I would think attaching the handle to the tail end of the tube or tailcap would be better. Attached to the area that radiates heat produced by the emitters the handle might get a bit hot in the upper modes.
I took my Warson X65 with nut for tripod out.
Have a laser guiding thingy that came with a small metal tripod
Screwed it in and secured it as if it is a handle.
Works great.
Adding a handle to the mix would complicate things, add more material.
A nut in the head could be taken into account, it is a smaller addition.
But problem with a handle is 1 the looks and 2 location, ideal for a right handed person it should be placed as Freemes pic. But for looks having a nut would look best opposite of the button, not somewhere close to its right or left.
Also, when a handle is really wanted, just attach something to the removable part at the bottom of the battery tube (to get a handle like the Palight Boss) and position it to your liking and if you are left- or right handed.
Just ran it for 90 secs, and it got warm, nothing crazy. If I were to turn on the turbo timeout, I’d probably set it for 2 mins.
The M6 has a nice tripod mount btw, much better than the “nut light”. It’s near the head, opposite side of the switch - not perfectly weight centered though.
This mini 14500 / Eneloop SRK sounds like a great idea. I would definately participate if someone honchos a GB.
I just bought one of RMMs Supfire M6s with the full upgrade and 5D3 tint. It is a wonderful, powerful, floody and throwy light. The contrast and detail from the 5D3 tint is far superior to the cool tint floody lights I have.
I will wait and see how this full SRK GB progresses. Subscribed.
Hmm, IDK if 4 P cells can be charged safely.
But the idea of having a system like the Convou BD0x sound really good.
Snap on, waterproof, usable while charging, no internal micro USB port,
I do not know how much it would add to overall build costs but think it is worth exploring right?
Now that would get me interested…
Any chance on using the light as a usb backup charger then as well? Maybe with an external usb cable attaching to the waterproof connector?
In that case I will be in! Would make it a nice travel light and have a backup charger during the zombie apocalyps
heheh just thinking about it also adding the feature of powerbank might be hard to do.
Maybe not hard, but in terms of costs.
The convoy/dipper system is there, it works and looks good, well balanced with the small micro usb connector on the clipon thing…
Please check this review for the charging system
Making it charge other devices means adding a bigger USB out port to the clipon charging thing.
Internally more components are needed.
Using th BLF Premium on site with a powerbank means having something to charge a phone/tablet, so you would be able to distract the zombies with Flappy bird anyway
If we go this route than we can make the clear insulator between the pieces of te button a battery indicator.
But charging 4 18650s in parallel is going to take a loooonggg time.
I rather have a lower price than the ability to charge the cells inside the light.
Just my €0.02
