1dash1
(1dash1)
March 19, 2016, 1:04am
25
Martin,
Does the turbo step-down kick in at 3 minutes or does it step down sooner?
How hot (subjectively) does the modded S50 get when it reaches step-down?
Does the modded S50 continue to heat up, even after downshifting to the high mode? If so, does it step down a second time (from high to medium)?
I wonder how well the turbo step-down works for the modded S50 and whether the flashlight will overheat when left on high.
Great work, BTW!
zelee
(zelee)
March 19, 2016, 3:00am
26
Too bad this light is sold out at banggood
1dash1
(1dash1)
March 19, 2016, 4:21am
27
The S50 is back in stock, as of today (Friday, March 19).
And the discount code still works!
sedstar
(sedstar)
March 19, 2016, 5:26am
28
i found this video on youtube, and on hereā¦ looked like a cool, easy, modā¦
RaVeN
(RaVeN)
March 20, 2016, 5:22am
29
Did you measure the KCD/throw before the mod? Interested in this with the great price of the group buy, but i want to know how much throw it has.
M4D_M4X
(M4D M4X)
March 20, 2016, 5:48am
30
i will hit the mancave and make that measurement when the baby alloe it
candyking
(candyking)
March 20, 2016, 11:18am
31
Hi, does the S70 use the same driver, so it is moddable in the same way?
Cheers!
M4D_M4X
(M4D M4X)
March 20, 2016, 11:32am
33
its also only a solder blob on the S70
but i am not sure it is the same driver (cause the e-switch)
candyking
(candyking)
March 20, 2016, 4:12pm
34
Awesome, really want to try that! Pm me code please? (For s50/s70)
1dash1
(1dash1)
March 20, 2016, 8:28pm
35
Do you mean that this same mod would work on the S70 (by applying a solder blob)?
Or do you mean that the stock S70 comes with a solder blob at this position on the circuit board?
NVM, found the answer:
Hallo, die Firma ThorFire hat mir ein Sample ihrer S70 Ć¼berlassen. Die Lampe ist sehr gut verarbeitet und durch das hohe Gewicht macht sie einen richtig guten Eindruck, auch die angegebenen 3.000 Lumen schƤtze ich als realistisch ein. Bezugsquelle...
Thanks for the tip Martin
ā¦ā¦ā¦ā¦ā¦ā¦ā¦ā¦.
WOW!
If you havenāt gotten in on freemeās groupbuy, do it.
First I bypassed both front/rear springs, then I re-did measurements of all modes with fully charged Samsung 30Qās:
Low: 0.26amps
Medium: 1.28amps
High: 2.53amps
Turbo: 3.95amps
Then I took the driver out and simply dropped a blob of solder on some empty pads, bypassing the stock sense resistors, and remeasured with the same cells:
Low: 0.23amps
Medium: 1.29amps
High: 2.93amps
Turbo: 9.20ā¦
M4D_M4X
(M4D M4X)
March 20, 2016, 8:22pm
36
The same mod can be made on the S70
i hope i can do the S70 mod-video this week
1dash1
(1dash1)
March 20, 2016, 8:33pm
37
Thanks, Martin!
According to the Taschenlampen website, the author measured 4K+ lumens from the solder-blobbed, de-domed S70. He also conjectured that the plain solder-blob modded S70 (without the de-dome) would have been around 5K lumens!
M4D_M4X
(M4D M4X)
March 20, 2016, 8:34pm
38
Yes - i have some contact with him and DO trust him 100%
Easyrr
(Easyrr)
March 22, 2016, 12:07pm
39
My happyness was a bit too early. Just got a note that restock will happen only on 18th April. Letās seeā¦
1dash1
(1dash1)
March 23, 2016, 9:18pm
40
Ditto for my S50 order. :cowboy_hat_face:
Will34 made a valid point with this question but I saw no answer. Iām hoping someone can give a range in ohms resistance that will likely achieve 4-5 amps.
M4D M4X S50 Review
Yeah I donāt think thereās any doubt you could do that, but someone will need to either find a datasheet for the components on the driver or do some trial-and-error to to find what resistor values give what results. I personally donāt have any resistors of that low value range to experiment with.
Youāre right about that. Thereās just not enough of these in the right hands yet to know the exact answer. Iām putting in a Mouser order and was just hoping someone could give me a likely suspect line up that I could try later. I donāt even have the light yet (Out of stock).
M4D_M4X
(M4D M4X)
March 28, 2016, 7:53pm
44
i can tell you that all the amps are going over that connention - to the resistors have to handle a lot power
i also have no set of resistors (nor the time) to try a lot combinationsā¦
