lens to the retaining ring.
Here it is installed in the pill.
I adjusted the height of the pre collimator lens so that the cone of light just filled the main lens, as I described a couple posts back.
With a purple Efest 4200mAh 26650 cell at ~4.16V OC, I measured 5.3A bypassing the tailcap. I measured my ammeter resistance to be ~35mOhms. I took before and after pictures and lux measurements. The exposure settings were not controlled, so the pictures should only be used to compare the beam sizes. I recently bought a Tondaj LX-1010B which I used for the lux measurements here. Note that this meter reads high for cool white tints like the 1A. From djozz’s excellent measurements here
Stock light without pre collimator lens.
11,800 lux at 6.05m: 432,000 cd
approximate beam size: 20cm x 20cm
very approximate lumen estimate= 0.2m x 0.2m x 11,800lux = 472 lumens
With precollimator lens adjusted so cone just fills main lens.
8,600 lux at 6.05m: 315,000 cd
approximate beam size: 33.5cm x 33.5cm
very approximate lumen estimate= 0.335m x 0.335m x 8,600lux = 965 lumens
For this shot I adjusted the precollimator lens slightly closer to the LED, so that the light cone just overfills the main lens. I will lose a bit of light, but will pick up some cd.
9,800 lux at 6.05m: 359,000 cd
approximate beam size: 30.5cm x 30.5cm
very approximate lumen estimate= 0.305m x 0.305m x 9,800lux = 911 lumens
I’m pretty happy with the result; about double the beam lumens with not too bad an intensity drop. It could be improved by using a suitably strong precollimator lens with AR coating. I also bought a 15mm diameter plano-convex lens with 15mm FL and AR coating. I may try this lens in the future to see how it works in the light.
You did fine job there.
You got main beam enlargement but I think to many cd loss (about 30%)…
Search another lens combination. I don’t think they should be AR coated either.
Nice measurments! The results are quite as expected, but without experiments you will never know, sometimes things are quite different than theory.
A thought that is not neccessarily correct: What is decreasing your luxvalues when using a collimating lens (apart from reflection/absorption losses) is that the beam intensity is not constant at all angles, but decreases with angle. So pre-collimating will project more of the lower-intensity edge of the beam on the lens, effectively decreasing the lens diameter and thus spot brightness. You showed that nicely in your last experiment with the pre-collimating lens a bit closer to the led.
About the Tondaj meter, I just re-read my luxmeters-post and realised: it over-reads cool white leds, but the 16% over-reading with a cool white XM-L (in a cheap dive-light) that I found in the test, later appeared to be a fake Latticebright led with a huge blue component in the spectrum (see Hannes’ post from yesterday), real XM-L’s have never been so blue so the over-reading of a genuine Cree will not get as high as 16%.
That’s an interesting thought/interpretation which I’m sure there is some truth to.
Ah, okay. So without that data point it looks like the Tondaj meter reads about 5% high for cree cool white LEDs.
