Are you sure?
On the web site linked, in the 3° photoshot, you can easily read XM-L 3800 (with some blur).
I’ve thinked that this is an old 3 x XM-L Trustfire rebranded. So that’s the cheap price.
But if it is a real 3 x XM-L2 for 20$ it’s a bargain!!!
Led: Cree or LB ? To good to be true
Thank you very much, nice video!
It looks like a pretty decent, budget friendly light for less than $20! Lots of critters in the video too. Ernest T. really took a likin’ to the postum…nice job, robo
It is a lot like my TF TR-3T6 but there are some minor differences inside with the driver springs, as I say I didn’t have the driver all the way out. It is slightly brighter also then the Trustfire is to the eye. It will only work with 2 or 3 cells.
I am no photographer and not an expert on lattice bright, so here are a couple of pictures of the emiiters in the light.
[stupid question on]
So this is much better than Trusftire TR, righ?
[stupid question off]
I ask it because 2 years ago I’ve thinked to buy the Trusfire, but never do it.
When I’ve saw your review of Lixada and the photos on TOMTOP site, assembled with 1x18650 too, I’ve said: “wow! Finally it’s time to pull the trigger”
But then on specifications I’ve read: Battery Configurations: 2 18650 3.7V* so….
It is a little brighter to the eye than the TF, build quality about the same I would say.
The configuration on the TomTop site shows with the battery tube is misleading , as with the tube in that configuration the 18650 is at least a full inch too short to use the light that way. It will only work with 2 cells (or 3 if you have a second extension tube).
Thanks for the review, Robo. The Trustfire TR 3T6 is a flashlight I have been considering and this seems basically a cone. But, I think am going to save my pennies, waiting for the Maxtoch 2X. However this triple has a nice broad, floody beam with some distance to it and it looks like a useful flashlight. Your reviews do a good job of demonstrating a flashlight’s capabilities at varying distances. Very helpful.
The proportions are strange, thickness of tube is odd. Not crazy about the large spring ground connection a la p60 either. I wonder if the short tube is for 2 X 18500.
