Some History
This was my first successful test to combine a boost circuit with an ATtiny13A.
I hooked up a stock Nanjg110 to an ATtiny13A and a capacitor, both remainder of a Nanjg AK47. I added an OffTimeCap between Pin-2 and GND. And I used an IRLML0030TRPbF as FET. I placed the FET on the pads for a 7135, cut the traces and rewired (better: re-blobbed) for the PWM signal from Pin-6.
I flashed a it with an offtime firmware with 4 modes.
And there was light.
At 18kHz PWM values of 2 – 10 – 40 – 255 resulted in 12mA – 102mA – 198mA – 404mA with a single full and resting Eneloop.
With 2xAA the boost controller died (blew a tiny fan of smoke) at one of the first mode changes. It’s surely the controller that died, I swapped this single component from a new 110 and everything was working again (with 1AA).
That’s when I took a closer look at the Fasttech boost driver (who has a controller for modes) and the two resistors there seemed to serve as protection.
In the meantime I found a replacement diode for the large SS14/SS24. As I looked for 2A diodes I stumbled upon the BAT60A.
Even rated 3A, only 370mV forward voltage, and SOD-323 package. It’s the teeny-tiny component on the right, where the cathode line uses up almost half the component.
I hooked it up in replacement and drained 5× 1AA and 6× 2AA (Eneloops) on this driver, while monitoring input and output current. Works perfectly fine. Even increased output current in 1AA config and efficiency in 2AA config (needs a lower input current to reach the 920 mA).
Then I reworked the FastTech driver (comes in blue now instead of green).
MCU changed to Attiny13a (which was pre-programmed)
Some MCU-traces cut (Pins1/4/5)
Rewired: Pin6 to Fet-Gate (red wire)
MCU+ is already connected to V+out
Rewired: MCU- to GND
MCU- of the original driver is connected to Fet-Source/PAM3. This did not work with the Attiny, it wouldn’t change modes.
Rewired MCU- to GND (black wire) and voila: 3-mode boost driver that did survive several 1AA and 2AA drains.
The first Oshpark board HQB15 v1 successfully built.
2× 2AA and 3× 1AA (Eneloops) drained, about 200 mode changes, all good.
It’s a HQB15 de-luxe with Coilcraft inductor and high value capacitors.
Partlist with used values and the firmware in this post.
Driver height with this inductor is 3.7mm (0.2mm less than with the FT inductor). Now take the new Oshpark 0.8mm boards and you’re down to 2.9mm. That’s 3.0mm less than a Nanjg110.
Enough space around the Attiny13a for the clip after driver assembly.
I took the experience from building v1 (it’s really, really tight) and tweaked the design. I skipped sharing v1 and went straight to HQB15 v2.
All future Oshpark boards will be introduced in this thread.
