You have to right-click on the pics and select “copy picture link”
Thanks - X3
But it’s hard to right click on the mobile phone
Really I’ve got no other computer!
I received my copper x6 spacer (the shorter one to fit a lens on top of the optics). I installed it and I had to dremel the lower part of the spacer so that it would fit into the light perfectly. I’ll post a picture later when I get a chance.
Thanks for your feedback vinte77. My X6 host has about 21.4mm pcb place diameter, spacer lower part was about 21.0mm. Seems that host dimentions may differs a little.
There is some delay in production (machine tools are to busy), hope X6 Al spacers, more Convoy spacers and pills will be ready till end of April.
I will definitely take a copper S2+ full pill for a triple when they are finished.
Do we have any news on the X6 aluminum spacers ?
If everything goes good, more convoy spacers, single and triple pills, X6 Al spacers, X5 quad kits will be ready in 1-2 weeks.
Good news, your solid copper pills are great.
I got my first order of S2+ spacers today. Pretty good. Twenty days. My first ever order from Russia.
Very nice
I’m waiting to order when new batch is ready !
I think we could use some spacer rings so we can fit 24mm Carlco quad optics into some lights. I haven’t yet found a light it fits in, always a tad smaller than the inside diameter of the bezel. We need some kind of ring that will hold it into place for lights that need a few more millimeters to retain it.
Hi, I am interested in a Cu full pill for triple LED (for Convoy S2+).
there are only 2 problems:
- it is almost unreal to make them universal
- flashlight will become non-waterproof.
I have considered different variants of flashlight waterproof from bezel side and that one that I have chosen for X5 quad looks better than others. Parts needs to be precision made, but if they are good you have best waterproof and lowest losses in optics cause you don`t cut it`s edge with bezel.
By the way, I have made some measuments of Manker U11 and seems that upper part from X5 quad set (stainless steel liner/tube) can fit it. But spacer itself is a big problem, I can`t imagine how to make it better.
Have you designed the X5 quad spacer ?
Will it be like DB custom’s that has sides to hold the optic ?
No, it will consists from 2 parts and will not have thread.
Thank you .
I think this will work fine . Will these be ready in about one weak as stated ?
So , let’s hope they will be ready some time
I appreciate your effort!
My first order from Russia arrived today, XP-G3 x 10pcs
thanks kiriba
Used Kiriba’s triple pill for a red convoy S2+ build today.
-Triple 219C on noctigon, soldered directly to the pill of course
–8x7135 guppydrv Qlite driver
Everything fits nicely and the driver was easy to solder to the retaining walls. Much better than using the stock brass pill converted to triple pill with a 16mm mcpcb for filling.
Received 4x xp-g3 and one cute-3 optic ….
They were shipped immediately after payment .
Very well packed , and received in only 15 days .
Thanks
