Review: FandyFire STL-V3 CREE XM-LT6 5-Mode
https://budgetlightforum.com/t/-/4133
X9 review
So the Trustfire is pulling 2.3Apms on high.
That means the driver on the Fandyfire is slightly more efficient?
I wanted to get this but I was in two minds because it was a 45mm head.
Now I will get this or the Sky Ray version if I can get it for $30.
Have you tried it with 2 x RCR123?
What's it pulling?
Its late , Ive got school tomorrow ... I will update as time permits ...
Mine pulls 1.57A from 2 x 16340 TF Flames (2.2A from 18650)
How do you like it so far ?
Nice review old4570!
I can confirm the relative lux readings: FF STL-V3 gives ~150%of Keygos KE5, but ~50% of FF STL-V6 (my readings for these three were something like 17kcd, 25kcd and 50kcd measured at 2m and converted back to 1m)
Edit: There might be something wrong, since 17kcd for Keygos sounds a bit too little. Have to check again later.
So far so good. It's small, almost pocketable, has a clip, is bright and throws well. My favorite 1x18650 thrower at the moment.
Ps. I was about to write a review next weekend but you were faster. :)
16340
Hi- 1.66a
Med- 0.71A
Low- 0.16A
Ceiling bounce 71Lux
throw 33800Lux
So there is a nice little boost from 8.4v / would love to see a extension tube ... for 2x18650
It's not too little. My U80 does that but with the under reading meter.
Plus you definitely cannot measure at 2m.
Actually I have the same under reading meter. :)
..and I know that 2m is too little for real throwers, but that was the best I could do yesterday. (I was just curious to see if STL-V3 really outshines KE5 by that much, and considered 2m as "good enough" for relative throw figures)
Updated with some nice outdoor beams !
Have you ever tried 2*IMR 18350's?
Dont own two 18350 IMR [ or one even ]
I just got mine yesterday. Definitely nice finish. Yeah, I was measuring the tailcap amps and it read around 1.8 A on high which I was kinda disappointed with. Was really hoping the driver was actually regulated at 2800 mAh like it says, but alas it is not the case. Still really bright though. I was hoping this would be like the X9 but with a better driver that I wouldn't need to replace to get over 2 amps. So is this driver regulated or not? How to find out?
I would say @ 8.4v or 2x16340 etc , it would be regulated ...
With a single 18650 , probably not so
Test regulation - Buy a light meter , and a Multi Meter .. Test battery voltage and then test output , where output drops , flashlight falls out of regulation ...
Hi there old, sorry I missed this review. Very well done as usual. Frontpage'd and Sticky'd now.
How does this stack up against the Uf980 in straight-up output?
Its only just dawned on me that this is supposed to be a (Q5) clone of the Fandyfire STL-V3. An XM-L mod of it may provide similar results for about half the price...
And what's about this?
http://www.ebay.com/itm/1300Lm-CREE-XM-L-T6-LED-Flashlight-Torch-Lamp-Light-/300641203038?pt=US_Flashlights&hash=item45ff9cb35e
Now it isn't alive, but after the spring festival I will order one.
