Not sure , the reason for the XP-E , if they were going for more throw - ok , but it does say in the description , easy to upgrade emitter .
I have been using it a lot around the house on a Nimh , and it works well , I think the cheapest retailer now is like $20 shipped , so Balder or other AA ??
Damn , Id have to say Balder . At $20 shipped , its a great buy .
Yeah, I didn't balk at the $20 price drop from CNQG. I snatched one up right away. :)
At least I would just be changing the emitter since the driver is already pumping hard enough. Maybe I'll be happy with the light as it is. I'm not too worried at $20 for a quality light :)
Not good. After nearly 5 days I'm notified the SE-1 isn't in stock and I'll have to wait until next week if I still want it. I ordered it the same day the price was lowered, or at least that was when this forum first noticed it. Not only does the website not reflect this status, I have to wait this long to find out after placing my order. There sure wasn't a problem taking my money :) I wonder if they filled orders that were placed after mine. I doubt it sold that quickly after lowering the price, considering I placed my order shortly after. It's a bit frustrating and not very professional.
Received my XP-E from CNQG today. It worked for about 30 seconds and now doesn't come on at all anymore. It started to flicker and then stopped working completely. I tried cleaning the threads and I inspected all that I could but there doesn't appear to be anything wrong visually. Crappy.
Too bad because when he did actually ship it the speed was the best I've ever got from China.
EDIT: I didn't even notice at first but there are absolutely no brand markings on this light. There are no markings whatsoever.
Bummer about the (nearly) DOA arrival man... I'm no tech expert on the lights but I'd make sure the contacts are clean and all the other things like that, that might be causing a problem.
Any suggestions to what I should do specifically? I cleaned it thoroughly with alcohol. Ric already responded and asked if I could return the light for a replacement. I'm not going ship a $20 light back to China, especially during the holiday season.
weiser701 Use a paper clip to to make contact from the battery to the threads if it lights up then it's a problem with the tail-cap. Make sure that the pill is screwed in properly and the tail-cap is screwed tight.
You could just send back the pill, use the old packing to keep costs down.
I was just about to do this since I started thinking it's a switch issue as opposed to a driver issue. I'll report back.
Martin from Balder has already responded as well. He might send me a replacement.
UPDATE: Okay, Martin is sending me a replacement but I'm still trying to figure out what the problem is. I've tried the paper clip trick and it still won't come on. Sometimes it wants to work fine and the rest of the time it doesn't come on at all. For example, It'll be working fine and then I'll set it down. I'll pick it up a few minutes later, try it out and get nothing. Seriously, what could be the issue?
The tail cap certainly makes solid contact. I inspected the solder points on the led board but I can't see anything between it and the driver. It's all sealed within the pill. It just seems so strange how it decides when and when not to work.
In response to your review I can say that the pill is threaded into the body and not glued. I've had the pill completely removed from the body and the head. Actually, when I first unscrewed the head from the body the pill came with it and I originally thought it was glued into the head.
If you look at the last picture , something oozing out ... When I say glued - yes its threaded in , but mine seems to have some sort of compound ...[ To thread lock ? ]
Oh yeah, I didn't notice that. Mine didn't come like that at all. It was threaded in rather tight but certainly no glue or thread lock. I ended up using some vise grips to remove the pill from the head.
I'm still trying to figure out why this darn thing only works some of the time!
Can someone please let me know what version to buy or pro/cons of each...I dont understand the tech. specs...Honestly at this stage of my flashlight knowledge I buy based on shape and battery type. But I really like 1AA lights and this unit has a lot of great reviews including this review...Many thanks.
Different emitters ... The XP-E will throw a little better - push light further out [ generally speaking ]
While the XM-L is a newer generation LED [ more output per mAh ] and generally puts out more of a floody beam .
For such a small host , XM-L would probably be choice , though I do like the SE1 just fine with the XP-E emitter , would be nice to do a side by side comparison ..
Hi Old4570, thanks for the reply, I appreciate it.
Do you think I should pay the extra $3 for the XM-L in neutral? (I never used to worry about $3 but on the BLF its just made me compare lights differently LOL.)
Thanks again for the review. I hope the light I get has the black clips, looks so much nicer vs the silver clips.
Wow , only you can answer that , $3 , If one were hot for neutral or warm [ which many are ] , it might be worth while especially if tint will dictate whether you use a light or not .
Throw is pretty good, but not as good as the Xtar WK26. I love the H-M-L modes with no memory. Build quality is great. Hotspot is beautiful - no rings or whatsoever.
Do you guys think I could get more throw from a R5 or T6 diode? I know that R3 is supposed to throw better, or so I’ve read. I’m thinking of buying another one and I’m wondering between R5 or T6.
Any other suggestions for a “throwy” 14500 light with straight body? I mean the head should be no wider than the tail. Also it has to be better than Xtar WK26, otherwise there is no point. Thanks for any help.
